Hi guys, If I install manjaro-xfce-20.1-rc4-200816-linux58.iso. Will this automatically update to the final version on release or will I have to DL again.
Thanx
Thanx
It is the final version of the software itself ─ at least, it should be on par with the latest updates. It is however labeled as an RC because it may not be the “final” version of the install/live image.
By the way, welcome to the forum.
Thank you for the prompt reply Aragorn.
Manjaro is a curated rolling-release distribution, so if you keep your system up-to-date ─ be sure to subscribe to notifications for the #announcements category ─ then you never have to reinstall the system ever again.
