Realtek 8821CE Wi-Fi card does not work out of the box in Manjaro
I have Manjaro KDE with the Linux 5.14 kernel; but regardless of any Linux OS in my laptop, I get no wireless Internet connection upon boot. My Wi-Fi works perfectly in Windows 10, but I have to connect an RJ45 Ethernet interface to connect to the Web in Manjaro.
Here is the configuration of my laptop (main system and Network), via Speccy. My ASUS E410MA uses the AW-CB304NF Wireless Network Card.
	spend after: (On AC Power)	30 min
	Suspend after: (On Battery Power)	15 min
	Screen saver	Disabled
Uptime
		Current Session
			Current Time	9/11/2021 11:14:52 AM
			Current Uptime	34,883 sec (0 d, 09 h, 41 m, 23 s)
			Last Boot Time	9/11/2021 1:33:29 AM
Services
TimeZone
	TimeZone	GMT -5:00 Hours
	Language	English (United States)
	Location	United States
	Format	English (United States)
	Currency	$
	Date Format	M/d/yyyy
	Time Format	h:mm:ss tt
Scheduler
	9/11/2021 11:42 AM;	MicrosoftEdgeUpdateTaskMachineUA
	9/12/2021 12:29 AM;	OneDrive Standalone Update Task-S-1-5-21-1590946533-1197935528-1295400654-1001
	9/12/2021 12:45 AM;	AsusSystemAnalysis_754F3273-0563-4F20-B12F-826510B07474
	9/12/2021 1:46 AM;	MicrosoftEdgeUpdateTaskMachineCore
	9/12/2021 3:12 AM;	MicrosoftEdgeUpdateTaskMachineCore1d6f9402f47dbc0
	9/12/2021 8:04 PM;	OneDrive Standalone Update Task-S-1-5-21-1590946533-1197935528-1295400654-500
	ASUS Optimization 36D18D69AFC3
	ASUS Update Checker 2.0
	CreateExplorerShellUnelevatedTask
	RtkAudUService64_BG
Network
	You are connected to the internet
	Connected through	Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC
	IP Address	192.168.0.103
	Subnet mask	255.255.255.0
	Gateway server	192.168.0.1
	Preferred DNS server	192.168.0.1
	DHCP	Enabled
	DHCP server	192.168.0.1
	External IP Address	24.228.164.44
	Adapter Type	IEEE 802.11 wireless
	NetBIOS over TCP/IP	Enabled via DHCP
	NETBIOS Node Type	Hybrid node
	Link Speed	0 Bps
		Computer Name
			NetBIOS Name	LAPTOP-Q2DERVP7
			DNS Name	LAPTOP-Q2DERVP7
			Membership	Part of workgroup
			Workgroup	WORKGROUP
		Remote Desktop
			Disabled
				Console
					State	Active
					Domain	LAPTOP-Q2DERVP7
		WinInet Info
			LAN Connection
			Local system uses a local area network to connect to the Internet
			Local system has RAS to connect to the Internet
		Wi-Fi Info
			Using native Wi-Fi API version	2
			Available access points count	38
				Wi-Fi ()
					SSID
					Frequency	2437000 kHz
					Channel Number	6
					Name	No name
					Signal Strength/Quality	100
					Security	Enabled
					State	The interface is connected to a network
					Dot11 Type	Infrastructure BSS network
					Network	Connectible
					Network Flags	There is a profile for this network
					Cipher Algorithm to be used when joining this network	AES-CCMP algorithm
					Default Auth used to join this network for the first time	802.11i RSNA algorithm that uses PSK
				Wi-Fi (AlticeWiFi)
					SSID	AlticeWiFi
					Frequency	5745000 kHz
					Channel Number	149
					Name	AlticeWiFi
					Security	Enabled
					Network	Connectible
					Default Auth used to join this network for the first time	802.11i Robust Security Network Association (RSNA) algorithm (WPA2 is one such algorithm)
				Wi-Fi (Bless Lucc)
					SSID	Bless Lucc
					Frequency	5785000 kHz
					Channel Number	157
					Name	Bless Lucc
					Security	Enabled
					Network	Connectible
				Wi-Fi (C1C7E4)
					SSID	C1C7E4
					Channel Number	6
					Name	C1C7E4
					Signal Strength/Quality	85
					Security	Enabled
					Network	Connectible
				Wi-Fi (C1C7E4_5G)
					SSID	C1C7E4_5G
					Channel Number	149
					Name	C1C7E4_5G
					Signal Strength/Quality	40
					Security	Enabled
					Network	Connectible
				Wi-Fi (DIRECT-6C-HP OfficeJet Pro 6970)
					SSID	DIRECT-6C-HP OfficeJet Pro 6970
					Frequency	2412000 kHz
					Channel Number	1
					Name	DIRECT-6C-HP OfficeJet Pro 6970
					Security	Enabled
					Network	Connectible
				Wi-Fi (DIRECT-D3-HP OfficeJet Pro 8030)
					SSID	DIRECT-D3-HP OfficeJet Pro 8030
					Channel Number	6
					Name	DIRECT-D3-HP OfficeJet Pro 8030
					Signal Strength/Quality	25
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-4RtD3)
					SSID	Fios-4RtD3
					Channel Number	1
					Name	Fios-4RtD3
					Signal Strength/Quality	45
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-8c7QM)
					SSID	Fios-8c7QM
					Channel Number	6
					Name	Fios-8c7QM
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-CXt4D)
					SSID	Fios-CXt4D
					Channel Number	6
					Name	Fios-CXt4D
					Signal Strength/Quality	12
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-Hf6Ry)
					SSID	Fios-Hf6Ry
					Frequency	2462000 kHz
					Channel Number	11
					Name	Fios-Hf6Ry
					Signal Strength/Quality	0
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-Jk3MF)
					SSID	Fios-Jk3MF
					Channel Number	6
					Name	Fios-Jk3MF
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-S3JqH)
					SSID	Fios-S3JqH
					Channel Number	11
					Name	Fios-S3JqH
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-XPACM)
					SSID	Fios-XPACM
					Channel Number	6
					Name	Fios-XPACM
					Signal Strength/Quality	14
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-XPACM-5G)
					SSID	Fios-XPACM-5G
					Frequency	5180000 kHz
					Channel Number	36
					Name	Fios-XPACM-5G
					Signal Strength/Quality	30
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-Z6Rvd)
					SSID	Fios-Z6Rvd
					Frequency	5805000 kHz
					Channel Number	161
					Name	Fios-Z6Rvd
					Signal Strength/Quality	35
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-hfKX3)
					SSID	Fios-hfKX3
					Channel Number	11
					Name	Fios-hfKX3
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fios-q8DR2)
					SSID	Fios-q8DR2
					Channel Number	1
					Name	Fios-q8DR2
					Security	Enabled
					Network	Connectible
				Wi-Fi (Fodera Mewd)
					SSID	Fodera Mewd
					Channel Number	6
					Name	Fodera Mewd
					Signal Strength/Quality	15
					Security	Enabled
					Network	Connectible
				Wi-Fi (HP-Print-3A-Photosmart 5520)
					SSID	HP-Print-3A-Photosmart 5520
					Frequency	2417000 kHz
					Channel Number	2
					Name	HP-Print-3A-Photosmart 5520
					Security	Enabled
					Network	Connectible
				Wi-Fi (JSPCJ)
					SSID	JSPCJ
					Channel Number	6
					Name	JSPCJ
					Signal Strength/Quality	55
					Security	Enabled
					Network	Connectible
				Wi-Fi (Lavender Sunflower)
					SSID	Lavender Sunflower
					Frequency	5300000 kHz
					Channel Number	60
					Name	Lavender Sunflower
					Security	Enabled
					Network	Connectible
				Wi-Fi (Linksys03590_5GHz)
					SSID	Linksys03590_5GHz
					Channel Number	36
					Name	Linksys03590_5GHz
					Security	Enabled
					Network	Connectible
				Wi-Fi (MyAltice 5f25a9)
					SSID	MyAltice 5f25a9
					Channel Number	11
					Name	MyAltice 5f25a9
					Security	Enabled
					Network	Connectible
				Wi-Fi (MyAltice aee4b7)
					SSID	MyAltice aee4b7
					Channel Number	149
					Name	MyAltice aee4b7
					Security	Enabled
					Network	Connectible
				Wi-Fi (MyAltice e5668c)
					SSID	MyAltice e5668c
					Channel Number	11
					Name	MyAltice e5668c
					Security	Enabled
					Network	Connectible
				Wi-Fi (PS4-14A3E6252006)
					SSID	PS4-14A3E6252006
					Channel Number	6
					Name	PS4-14A3E6252006
					Signal Strength/Quality	75
					Security	Enabled
					Network	Connectible
				Wi-Fi (TP-Link_D6FF)
					SSID	TP-Link_D6FF
					Frequency	2452000 kHz
					Channel Number	9
					Name	TP-Link_D6FF
					Security	Enabled
					Network	Connectible
				Wi-Fi (TP-Link_D6FF_5G)
					SSID	TP-Link_D6FF_5G
					Channel Number	149
					Name	TP-Link_D6FF_5G
					Security	Enabled
					Network	Connectible
					Network Flags	Currently Connected to this network
				Wi-Fi (WaterWorks)
					SSID	WaterWorks
					Frequency	5540000 kHz
					Channel Number	108
					Name	WaterWorks
					Security	Enabled
					Network	Connectible
				Wi-Fi (ea0592-5G)
					SSID	ea0592-5G
					Channel Number	161
					Name	ea0592-5G
					Security	Enabled
					Network	Connectible
				Wi-Fi (luigi)
					SSID	luigi
					Channel Number	2
					Name	luigi
					Security	Enabled
					Network	Connectible
				Wi-Fi (luigi_5g)
					SSID	luigi_5g
					Frequency	5240000 kHz
					Channel Number	48
					Name	luigi_5g
					Signal Strength/Quality	95
					Security	Enabled
					Network	Connectible
				Wi-Fi (luigi_EXT)
					SSID	luigi_EXT
					Channel Number	2
					Name	luigi_EXT
					Security	Enabled
					Network	Connectible
				Wi-Fi (optimumwifi)
					SSID	optimumwifi
					Channel Number	149
					Name	optimumwifi
					Security	Disabled
					Network	Connectible
					Cipher Algorithm to be used when joining this network	No Cipher algorithm is enabled/supported
					Default Auth used to join this network for the first time	IEEE 802.11 Open System authentication algorithm
				Wi-Fi (optimumwifi_Passpoint)
					SSID	optimumwifi_Passpoint
					Channel Number	6
					Name	optimumwifi_Passpoint
					Security	Enabled
					Network	Connectible
				Wi-Fi (roslynevans)
					SSID	roslynevans
					Channel Number	1
					Name	roslynevans
					Security	Enabled
					Network	Connectible
				Wi-Fi (roslynevans_5G)
					SSID	roslynevans_5G
					Channel Number	149
					Name	roslynevans_5G
					Security	Enabled
					Network	Connectible
		WinHTTPInfo
			WinHTTPSessionProxyType	No proxy
			Session Proxy
			Session Proxy Bypass
			Connect Retries	5
			Connect Timeout (ms)	60,000
			HTTP Version	HTTP 1.1
			Max Connects Per 1.0 Servers	INFINITE
			Max Connects Per Servers	INFINITE
			Max HTTP automatic redirects	10
			Max HTTP status continue	10
			Send Timeout (ms)	30,000
			IEProxy Auto Detect	Yes
			IEProxy Auto Config
			IEProxy
			IEProxy Bypass
			Default Proxy Config Access Type	No proxy
			Default Config Proxy
			Default Config Proxy Bypass
		Sharing and Discovery
			Network Discovery	Enabled
			File and Printer Sharing	Enabled
			File and printer sharing service	Enabled
			Simple File Sharing	Enabled
			Administrative Shares	Enabled
			Network access: Sharing and security model for local accounts	Classic - local users authenticate as themselves
		Adapters List
				Enabled
						Bluetooth Device (Personal Area Network)
							Connection Name	Bluetooth Network Connection
							DHCP enabled	Yes
							MAC Address	D8-C0-A6-81-D0-54
							Connection Name	Wi-Fi
							NetBIOS over TCPIP	Yes
							DHCP enabled	Yes
							MAC Address	D8-C0-A6-81-D0-55
							DHCP	192.168.0.1
							DNS Server	192.168.0.1
						VMware Virtual Ethernet Adapter for VMnet1
							Connection Name	VMware Network Adapter VMnet1
							DHCP enabled	Yes
							MAC Address	00-50-56-C0-00-01
							IP Address	192.168.220.1
							DHCP	192.168.220.254
						VMware Virtual Ethernet Adapter for VMnet8
							Connection Name	VMware Network Adapter VMnet8
							DHCP enabled	Yes
							MAC Address	00-50-56-C0-00-08
							IP Address	192.168.253.1
							DHCP	192.168.253.254
				Disabled
						AVG TAP Adapter v3
							Connection Name	Secure VPN
		Network Shares
			No network shares
		Current TCP Connections
				AsusLinkNear.exe (7424)
				AVGSvc.exe (3788)
				C:\Program Files\Mozilla Firefox\firefox.exe (11384)
				C:\Program Files\Mozilla Firefox\firefox.exe (13044)
				C:\Program Files\Mozilla Firefox\firefox.exe (13324)
				C:\Program Files\Mozilla Firefox\firefox.exe (1464)
				C:\Program Files\Mozilla Firefox\firefox.exe (14716)
				C:\Program Files\Mozilla Firefox\firefox.exe (7172)
				C:\Program Files\Mozilla Firefox\firefox.exe (7840)
				C:\Program Files\WindowsApps\Microsoft.WindowsStore_12107.1001.15.0_x64__8wekyb3d8bbwe\WinStore.App.exe (12244)
				C:\Users\cooky\AppData\Local\Microsoft\OneDrive\OneDrive.exe (4784)
				C:\Windows\ImmersiveControlPanel\SystemSettings.exe (15064)
				C:\Windows\System32\svchost.exe (11956)
				lsass.exe (784)
				OneApp.IGCC.WinService.exe (4344)
				services.exe (176)
				spoolsv.exe (3404)
				svchost.exe (1164)
				svchost.exe (1720)
				svchost.exe (1940)
				svchost.exe (6668)
				svchost.exe (8412)
				System Process
				System Process
				TuneupSvc.exe (7700)
				VpnSvc.exe (8292)
				wininit.exe (1012)
Should I post this information from within Manjaro? I’m posting this from within Windows.
You should post it from manjaro to, also check that fastboot is disabled in windows since that can block linux from using the wifi device.
Fast Boot has no effect. Whether enabled or disabled, my Wi-Fi won’t activate automatically. I didn’t have this problem with my Acer A314-21 or ASUS E402WAS laptops. My Wi-Fi would activate regardless of the OS that I boot. In my E410MA, it is restricted to Windows, and I wonder if the factory preset the network adapter that way, or I need to download a Wi-Fi driver for Manjaro.
Does the MSM have some drivers choices to install for the card?
From this page: If Manjaro did not install a wireless network card driver during installation, it can be installed here as well.
Searching the forum for the specific hardware provides this solution:
We’re working partially in the dark here, so:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
Sorry I’m late with my response. Lots of distractions around.
Here is the configuration of my system from my terminal…
[cookymonzta@LAPTOP-Q2DERVP7 ~]$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  root=UUID=5450cc84-0678-4dcc-ac22-dbcad11fb80a rw quiet apparmor=1
  security=apparmor resume=UUID=b1b31cb3-8ed9-4b72-8fd9-5614abb6dfbe
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: VivoBook_ASUS Laptop E410MA_E410MA
  v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: E410MA v: 1.0 serial: <filter>
  UEFI: American Megatrends v: E410MA.306 date: 05/27/2021
  ID-1: BAT0 charge: 29.0 Wh (83.8%) condition: 34.6/42.1 Wh (82.3%)
  volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Charging
  RAM: total: 3.66 GiB used: 954.5 MiB (25.4%)
  Info: Quad Core model: Intel Pentium Silver N5030 bits: 64 type: MCP
  arch: Goldmont Plus family: 6 model-id: 7A (122) stepping: 8 microcode: 1A
  cache: L2: 4 MiB bogomips: 8756
  Speed: 796 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 796 2: 2549
  3: 2323 4: 1440
  Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
  arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
  flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
  lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl
  nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts
  rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd
  sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
  tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid x2apic xgetbv1
  xsave xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel GeminiLake [UHD Graphics 605] vendor: ASUSTeK driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:3184 class-ID: 0300
  Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 13d3:5a11 class-ID: 0e02
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
  diag: 354mm (13.9")
  OpenGL: renderer: Mesa Intel UHD Graphics 605 (GLK 3) v: 4.6 Mesa 21.2.1
  direct render: Yes
  Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
  vendor: ASUSTeK driver: snd_hda_intel v: kernel
  alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
  chip-ID: 8086:3198 class-ID: 0403
  Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.34 running: no
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
  vendor: AzureWave driver: N/A modules: rtw88_8821ce port: e000
  bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 1-4:2 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
  Local Storage: total: 7.85 TiB used: 11.14 GiB (0.1%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: DA4128
  size: 116.48 GiB block-size: physical: 512 B logical: 512 B type: SSD
  serial: <filter> rev: 0x8 scheme: GPT
  SMART Message: Unknown smartctl error. Unable to generate data.
  ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Inland model: NVMe SSD 256GB
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: T1202A0 temp: 39.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABB400 size: 7.28 TiB
  block-size: physical: 4096 B logical: 512 B type: HDD rpm: 5400
  serial: <filter> scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 type: USB model: Multiple Card Reader
  size: 232.96 GiB block-size: physical: 512 B logical: 512 B type: N/A
  serial: <filter> rev: 1.00
  ID-1: / raw-size: 230.1 GiB size: 225.43 GiB (97.97%) used: 11.13 GiB (4.9%)
  fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  uuid: 5450cc84-0678-4dcc-ac22-dbcad11fb80a
  used: 8.3 MiB (2.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: NO_LABEL uuid: 2840-78F6
  ID-1: swap-1 type: partition size: 8.07 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
  uuid: b1b31cb3-8ed9-4b72-8fd9-5614abb6dfbe
  ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 260 MiB fs: vfat label: SYSTEM
  uuid: B00F-0DF5
  ID-2: /dev/mmcblk0p2 maj-min: 179:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-3: /dev/mmcblk0p3 maj-min: 179:3 size: 115.18 GiB fs: ntfs label: OS
  uuid: C8CC127BCC1263CA
  ID-4: /dev/mmcblk0p4 maj-min: 179:4 size: 1.03 GiB fs: ntfs label: RECOVERY
  uuid: 40740CC9740CC41E
  ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-6: /dev/sda2 maj-min: 8:2 size: 7.28 TiB fs: ntfs label: General Storage
  uuid: 6622466822463CF5
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
  Device-1: 1-4:2 info: IMC Networks Bluetooth Radio type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
  Device-2: 1-5:3 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
  Device-3: 1-6:4 info: Alcor Micro Multi Flash Reader type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
  chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 7 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-6:2 info: ASMedia ASM1352R-Volume type: Mass Storage driver: uas
  interfaces: 1 rev: 3.1 speed: 5 Gb/s chip-ID: 174c:1352 class-ID: 0806
  serial: <filter>
  System Temperatures: cpu: 35.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 182 Uptime: 5m wakeups: 1 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1195 lib: 328 flatpak: 0 Shell: Bash
  v: 5.1.8 running-in: yakuake inxi: 3.3.06
Again, it seems that ASUS did not supply a universal hardware driver for this laptop (unlike the one in their E402WA laptop), and the driver that was supplied will only run in Windows. It won’t even run in my UEFI. To upgrade my BIOS, I have to use Windows Update or the ASUS hardware/software updater in Windows.
As I feared, no driver loaded, so go to hanzel’s post, follow ris recommendations and if they work out, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
Didn’t work. I used this procedure…
sudo pacman -Syyu
sudo pacman -S dkms linux514-headers
pamac build rtl8821ce-dkms-git
…And yet, somehow, I don’t think it installed, and I don’t know why.
  udev.log_priority=3
  ID-1: BAT0 charge: 25.6 Wh (74.0%) condition: 34.6/42.1 Wh (82.3%)
  status: Discharging
  RAM: total: 3.66 GiB used: 1.01 GiB (27.5%)
  Speed: 952 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 952 2: 2110
  3: 2206 4: 2242
  diag: 354mm (13.9")
  direct render: Yes
  Local Storage: total: 587.92 GiB used: 11.98 GiB (2.0%)
  ID-3: /dev/sda maj-min: 8:0 type: USB model: Multiple Card Reader
  ID-1: / raw-size: 230.1 GiB size: 225.43 GiB (97.97%) used: 11.88 GiB (5.3%)
  ID-3: /run/media/cookymonzta/VM raw-size: 232.96 GiB
  size: 232.96 GiB (100.00%) used: 93.6 MiB (0.0%) fs: ntfs dev: /dev/sda
  maj-min: 8:0 label: VM uuid: F6E2F830E2F7F32B
  uuid: B00F-0DF5
  System Temperatures: cpu: 45.0 C mobo: N/A
  Processes: 195 Uptime: 3m wakeups: 1 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1214 lib: 329 flatpak: 0
  Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
What is “Try enabling dig”, and where do I go to apply that procedure?
  1. There is no output from your build process, so we cannot see what went wrong. :frowning:
  2. Did you read the entire thread, or just the solution?
:thinking:
The output of those commands would give some clues, please provide them so we can see what is happening on your end.
inxi tries to list your WAN IP. Since it does not find something to work with it suggest some avenues to explore to fix this, for the issue with the wifi card this is not relevant. Dig is a flexible tool for interrogating DNS name servers.
Edit: According to the AUR comments there might be a issue with a driver from the kernel that might be loaded and failing. I’m not the person to help you start fixing that tho. Please blame system assemblers for putting together systems with poor driver support for your troubles :stuck_out_tongue:
Finally, it works!
I tried this…
pamac update -a
…Then I tried this…
I think it attempted to perform a downgrade of the driver version, and it couldn’t, and restored the latest version in my Linux build. After a restart, a bunch of Wi-Fi connections displayed, including my own.
  udev.log_priority=3
  ID-1: BAT0 charge: 31.2 Wh (90.2%) condition: 34.6/42.1 Wh (82.3%)
  status: Charging
  RAM: total: 3.66 GiB used: 1023.5 MiB (27.3%)
  Speed: 856 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 856 2: 905
  3: 2362 4: 816
  diag: 354mm (13.9")
  direct render: Yes
  vendor: AzureWave driver: rtl8821ce v: N/A modules: rtw88_8821ce,8821ce
  port: e000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
  Local Storage: total: 587.92 GiB used: 11.92 GiB (2.0%)
  ID-1: / raw-size: 230.1 GiB size: 225.43 GiB (97.97%) used: 11.82 GiB (5.2%)
  uuid: B00F-0DF5
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 195 Uptime: 2m wakeups: 1 Init: systemd v: 248 tool: systemctl
That looks alot better, congrats on fixing it :+1:
Just one thing before I let this thread close: How do I find out what Web site the package manager found this driver? I need to apply it to the operating systems in my VM, not all of which are Linux-based.
Not possible. That driver is for Linux. It comes from GitHub - tomaspinho/rtl8821ce which you could also see by viewing the PKGBUILD of the AUR package.
