Build Output:
The build completes successfully, and calamares installs properly, but the live user (manjaro) doesn’t have any custom files from /etc/skel/.
Question:
Is this related to the new manjaro-live-setup in recent versions? It worked fine since Jan.
Are there configuration parameters I’m missing to enable /etc/skel/ population in the live environment?
Is there a documented workflow for properly including custom user files in the live ISO?
I’m aware that /etc/skel/ is typically used as a template for new user homes during installation, but I need custom configurations available in the live environment itself.
Any guidance on the proper way to include custom skeleton files in the live ISO would be appreciated.
Mod edit:- General tidy. No charge. @M78 – Please note that the forum uses markdown – whenever you type an # it is interpreted as HTML heading one (<h1>).
Note: Grave accent (or, backtick) characters are used.
For inlinecode or to show a single command:
please follow this simple example: code here.
For multi-linecommand output:
place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
use the </> button in the Compose window to achieve the same result.
What is a Quark?
What you are doing is technically correct - I have been using these features in many situations - and this has always worked.
In your iso-profiles folder - all content should be owned by your user
sudo chown $USER:$USER ~/iso-profiles
Quite possible
Not that I know of
There is very little documentation on the subject, what I know comes from hard work.
I would refer to the wiki - but it is so unstable that it has been disabled.
The ISO is a layered cake.
The layers are built using the Packages-<layer> package lists and the <layer>-overlay folders is used to inject customisation not available in any package.
The layers are built into separate folders configured by the chroots_dir in manjaro-tools.conf
# build dir where buildpkg or buildiso chroots are created
chroots_dir='/var/lib/manjaro-tools'
The build process has a -x argument which stops the process before generating the squash file systems.
This allows for editing the source file systems before building the ISO.
This can be used for various purposes e.g. to troubleshoot a stubborn configuration.
To resume the build session run with -zx arguments to build the file system. You can even use this for a repeated troubleshooting - where you tweak a given configuration - then regenerate the ISO - the script will know rebuild the part you touched without having to rebuild all file systems over and over.
I used the live-overlay quite extensively by injecting modified versions of the final scripts. I also work with trimmed down package lists and sometimes omitting mhwd completely.
