Hello, I’ve installed manjaro couple days ago on a fresh SSD. I also have windows installed on other disk, working prefectly fine for a long time. Problem is that manjaro freezes randomly with no obvious reason (I have to hard reboot to bring it back to life). It can happen right after boot, even several times in a row, as well as after several hours of normal work. System stops responding entierly, it’s not just graphics.
I tried to research the problem myself, even though I’m pretty new to linux, but with no success. It happens with or without some programms launched, some usb devices plugged in on not, on a new empty user, etc. What I tried to monitor:
journalctl
- it has errors, but mostly on boot. At the moment when freeze happens no errors there. Example of the erorrs:
-- Boot 1005f341ae4347209e46ce674bd3f61d --
янв 12 19:34:30 rocketman-manjaro kernel: x86/cpu: SGX disabled by BIOS.
янв 12 19:34:30 rocketman-manjaro kernel: sd 4:0:0:0: [sdb] No Caching mode page found
янв 12 19:34:30 rocketman-manjaro kernel: sd 4:0:0:0: [sdb] Assuming drive cache: write through
янв 12 19:34:30 rocketman-manjaro kernel: hid-generic 0003:0D8C:0134.0005: No inputs registered, leaving
янв 12 19:34:30 rocketman-manjaro kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x201] vs fed40080 f80
янв 12 19:34:30 rocketman-manjaro kernel: usb 1-6.1.1.3: 2:1: cannot set freq 48000 to ep 0x3
янв 12 19:43:26 rocketman-manjaro gdm-password][1148]: gkr-pam: unable to locate daemon control file
янв 12 19:43:29 rocketman-manjaro gdm-launch-environment][751]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
...skipping...
#1 0x00007f412042dbdb g_cond_wait_until (libglib-2.0.so.0 + 0xa2bdb)
#2 0x00007f41203ae7d3 n/a (libglib-2.0.so.0 + 0x237d3)
#3 0x00007f41203ae964 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23964)
#4 0x00007f41204109da n/a (libglib-2.0.so.0 + 0x859da)
#5 0x00007f412040dd51 n/a (libglib-2.0.so.0 + 0x82d51)
#6 0x00007f411eb13259 start_thread (libpthread.so.0 + 0x9259)
#7 0x00007f411f6015e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 811:
#0 0x00007f411f5f6b2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f4120433749 n/a (libglib-2.0.so.0 + 0xa8749)
#2 0x00007f41203dcc11 g_main_context_iteration (libglib-2.0.so.0 + 0x51c11)
#3 0x00007f41206e3ebe n/a (libdconfsettings.so + 0x5ebe)
#4 0x00007f412040dd51 n/a (libglib-2.0.so.0 + 0x82d51)
#5 0x00007f411eb13259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f411f6015e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 810:
#2 0x00007f41203deab3 g_main_loop_run (libglib-2.0.so.0 + 0x53ab3)
#3 0x00007f412061e598 n/a (libgio-2.0.so.0 + 0x103598)
Stack trace of thread 815:
#0 0x00007f411eb1f8ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007f411eb19270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
#2 0x00007f411cf886bc _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-78.so + 0x7736bc)
#3 0x00007f411cf88191 n/a (libmozjs-78.so + 0x773191)
#4 0x00007f411d1fe38b n/a (libmozjs-78.so + 0x9e938b)
Stack trace of thread 821:
янв 12 18:57:04 rocketman-manjaro sudo[4910]: work : a password is required ; TTY=pts/0 ; PWD=/home/work ; USER=root ; COMMAND=/sbin/file -s /dev/nvme1n1p3
янв 12 18:57:04 rocketman-manjaro sudo[4912]: work : a password is required ; TTY=pts/0 ; PWD=/home/work ; USER=root ; COMMAND=/sbin/file -s /dev/sda1
- I’ve read somewhere it could be a memory problem so I ran memtest86 - no errors.
- Thought maybe CPU throtling, so I opened system monitor, and
top
in terminal, and was waiting system to freeze to capture the moment. I have a photo but can’t upload as a new user. In short - cpu was not overloaded at all, most loaded core - 2%.
Also I did check a hash sum after downloading the manjaro image.
Myinxi --admin --verbosity=7 --filter --width
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=dc15ab2d-e390-4a7e-bd5d-3dd3dc7e7498 rw rootflags=subvol=@ quiet
cryptdevice=UUID=b64548c9-3187-44b1-85b5-0204796cef48:luks-b64548c9-3187-44b1-85b5-0204796cef48
root=/dev/mapper/luks-b64548c9-3187-44b1-85b5-0204796cef48 splash
apparmor=1 security=apparmor udev.log_priority=3 acpi_osi=linux nomodeet
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Desktop Mobo: ASUSTeK model: PRIME Z370-P v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0614
date: 03/22/2018
RAM: total: 15.56 GiB used: 2.98 GiB (19.1%)
RAM Report:
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4800 high: 4802 min/max: 800/4700:4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 4799 2: 4799 3: 4801
4: 4800 5: 4802 6: 4801 7: 4801 8: 4800 9: 4802 10: 4801 11: 4800 12: 4801
bogomips: 88824
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1e87
class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: Cambridge Silicon Radio REIYIN Bluetooth Audio WT04 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6.1.1.3:9
chip-ID: 0a12:1004 class-ID: 0300 serial: <filter>
Device-4: C-Media USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6.1.2:8
chip-ID: 0d8c:0134 class-ID: 0300
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: d000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: luks-b64548c9-3187-44b1-85b5-0204796cef48 maj-min: 254:0
type: LUKS dm: dm-0 size: 232.59 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 232.59 GiB
Local Storage: total: 1.6 TiB used: 23.74 GiB (1.4%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 37.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB model: USB FLASH DRIVE
size: 7.47 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1.0 scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
used: 23.73 GiB (10.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b64548c9-3187-44b1-85b5-0204796cef48 label: N/A
uuid: dc15ab2d-e390-4a7e-bd5d-3dd3dc7e7498
used: 716 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 1EB0-1F27
ID-3: /home raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
ID-4: /run/media/work/D918-FDA5 raw-size: 249 MiB size: 248.7 MiB (99.89%)
used: 7.3 MiB (3.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: D918-FDA5
ID-5: /swap raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
ID-6: /var/cache raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
ID-7: /var/log raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 499 MiB fs: ntfs
label: \xd0\x92\xd0\xbe\xd1\x81\xd1\x81\xd1\x82\xd0\xb0\xd0\xbd\xd0\xbe\xd0\xb2\xd0\xb8\xd1\x82\xd1\x8c
uuid: 3A24087D24083DFF
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 99 MiB fs: vfat label: N/A
uuid: 7A08-7373
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p4 maj-min: 259:7 size: 464.55 GiB fs: ntfs label: N/A
uuid: EAB40C22B40BF03D
ID-5: /dev/nvme1n1p5 maj-min: 259:8 size: 623 MiB fs: ntfs label: N/A
uuid: C6FE8ACAFE8AB1EB
ID-6: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-7: /dev/sda2 maj-min: 8:2 size: 931.5 GiB fs: ntfs label: SATA SSD
uuid: 1A6EF7846EF7574B
ID-8: /dev/sdb2 maj-min: 8:18 size: 249 MiB fs: vfat label: N/A
uuid: D919-3D9A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-6:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Hub-3: 1-6.1:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Hub-4: 1-6.1.1:7 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-6.1.1.3:9
info: Cambridge Silicon Radio REIYIN Bluetooth Audio WT04 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
speed: 12 Mb/s power: 96mA chip-ID: 0a12:1004 class-ID: 0300
serial: <filter>
Device-2: 1-6.1.1.4:10 info: USB HID GMMK Pro type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 320f:5044 class-ID: 0300
Device-3: 1-6.1.2:8 info: C-Media USB PnP Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300
Device-4: 1-6.3:6 info: Logitech USB Receiver type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c547 class-ID: 0300
Device-5: 1-12:3 info: Apacer Handy Steno/AH123 / Handy Steno 2.0/HT203
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1005:b113 class-ID: 0806
serial: <filter>
Device-6: 1-13:5 info: NZXT Kraken X type: HID driver: nzxt-kraken2,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 1e71:170e
Hub-5: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-6: 2-6:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 35 C
Fan Speeds (RPM): fan-1: 810 gpu: nvidia fan: 35%
Processes: 346 Uptime: 1h 5m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1226 pacman: 1213 lib: 307
flatpak: 0 snap: 13 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.11
