I recently decided to install my old SATA SSD from my old laptop into my new one, since I don’t use my old laptop anymore and need more space. Now I have my NVMe drive with Manjaro/Windows plus the newly installed SATA with Arch/Windows.
Entering my BIOS boot menu offers me manjaro (grub), windows boot (NVMe) and windows boot (SATA). The Arch installation is not found. Can I add it to grub in Manjaro or will it be a problem that it’s on another disk?
What I want to do now is nuke the Windows installation on the NVMe - one Windows installation is enough for certain games, and it makes sense to leave the one with the most space on the SATA drive. I want to use the space for my Manjaro installation. Is there any easy way to merge it with the existing partition or would it be easier to just reinstall everything?
So, I want to add Arch to the grub menu, remove NVMe Windows and add the free space to my Manjaro installation, and add the SATA Windows and Arch to my filesystem (I guess I’ll have to add fstab entries?).
Does anyone know if my SATA Windows installation will start acting weird from my changing the disk into a new computer? Or if it’ll complain about the license being different on this machine as compared to the previous one?
Any tips for how to achieve this or cautions about problems I haven’t thought about or alternate solutions are highly welcome and appreciated!
Both my laptops, the old and new, have intel+nvidia. Maybe this makes the transition easier? Maybe it has no effect?
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 465,8G 0 disk
├─sda1 8:1 0 300M 0 part
├─sda2 8:2 0 99M 0 part
├─sda3 8:3 0 128M 0 part
├─sda4 8:4 0 338,6G 0 part
├─sda5 8:5 0 892M 0 part
└─sda6 8:6 0 125,8G 0 part
nvme0n1 259:0 0 476,9G 0 disk
├─nvme0n1p1 259:1 0 260M 0 part /boot/efi
├─nvme0n1p2 259:2 0 16M 0 part
├─nvme0n1p3 259:3 0 156,3G 0 part
├─nvme0n1p4 259:4 0 1000M 0 part
└─nvme0n1p5 259:5 0 319,4G 0 part /
sudo fdisk -l
Disk /dev/nvme0n1: 476,94 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: HFM512GDHTNG-8310A
Disklabel type: gpt
Disk identifier: 0897E4E2-753E-4FFC-9AC8-E2F24CF18DB4
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 534527 532480 260M EFI System
/dev/nvme0n1p2 534528 567295 32768 16M Microsoft reserved
/dev/nvme0n1p3 567296 328247295 327680000 156,3G Microsoft basic data
/dev/nvme0n1p4 998166528 1000214527 2048000 1000M Windows recovery environment
/dev/nvme0n1p5 328247296 998166527 669919232 319,4G Linux filesystem
Partition table entries are not in disk order.
Disk /dev/sda: 465,76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 850
Disklabel type: gpt
Disk identifier: 8CCAABE6-BA5B-4053-84E8-7C518D402DBE
/dev/sda1 2048 616447 614400 300M Windows recovery environment
/dev/sda2 616448 819199 202752 99M EFI System
/dev/sda3 819200 1081343 262144 128M Microsoft reserved
/dev/sda4 1081344 711203760 710122417 338,6G Microsoft basic data
/dev/sda5 711204864 713031679 1826816 892M Windows recovery environment
/dev/sda6 713031680 976773134 263741455 125,8G Linux filesystem
