journalctl -b0 -p4 --no-pager
Aug 27 10:19:50 gabe-pc kernel: #7 #8 #9 #10 #11
Aug 27 10:19:50 gabe-pc kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Aug 27 10:19:50 gabe-pc systemd[1]: Configuration file /etc/systemd/system/piavpn.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Aug 27 10:19:50 gabe-pc kernel: usb 3-1.2: config 1 interface 0 altsetting 0 endpoint 0x83 has an invalid bInterval 32, changing to 9
Aug 27 10:19:50 gabe-pc kernel: nvidia: loading out-of-tree module taints kernel.
Aug 27 10:19:50 gabe-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
Aug 27 10:19:50 gabe-pc kernel: Disabling lock debugging due to kernel taint
Aug 27 10:19:50 gabe-pc kernel: EXT4-fs (sdb3): warning: mounting fs with errors, running e2fsck is recommended
Aug 27 10:19:51 gabe-pc kernel:
Aug 27 10:19:51 gabe-pc kernel: kvm: disabled by bios
Aug 27 10:19:51 gabe-pc kernel: usb 3-1.2: Warning! Unlikely big volume range (=5120), cval->res is probably wrong.
Aug 27 10:19:51 gabe-pc kernel: usb 3-1.2: [5] FU [Mic Capture Volume] ch = 1, val = 7680/12800/1
Aug 27 10:19:51 gabe-pc kernel: usb 3-1.2: Failed to query (GET_INFO) UVC control 2 on unit 1: -32 (exp. 1).
Aug 27 10:19:51 gabe-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
Aug 27 10:19:51 gabe-pc kernel: kauditd_printk_skb: 147 callbacks suppressed
Aug 27 10:19:51 gabe-pc kernel: bFWReady == _FALSE call reset 8051...
Aug 27 10:19:51 gabe-pc kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Aug 27 10:19:52 gabe-pc kernel: kvm: disabled by bios
Aug 27 10:19:52 gabe-pc kernel: sd 12:0:0:0: [sdd] No Caching mode page found
Aug 27 10:19:52 gabe-pc kernel: sd 12:0:0:0: [sdd] Assuming drive cache: write through
Aug 27 10:19:52 gabe-pc kernel: sd 13:0:0:0: [sde] No Caching mode page found
Aug 27 10:19:52 gabe-pc kernel: sd 13:0:0:0: [sde] Assuming drive cache: write through
Aug 27 10:19:52 gabe-pc systemd-modules-load[367]: Failed to insert module 'kvm_amd': Operation not supported
Aug 27 10:19:52 gabe-pc systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Aug 27 10:19:52 gabe-pc systemd[1]: Failed to start Load Kernel Modules.
Aug 27 10:19:52 gabe-pc systemd[728]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Aug 27 10:19:53 gabe-pc kernel: ==> rtl8188e_iol_efuse_patch
Aug 27 10:19:54 gabe-pc dnsmasq[1236]: no servers found in /etc/resolv.conf, will retry
Aug 27 10:19:55 gabe-pc systemd[1985]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Aug 27 10:19:55 gabe-pc systemd[1985]: Failed to start Update XDG user dir configuration.
Aug 27 10:19:55 gabe-pc sddm-greeter[2098]: QFont::fromString: Invalid description '(empty)'
Aug 27 10:19:56 gabe-pc sddm-greeter[2098]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffc7164f8e0), parent's thread is QThread(0x55d8d00a9490), current thread is QThread(0x55d8d025e920)
Aug 27 10:19:56 gabe-pc sddm-greeter[2098]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Aug 27 10:19:57 gabe-pc kernel: kauditd_printk_skb: 1245 callbacks suppressed
Aug 27 10:20:03 gabe-pc sddm-greeter[2098]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Aug 27 10:20:03 gabe-pc sddm-greeter[2098]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Aug 27 10:20:03 gabe-pc sddm-greeter[2098]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Aug 27 10:20:03 gabe-pc sddm-greeter[2098]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Aug 27 10:20:03 gabe-pc sddm-greeter[2098]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Aug 27 10:20:04 gabe-pc sddm-greeter[2098]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.30'
Aug 27 10:20:04 gabe-pc sddm-greeter[2098]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:36: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:37: Unknown key name 'PrefersNonDefaultGPU' in section 'Desktop Entry', ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:40: Unknown section 'Desktop Action Store'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:70: Unknown section 'Desktop Action Community'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:100: Unknown section 'Desktop Action Library'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:130: Unknown section 'Desktop Action Servers'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:160: Unknown section 'Desktop Action Screenshots'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:190: Unknown section 'Desktop Action News'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:220: Unknown section 'Desktop Action Settings'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:250: Unknown section 'Desktop Action BigPicture'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/steam.desktop:254: Unknown section 'Desktop Action Friends'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2623]: /home/gcars06/.config/autostart/wine.sh.desktop: not generating unit, error parsing Exec= line: Permission denied
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:36: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:37: Unknown key name 'PrefersNonDefaultGPU' in section 'Desktop Entry', ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:40: Unknown section 'Desktop Action Store'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:70: Unknown section 'Desktop Action Community'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:100: Unknown section 'Desktop Action Library'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:130: Unknown section 'Desktop Action Servers'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:160: Unknown section 'Desktop Action Screenshots'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:190: Unknown section 'Desktop Action News'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:220: Unknown section 'Desktop Action Settings'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:250: Unknown section 'Desktop Action BigPicture'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/steam.desktop:254: Unknown section 'Desktop Action Friends'. Ignoring.
Aug 27 10:20:14 gabe-pc systemd-xdg-autostart-generator[2926]: /home/gcars06/.config/autostart/wine.sh.desktop: not generating unit, error parsing Exec= line: Permission denied
Aug 27 10:20:14 gabe-pc ksplashqml[2882]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/splash/Splash.qml:90: ReferenceError: bottomRect is not defined
Aug 27 10:20:14 gabe-pc ksplashqml[2882]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/splash/Splash.qml:89: ReferenceError: bottomRect is not defined
Aug 27 10:20:14 gabe-pc plasma_session[2929]: kf.config.core: "KConfigIni: In file /etc/xdg/autostart/nvidia-force-comp-pipeline.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
Aug 27 10:20:14 gabe-pc klauncher[2937]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Aug 27 10:20:15 gabe-pc kcminit_startup[2941]: QDBusConnection: error: could not send signal to service "" path "//home/gcars06/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/gcars06/.kde4/share/config/kdeglobals
Aug 27 10:20:15 gabe-pc pipewire[2707]: spa.v4l2: '/dev/video0' VIDIOC_QUERYCTRL: Input/output error
Aug 27 10:20:15 gabe-pc kernel: usb 3-1.2: Failed to query (GET_DEF) UVC control 2 on unit 1: -32 (exp. 1).
Aug 27 10:20:15 gabe-pc pipewire-media-session[2710]: ms.core: error id:47 seq:488 res:-5 (Input/output error): enum params id:1 (Spa:Enum:ParamId:PropInfo) failed
Aug 27 10:20:15 gabe-pc kwin_x11[2952]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Aug 27 10:20:15 gabe-pc kwin_x11[2952]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Aug 27 10:20:15 gabe-pc kwin_x11[2952]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Aug 27 10:20:15 gabe-pc kwin_x11[2952]: kwin_decorations: Could not locate decoration plugin "org.kde.lightly"
Aug 27 10:20:15 gabe-pc kded5[2949]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
Aug 27 10:20:15 gabe-pc ksmserver[2995]: Qt: Session management error: networkIdsList argument is NULL
Aug 27 10:20:15 gabe-pc kernel: ntfs3: Unknown parameter 'windows_names'
Aug 27 10:20:15 gabe-pc kernel: FAT-fs (sdb2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Aug 27 10:20:15 gabe-pc kernel: FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Aug 27 10:20:15 gabe-pc kmixctrl[3035]: org.kde.kmix: Channel Map contains a pa_channel_position we cannot handle 12
Aug 27 10:20:15 gabe-pc kmixctrl[3035]: org.kde.kmix: Channel Map contains a pa_channel_position we cannot handle 13
Aug 27 10:20:15 gabe-pc kmixctrl[3035]: org.kde.kmix: no mix devices and not dynamic
Aug 27 10:20:15 gabe-pc plasma_session[2929]: kf.config.core: "KConfigIni: In file /etc/xdg/autostart/nvidia-force-comp-pipeline.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
Aug 27 10:20:16 gabe-pc plasma_session[2929]: org.kde.plasma.session: failed to parse "/home/gcars06/.config/autostart/wine.sh.desktop" for autostart
Aug 27 10:20:16 gabe-pc backlighthelper[3138]: org.kde.powerdevil: no kernel backlight interface found
Aug 27 10:20:16 gabe-pc org_kde_powerdevil[3004]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Aug 27 10:20:16 gabe-pc org_kde_powerdevil[3004]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Aug 27 10:20:16 gabe-pc plasmashell[3005]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Aug 27 10:20:16 gabe-pc plasmashell[3005]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Aug 27 10:20:16 gabe-pc kded5[2949]: kscreen.kded: PowerDevil SuspendSession action not available!
Aug 27 10:20:16 gabe-pc pipewire-media-session[2710]: ms.mod.default-profile: device 'alsa_card.pci-0000_2b_00.1': can't restore profile: No such device
Aug 27 10:20:16 gabe-pc org_kde_powerdevil[3004]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Aug 27 10:20:16 gabe-pc org_kde_powerdevil[3004]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: kwin_core: XCB error: 10 (BadAccess), sequence: 888, resource id: 480, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1009, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1153, resource id: 14680110, major code: 3 (GetWindowAttributes), minor code: 0
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1154, resource id: 14680110, major code: 14 (GetGeometry), minor code: 0
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1157, resource id: 14680111, major code: 3 (GetWindowAttributes), minor code: 0
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1158, resource id: 14680111, major code: 14 (GetGeometry), minor code: 0
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1161, resource id: 14680112, major code: 3 (GetWindowAttributes), minor code: 0
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1162, resource id: 14680112, major code: 14 (GetGeometry), minor code: 0
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1165, resource id: 14680113, major code: 3 (GetWindowAttributes), minor code: 0
Aug 27 10:20:16 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1166, resource id: 14680113, major code: 14 (GetGeometry), minor code: 0
Aug 27 10:20:17 gabe-pc gnome-keyring-daemon[3392]: discover_other_daemon: 1
Aug 27 10:20:17 gabe-pc pipewire-media-session[2710]: ms.mod.default-profile: device 'alsa_card.pci-0000_2b_00.1': can't restore profile: No such device
Aug 27 10:20:17 gabe-pc plasmashell[3005]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Aug 27 10:20:17 gabe-pc plasmashell[3005]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Aug 27 10:20:17 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1426, resource id: 71303176, major code: 12 (ConfigureWindow), minor code: 0
Aug 27 10:20:17 gabe-pc xembedsniproxy[3006]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 449, resource id: 71303176, major code: 7 (ReparentWindow), minor code: 0
Aug 27 10:20:17 gabe-pc xembedsniproxy[3006]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 451, resource id: 71303176, major code: 142 (Unknown), minor code: 1
Aug 27 10:20:17 gabe-pc xembedsniproxy[3006]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 452, resource id: 71303176, major code: 6 (ChangeSaveSet), minor code: 0
Aug 27 10:20:17 gabe-pc xembedsniproxy[3006]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 453, resource id: 71303176, major code: 25 (SendEvent), minor code: 0
Aug 27 10:20:17 gabe-pc xembedsniproxy[3006]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 454, resource id: 71303176, major code: 12 (ConfigureWindow), minor code: 0
Aug 27 10:20:17 gabe-pc xembedsniproxy[3006]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 456, resource id: 71303176, major code: 12 (ConfigureWindow), minor code: 0
Aug 27 10:20:17 gabe-pc xembedsniproxy[3006]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 457, resource id: 71303176, major code: 8 (MapWindow), minor code: 0
Aug 27 10:20:17 gabe-pc xembedsniproxy[3006]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 458, resource id: 71303176, major code: 61 (ClearArea), minor code: 0
Aug 27 10:20:17 gabe-pc plasmashell[3005]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 27 10:20:18 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2449, resource id: 4194348, major code: 18 (ChangeProperty), minor code: 0
Aug 27 10:20:18 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Aug 27 10:20:18 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Aug 27 10:20:18 gabe-pc plasmashell[3005]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5653158fa990)
Aug 27 10:20:18 gabe-pc plasmashell[3005]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5653158faa80)
Aug 27 10:20:18 gabe-pc plasmashell[3005]: Entry is not valid "org.kde.discover" QSharedPointer(0x565315901660)
Aug 27 10:20:18 gabe-pc plasmashell[3005]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x565315b1cb10)
Aug 27 10:20:18 gabe-pc plasmashell[3005]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x565315901660)
Aug 27 10:20:18 gabe-pc plasmashell[3005]: Entry is not valid "org.kde.discover" QSharedPointer(0x5653159016b0)
Aug 27 10:20:18 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Aug 27 10:20:18 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Aug 27 10:20:18 gabe-pc kded5[2949]: org.kde.kmix: Channel Map contains a pa_channel_position we cannot handle 12
Aug 27 10:20:18 gabe-pc kded5[2949]: org.kde.kmix: Channel Map contains a pa_channel_position we cannot handle 13
Aug 27 10:20:18 gabe-pc kded5[2949]: org.kde.kmix: no mix devices and not dynamic
Aug 27 10:20:18 gabe-pc plasmashell[3005]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Aug 27 10:20:18 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Aug 27 10:20:18 gabe-pc plasmashell[3005]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 27 10:20:19 gabe-pc plasmashell[3005]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Aug 27 10:20:19 gabe-pc plasmashell[3005]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 27 10:20:19 gabe-pc plasmashell[3005]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 27 10:20:19 gabe-pc plasmashell[3005]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x56531667ca70) QQmlContext(0x565315e71870) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 27 10:20:19 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Aug 27 10:20:19 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Aug 27 10:20:19 gabe-pc plasmashell[3005]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x565316ca69c0) QQmlContext(0x565315e71870) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 27 10:20:19 gabe-pc plasmashell[3005]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4627, resource id: 4194306, major code: 19 (DeleteProperty), minor code: 0
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4640, resource id: 4194306, major code: 19 (DeleteProperty), minor code: 0
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4641, resource id: 4194306, major code: 18 (ChangeProperty), minor code: 0
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4642, resource id: 4194306, major code: 19 (DeleteProperty), minor code: 0
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4643, resource id: 4194306, major code: 19 (DeleteProperty), minor code: 0
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4644, resource id: 4194306, major code: 19 (DeleteProperty), minor code: 0
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4645, resource id: 4194306, major code: 7 (ReparentWindow), minor code: 0
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4646, resource id: 4194306, major code: 6 (ChangeSaveSet), minor code: 0
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4647, resource id: 4194306, major code: 2 (ChangeWindowAttributes), minor code: 0
Aug 27 10:20:20 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4648, resource id: 4194306, major code: 10 (UnmapWindow), minor code: 0
Aug 27 10:20:22 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Aug 27 10:20:22 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5786, resource id: 10485890, major code: 18 (ChangeProperty), minor code: 0
Aug 27 10:20:22 gabe-pc bluetoothd[728]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Aug 27 10:20:23 gabe-pc kernel: kauditd_printk_skb: 24 callbacks suppressed
Aug 27 10:20:24 gabe-pc plasmashell[3005]: libpng warning: iCCP: known incorrect sRGB profile
Aug 27 10:20:24 gabe-pc plasmashell[3005]: libpng warning: known incorrect sRGB profile
Aug 27 10:20:24 gabe-pc plasmashell[3005]: libpng warning: profile matches sRGB but writing iCCP instead
Aug 27 10:20:24 gabe-pc plasmashell[3005]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
Aug 27 10:20:24 gabe-pc plasmashell[3005]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
Aug 27 10:20:24 gabe-pc plasmashell[3005]: qt.svg: link #fcitx-kbd is undefined!
Aug 27 10:20:28 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11577, resource id: 10485916, major code: 18 (ChangeProperty), minor code: 0
Aug 27 10:20:29 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12852, resource id: 10485875, major code: 15 (QueryTree), minor code: 0
Aug 27 10:20:29 gabe-pc kwin_x11[2952]: kwin_core: XCB error: 152 (BadDamage), sequence: 12906, resource id: 14680207, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Aug 27 10:20:30 gabe-pc ktraderclient5[4986]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
Aug 27 10:20:30 gabe-pc ktraderclient5[4986]: kf.service.sycoca: Invalid Service : "/usr/share/applications/qemu.desktop"
Aug 27 10:20:32 gabe-pc plasmashell[3005]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x565315afae90) QQmlContext(0x565315e71870) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 27 10:20:32 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Aug 27 10:20:32 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Aug 27 10:20:32 gabe-pc plasmashell[3005]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Aug 27 10:20:38 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18244, resource id: 10485921, major code: 15 (QueryTree), minor code: 0
Aug 27 10:20:47 gabe-pc kernel: kauditd_printk_skb: 7 callbacks suppressed
Aug 27 10:20:52 gabe-pc ktraderclient5[7472]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/microsoft-edge" not found
Aug 27 10:21:53 gabe-pc systemd-networkd-wait-online[763]: Timeout occurred while waiting for network connectivity.
Aug 27 10:21:53 gabe-pc systemd[1]: systemd-networkd-wait-online.service: Failed with result 'exit-code'.
Aug 27 10:21:53 gabe-pc systemd[1]: Failed to start Wait for Network to be Configured.
Aug 27 10:21:54 gabe-pc com.teamviewer.TeamViewer[7549]: qrc:/ui/MainWindow/Meeting/MeetingJoinPanel.qml:69: TypeError: Cannot read property 'participantName' of null
Aug 27 10:21:54 gabe-pc com.teamviewer.TeamViewer[7549]: qrc:/ui/MainWindow/Meeting/MeetingJoinPanel.qml:17: TypeError: Cannot read property 'joinEnabled' of null
Aug 27 10:21:54 gabe-pc com.teamviewer.TeamViewer[7549]: qrc:/ui/MainWindow/Meeting/MeetingJoinPanel.qml:18: TypeError: Cannot read property 'joining' of null
Aug 27 10:21:54 gabe-pc com.teamviewer.TeamViewer[7549]: file:///opt/teamviewer/tv_bin/RTlib/qt/qml/QtQuick/Controls/Private/Style.qml:52: ReferenceError: __control is not defined
Aug 27 10:21:54 gabe-pc com.teamviewer.TeamViewer[7549]: file:///opt/teamviewer/tv_bin/RTlib/qt/qml/QtQuick/Controls/Styles/Base/ScrollViewStyle.qml:56: ReferenceError: __control is not defined
Aug 27 10:21:54 gabe-pc com.teamviewer.TeamViewer[7549]: qrc:/ui/MainWindow/Onboarding/OnboardingTab.qml:80: TypeError: Cannot read property 'headline' of null
Aug 27 10:21:54 gabe-pc com.teamviewer.TeamViewer[7549]: qrc:/ui/MainWindow/Onboarding/OnboardingTab.qml:95: TypeError: Cannot read property 'image' of null
Aug 27 10:21:54 gabe-pc com.teamviewer.TeamViewer[7549]: qrc:/ui/MainWindow/Onboarding/OnboardingTab.qml:101: TypeError: Cannot read property 'text' of null
Aug 27 10:22:00 gabe-pc com.teamviewer.TeamViewer[7549]: qrc:/ui/MainWindow/Partnerlist/Partnerlist.qml:24: TypeError: Cannot read property 'itemModel' of null
Aug 27 10:22:16 gabe-pc xdg-desktop-portal-kde[3382]: xdp-kde-settings: Namespace "org.gnome.desktop.a11y.interface" is not supported
Aug 27 10:22:16 gabe-pc deja-dup[7623]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
Aug 27 10:24:50 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21449, resource id: 81788936, major code: 18 (ChangeProperty), minor code: 0
Aug 27 10:26:45 gabe-pc kscreenlocker_greet[7713]: Qt: Session management error: networkIdsList argument is NULL
Aug 27 10:26:45 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/lockscreen/LockScreen.qml:52:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/lockscreen/LockScreen.qml:52:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/lockscreen/MainBlock.qml:99:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/lockscreen/LockScreenUi.qml:66:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/lockscreen/LockScreenUi.qml:43:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/components/ActionButton.qml:33:5: Unable to assign [undefined] to int
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/components/KeyboardLayoutButton.qml:40: TypeError: Cannot read property 'length' of undefined
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/components/KeyboardLayoutButton.qml:35:5: Unable to assign [undefined] to QString
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/components/KeyboardLayoutButton.qml:29:5: Unable to assign [undefined] to int
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/components/Battery.qml:48:9: Unable to assign [undefined] to double
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: file:///home/gcars06/.local/share/plasma/look-and-feel/Iridescent-round/contents/components/UserDelegate.qml:41:5: Unable to assign [undefined] to int
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: qt.svg: link #fcitx-kbd is undefined!
Aug 27 10:26:46 gabe-pc kscreenlocker_greet[7713]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Aug 27 10:26:47 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23168, resource id: 81788970, major code: 18 (ChangeProperty), minor code: 0
Aug 27 10:29:59 gabe-pc plasmashell[3005]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x565316bbe9a0) QQmlContext(0x565315e71870) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 27 10:29:59 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Aug 27 10:29:59 gabe-pc plasmashell[3005]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Aug 27 10:30:04 gabe-pc kwin_x11[2952]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52905, resource id: 10485927, major code: 15 (QueryTree), minor code: 0
sudo dmesg -l err,warn,emerg,alert
[ 0.574879] #7 #8 #9 #10 #11
[ 3.158291] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 4.052716] systemd[1]: Configuration file /etc/systemd/system/piavpn.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.402784] usb 3-1.2: config 1 interface 0 altsetting 0 endpoint 0x83 has an invalid bInterval 32, changing to 9
[ 5.104645] nvidia: loading out-of-tree module taints kernel.
[ 5.104654] nvidia: module license 'NVIDIA' taints kernel.
[ 5.104655] Disabling lock debugging due to kernel taint
[ 5.155444] EXT4-fs (sdb3): warning: mounting fs with errors, running e2fsck is recommended
[ 5.192747] kvm: disabled by bios
[ 5.204664] usb 3-1.2: Warning! Unlikely big volume range (=5120), cval->res is probably wrong.
[ 5.204668] usb 3-1.2: [5] FU [Mic Capture Volume] ch = 1, val = 7680/12800/1
[ 5.211613] usb 3-1.2: Failed to query (GET_INFO) UVC control 2 on unit 1: -32 (exp. 1).
[ 5.221642] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
[ 5.247997] kvm: disabled by bios
[ 5.385975] kvm: disabled by bios
[ 5.533757] kvm: disabled by bios
[ 5.667196] kvm: disabled by bios
[ 5.839335] kvm: disabled by bios
[ 5.851884] kauditd_printk_skb: 147 callbacks suppressed
[ 5.980202] kvm: disabled by bios
[ 5.990324] bFWReady == _FALSE call reset 8051...
[ 6.128600] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 6.136053] kvm: disabled by bios
[ 6.241645] kvm: disabled by bios
[ 6.337291] kvm: disabled by bios
[ 6.674473] sd 12:0:0:0: [sdd] No Caching mode page found
[ 6.674480] sd 12:0:0:0: [sdd] Assuming drive cache: write through
[ 6.828407] sd 13:0:0:0: [sde] No Caching mode page found
[ 6.828415] sd 13:0:0:0: [sde] Assuming drive cache: write through
[ 7.711638] ==> rtl8188e_iol_efuse_patch
[ 11.847956] kauditd_printk_skb: 1245 callbacks suppressed
[ 29.565380] usb 3-1.2: Failed to query (GET_DEF) UVC control 2 on unit 1: -32 (exp. 1).
[ 30.078279] ntfs3: Unknown parameter 'windows_names'
[ 30.102265] FAT-fs (sdb2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 30.102452] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 37.209929] kauditd_printk_skb: 24 callbacks suppressed
[ 61.534827] kauditd_printk_skb: 7 callbacks suppressed
