My arch friend recommended me to make this post since he couldn’t figure it out.
Before I switched to Manjaro I had tried debian mint. It ran fine but it lacked the necessary drivers and my friend convinced me to switch to Manjaro. But during usb boot load I noticed there were significant lag which I initially thought was because of my flash drive but it persisted even after installation. Since then I’ve followed my friend’s recommendation of creating a swap, checking my ucode was up to date, updating my mesa driver, and changing to gnome, to no avail.
Significant lag(1 fps) has not been the only symptom, occasionally my screen has also glitched and froze. It has also in general been unresponsive with some application taking a lot of time to open. My computer is newly bought and my system info is this:
Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=a94d0934-25a5-4d93-9073-22d48001a6f0 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82UT v: Yoga Slim 7 Pro 14IAH7
serial: <superuser required> Chassis: type: 10 v: Yoga Slim 7 Pro 14IAH7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: KRCN10WW date: 08/02/2022
ID-1: BAT0 charge: 37.7 Wh (61.1%) condition: 61.7/61.0 Wh (101.2%)
volts: 15.7 min: 15.4 model: Sunwoda L19D4PH3 type: Li-poly serial: <filter>
status: discharging cycles: 3
RAM: total: 15.35 GiB used: 1.96 GiB (12.7%)
Info: model: 12th Gen Intel Core i5-12500H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2613 high: 3100 min/max: 400/4500:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 3100 2: 518 3: 3100
4: 3100 5: 520 6: 3100 7: 3100 8: 3100 9: 3100 10: 3100 11: 3100 12: 3100
13: 482 14: 3100 15: 3100 16: 3100 bogomips: 99568
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-8:2 chip-ID: 04f2:b756 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.00x18.74")
s-diag: 898mm (35.37")
Monitor-1: eDP-1 model: AU Optronics 0xc391 built: 2020 res: 2880x1800
hz: 90 dpi: 243 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
ratio: 16:10 modes: 2880x1800
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:3
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 465.76 GiB used: 15.16 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: CRTP1311 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 15.16 GiB (3.3%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a94d0934-25a5-4d93-9073-22d48001a6f0
used: 4.4 MiB (1.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: A4C1-748C
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 3 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-8:2 info: Chicony Integrated Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 3-10:3 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 301 Uptime: 15m wakeups: 191 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1277 libs: 352 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Thanks in advanced.
Edit:
Ok fixed! For future people who may run into the same issue as me, try this:
Open up the terminal and write
kate /etc/default/grub
or on manjaro gnome you can dosudo gedit /etc/default/grub
At GRUB_CMDLINE_LINUX_DEFAULT inside the quotes, add parameter
i915.enable_psr=0
. You add a parameter by adding a space at the end of the text inside the quotes. Don’t remove anything(Although I did it the first time with plasma and it seemed fine but just in case don’t) -
Save the file, update grub in terminal
sudo update-grub
and reboot. It should now work
I did this with both Manjaro Plasma and Gnome. For gnome it was extremely obnoxious since the screen flickered at every mouse movement but it fixed itself after changing the resolution to 1920x1200.
