Hi! I have a problem with disappearing wifi interface, it happens once per few hours. Only reboot helps.
Here is my system:
inxi --admin --verbosity=7 --filter --width
Kernel: 6.0.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=10456b6e-a634-4609-ab49-e9dd374942c0 rw quiet
resume=UUID=46b9a338-1113-4df8-b0a9-3c82db3b07ca
usbcore.usbfs_memory_mb=128
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: X411UN v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X411UN v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X411UN.310 date: 04/17/2019
ID-1: BAT0 charge: 41.4 Wh (98.3%) condition: 42.1/42.1 Wh (100.0%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 1
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M185/M225
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 15.51 GiB used: 5.22 GiB (33.6%)
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 28808
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: ASUSTeK driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d10
class-ID: 0302
Device-3: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:5a07 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x06f3 built: 2016 res: 1920x1080
hz: 57 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound API: ALSA v: k6.0.6-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: AzureWave
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-8:4 chip-ID: 13d3:3526 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 238.47 GiB used: 114.9 GiB (48.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: A020 scheme: GPT
ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 27.52 GiB (72.1%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 10456b6e-a634-4609-ab49-e9dd374942c0
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 26.5 MiB (10.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: 7ADF-0389
ID-3: /home raw-size: 135.74 GiB size: 132.55 GiB (97.65%)
used: 87.36 GiB (65.9%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 0aaf16cb-135c-445a-a626-a51615827b09
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 46b9a338-1113-4df8-b0a9-3c82db3b07ca
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 58.71 GiB fs: ntfs label: OS
uuid: 7660E24560E20C25
ID-3: /dev/sda4 maj-min: 8:4 size: 800 MiB fs: ntfs label: RECOVERY
uuid: E838B5DB38B5A8C8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 1-6:3 info: IMC Networks VGA UVC WebCam type: Video
Device-3: 1-8:4 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 52.0 C pch: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3600
Processes: 251 Uptime: 21m wakeups: 3 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1809
pm: pacman pkgs: 1791 libs: 465 tools: pamac pm: flatpak pkgs: 0 pm: snap
pkgs: 18 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.23
and sudo dmesg | grep rtw_8822be
[ 6.152012] rtw_8822be 0000:02:00.0: Firmware version 27.2.0, H2C version 13
[ 6.152047] rtw_8822be 0000:02:00.0: enabling device (0000 -> 0003)
[ 6.222268] rtw_8822be 0000:02:00.0 wlp2s0: renamed from wlan0
[ 6.295430] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 6.295436] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 6.295444] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 7.536031] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 7.536037] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 7.536043] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 7.660274] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 7.660278] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 7.660284] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 33.419576] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 33.419582] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 33.419589] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 33.585088] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 33.585097] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 33.585107] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 34.029454] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 34.029464] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 34.029476] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 34.648562] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 34.648573] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 34.648585] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 35.119720] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 35.119732] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 35.119744] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 35.397799] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 35.397811] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 35.397826] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 216.293554] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 216.293561] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 216.293570] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 431.282369] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 431.282376] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 431.282385] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 820.262315] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 820.262323] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 820.262331] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 835.999128] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 835.999130] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 835.999133] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 903.223749] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 903.223756] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 903.223765] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1002.735376] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1002.735383] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1002.735391] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1041.525489] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1041.525498] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1041.525506] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1080.231358] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1080.231366] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1080.231374] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1082.557259] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1082.557263] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1082.557268] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1222.468103] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1222.468113] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1222.468125] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1225.018627] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1225.018629] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1225.018632] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1242.985202] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1242.985212] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1242.985223] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1271.806606] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1271.806610] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1271.806614] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1343.562798] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1343.562806] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1343.562815] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1356.242576] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1356.242584] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1356.242593] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1437.043619] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1437.043626] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1437.043635] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
[ 1460.527454] rtw_8822be 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 1460.527457] rtw_8822be 0000:02:00.0: device [10ec:b822] error status/mask=00000001/00006000
[ 1460.527459] rtw_8822be 0000:02:00.0: [ 0] RxErr (First)
I think it’s been happening since last few kernels, but I don’t remember which exactly kernel version it was. Could you help me with fixing it, so I can use the newest kernel version?
