Realtek Network Adaptor
Hi, I held down Left Shift for the entirety of reboot twice and nothing came up. Is there a way I can do it differently?
oh you just need to tap it
(otherwise I guess we can edit the same grub file as before and change ‘hidden’ to ‘menu’ or something)
I’ll try that, I have a slight feeling its my HDMI being funky
Yeah, even tapping occasionally during startup didnt work. What now? Its not showing the node menu for some reason, goes from HP logo to sign-in,
this driver will work for your tp-link wifi adapter.
https://aur.archlinux.org/packages/rtl88x2bu-dkms-git
How do I install this? :smiley:
go to add/remove software and select preference and enable third party support. You will find it in AUR repo and install it.
I’m sorry, I’m new to Linux so I don’t know how to find the AUR repo, how do I do so?
Installed it, rebooted, still nothing :frowning:
sudo ip link set wlan0 up or sudo ifconfig wlan0 up
do the same for wlp2s0 interface
This bring their states up
First one went through but I don’t know if it did anything, second one pops up as “ifconfig: command not found”
As for wlp2s0, I just get “cannot find device: wlp2s0”
sudo ip link set wlan1 up
or whatever additional wifi interface is listed in ip link
This should enable your wifi adapter to see nearby wifi networks
Tried the results I get from running ip link, none of them work. Still nothing :frowning:
what does it say in ip link?
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp1s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
    link/ether 10:62:e5:58:32:b3 brd ff:ff:ff:ff:ff:ff
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DORMANT group default qlen 1000
    link/ether 90:32:4b:20:26:b3 brd ff:ff:ff:ff:ff:ff
4: enp0s20f0u1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 1000
    link/ether 16:3a:1a:e0:97:ed brd ff:ff:ff:ff:ff:ff
6: wlan1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DORMANT group default qlen 1000
    link/ether 98:48:27:60:c3:70 brd ff:ff:ff:ff:ff:ff
For funzies lets throw in
rfkill list
0: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
2: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
3: phy2: Wireless LAN
        Soft blocked: no
        Hard blocked: no
it may be your wifi signal is too weak to connect. Try a wifi quality tool LinSSID or move closer to your wifi access point
I’m not sure why that would the case, it worked fine in the past from where my laptop stays I don’t see why that would’ve changed
