Reaction emoji bubble slips under the post below
emoji
#1
Small post about an issue i just found regarding the newly added reaction emojis.
It is possible to know who used an emoji by hovering it. This makes a bubble appear.
But, if this bubble is too big, it slips under the post below.
#2
It’s a fairly minor cosmetic issue so I’ll look into it when I want something different to do. :slight_smile:
#3
This CSS corrects the problem:
.topic-body, .topic-avatar {
	position: static !important;
#4
It corrects this issue but creates some others (e.g. with the post management tools). :slightly_frowning_face:
#5
Apparently, some post-management tools (which I can’t see as an ordinary user) are positioned relative to the .topic-body.
Here’s another attempt:
.topic-body {
	overflow: visible !important;
.topic-avatar {
.post-menu-area {
	clear: both !important;
Any better?
#6
Hmm… I’m not seeing this any more without any changes. Can you (/anyone) verify you can still see this?
#7
I’m still seeing the problem, for example, when displaying the tooltip for the reaction icon in your previous post.
#8
OK, so the specific tooltip selector/rule is this one:
.post-retort__tooltip {
	opacity: 0;
	transition: .5s opacity;
	position: absolute;
	top: 30px;
	font-size: 12px;
	text-align: center;
	width: 140px;
	background: black;
	color: white;
	font-weight: bold;
	padding: 5px;
	border-radius: 5px;
	word-wrap: normal;
	left: 50%;
	transform: translate(-50%, 0);
	z-index: 1;
	pointer-events: none;
I imagine simply lowering the z-index will allow it to reliably appear on top. What’s that like?
#9
Adjusting the z-index of .post-retort__tooltip or of .topic-body has no effect. I think it’s because each .topic-body is below the subsequent .topic-body (same z-index, so HTML node order determines z-level). The .post-retort__tooltip is a child of a .topic-body, so it can’t appear above the subsequent .topic-body.
My second CSS attempt above works around this problem by repositioning some elements.
#10
OK here we go:
	width: 185px;
	padding: 3px;
	left: 10%;
	transform: unset;
.post-retort__tooltip::after {
	top: 0px;
	left: 5%;
That re-styles the tooltip so it’s a bit wider and to one side. It’s a bit better.
#11
Yes, it’s a bit better, but the tooltip is still cropped a bit at the bottom.
#12
Not if the user name is short :wink:
#13
And there can’t be multiple names attached to the same icon. :wink:
#14
Aaaaannnddd… with some slightly tighter padding it all fits neatly. It’s not quite as nicely spaced but it will do, and it doesn’t affect the rest of the layout.
