So, my system has been running a little “sub-optimal” for the past month. installing new software, either by using pacman, pamac or appimage makes kde unresponsive and the application launcher keeps updating itself for several seconds while being unreasonably slow, but it goes away eventually.
Disconnecting/Connecting from the network (System Settings > Connections) also causes kde to become unresponsive for a few seconds.
Sometimes i get “Filesystem mounted at ‘/’ is not responding” and booting times are awful. besides these issues the system runs fine as it was running before these issues began occurring.
Now, i’m running off a HDD but this looks like either bad sectors, file corruption or something like that. what i want i some help to diagnose and fix this issues, some logs:
[manjaro@manjaro ~]$ sudo fsck -vcf /dev/sda3
fsck from util-linux 2.36.2
e2fsck 1.46.2 (28-Feb-2021)
Checking for bad blocks (read-only test): done
/dev/sda3: Updating bad block inode.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/sda3: ***** FILE SYSTEM WAS MODIFIED *****
520937 inodes used (3.08%, out of 16900096)
2706 non-contiguous files (0.5%)
724 non-contiguous directories (0.1%)
# of inodes with ind/dind/tind blocks: 0/0/0
Extent depth histogram: 460642/359
57057528 blocks used (84.44%, out of 67569800)
0 bad blocks
9 large files
425480 regular files
32688 directories
0 character device files
0 block device files
1 fifo
7061 links
62758 symbolic links (59926 fast symbolic links)
1 socket
527989 files
systemd-analyze blame :
5.939s dev-sda3.device
3.723s udisks2.service
3.233s systemd-journal-flush.service
2.893s systemd-random-seed.service
2.892s systemd-sysusers.service
1.563s ldconfig.service
1.248s upower.service
621ms systemd-modules-load.service
613ms apparmor.service
481ms user@1000.service
468ms cups.service
326ms systemd-tmpfiles-clean.service
318ms systemd-tmpfiles-setup.service
310ms dev-disk-by\x2duuid-61bfbf7f\x2d2e60\x2d4c29\x2d994b\x2d162fa5eab2ef.swap
246ms modprobe@drm.service
210ms systemd-journal-catalog-update.service
162ms modprobe@fuse.service
143ms avahi-daemon.service
137ms systemd-update-done.service
134ms NetworkManager.service
128ms systemd-udevd.service
123ms systemd-logind.service
119ms systemd-journald.service
116ms systemd-update-utmp.service
88ms dev-hugepages.mount
88ms dev-mqueue.mount
87ms sys-kernel-debug.mount
86ms sys-kernel-tracing.mount
85ms systemd-udev-trigger.service
85ms kmod-static-nodes.service
84ms modprobe@configfs.service
83ms systemd-timesyncd.service
60ms systemd-remount-fs.service
59ms polkit.service
54ms systemd-binfmt.service
45ms proc-sys-fs-binfmt_misc.mount
33ms systemd-tmpfiles-setup-dev.service
31ms sys-kernel-config.mount
22ms user-runtime-dir@1000.service
22ms alsa-restore.service
10ms linux-module-cleanup.service
9ms snapd.apparmor.service
5ms systemd-user-sessions.service
4ms tmp.mount
4ms systemd-sysctl.service
4ms rtkit-daemon.service
2ms sys-fs-fuse-connections.mount
systemd-analyze critical-chain :
graphical.target @11.010s
└─sddm.service @11.009s
└─systemd-user-sessions.service @11.001s +5ms
└─network.target @10.996s
└─NetworkManager.service @10.860s +134ms
└─dbus.service @10.854s
└─basic.target @10.844s
└─sockets.target @10.844s
└─dbus.socket @10.844s
└─sysinit.target @10.801s
└─systemd-update-done.service @10.663s +137ms
└─ldconfig.service @9.097s +1.563s
└─local-fs.target @9.095s
└─tmp.mount @9.091s +4ms
└─swap.target @9.089s
└─dev-disk-by\x2duuid-61bfbf7f\x2d2e60\x2d4c29\x2d994b\x2d162fa5eab2ef.swap @8.778s +310ms
└─dev-disk-by\x2duuid-61bfbf7f\x2d2e60\x2d4c29\x2d994b\x2d162fa5eab2ef.device @8.776s
journalctl -b -1 :
Sounds like your HDD is dying. Better make backups now while you can, and then get the thing replaced ASAP.
Fabby
30 August 2021 18:41
3
Do what @Aragorn said first:
Make a backup of your documents ASAP!
After doing that, provide the output to:
And please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
@Fabby @Aragorn Thanks for the heads up guys, but no important files are on the drive, what i actually need is to diagnose the state of the drive. otherwise I’m just giving up on trying to find what is happening.
btw i forgot to include that this happened after a unexpected shutdown (power went down) so it sounds more like file corruption.
[ian@ian-manjaro ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5222c916-df1a-4521-a528-7f3095a0d71a rw
init=/usr/bin/e4rat-lite-preload radeon.cik_support=0 amdgpu.cik_support=1
radeon.si_support=0 amdgpu.si_support=1 usbhid.mousepoll=2 quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: M5A78L-M LX/BR v: Rev X.0x
serial: <filter> BIOS: American Megatrends v: 1101 date: 04/19/2013
RAM: total: 7.75 GiB used: 2.99 GiB (38.6%)
Info: 6-Core model: AMD FX-6300 bits: 64 type: MCP arch: Bulldozer
family: 15 (21) model-id: 2 stepping: 0 microcode: 6000852 cache: L2: 2 MiB
bogomips: 42208
Speed: 1406 MHz min/max: 1400/3500 MHz boost: enabled Core speeds (MHz):
1: 1406 2: 1406 3: 1406 4: 1406 5: 1406 6: 1405
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht hw_pstate
ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor msr mtrr
nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm
svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean vme vmmcall wdt
xop xsave
disabled, RSB filling
Device-1: AMD Tobago PRO [Radeon R7 360 / R9 360 OEM] vendor: XFX Pine
driver: amdgpu v: kernel alternate: radeon bus-ID: 01:00.0
chip-ID: 1002:665f class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 76 s-size: 426x341mm (16.8x13.4")
s-diag: 546mm (21.5")
Monitor-1: DVI-I-1 res: 1280x1024 hz: 60
OpenGL: renderer: AMD Radeon R7 300 Series (BONAIRE DRM 3.40.0
5.10.60-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASUSTeK M5A78L LE driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Tobago HDMI Audio [Radeon R7 360 / R9 360 OEM]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aac0 class-ID: 0403
Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: e800 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 847.7 GiB used: 675.32 GiB (79.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BC142
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: JC4B scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD1600AAJS-00L7A0 size: 149.05 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 3E01
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD25 00BEVT-60ZCT1 WDC WD2500 size: 232.89 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> scheme: MBR
ID-1: / raw-size: 257.76 GiB size: 252.65 GiB (98.02%)
used: 203.77 GiB (80.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 5222c916-df1a-4521-a528-7f3095a0d71a
ID-2: /run/media/ian/0EB342184C40CCEB raw-size: 29.3 GiB
size: 29.3 GiB (100.00%) used: 15.81 GiB (54.0%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: N/A uuid: 0EB342184C40CCEB
ID-3: /run/media/ian/12A89049A8902CEB raw-size: 232.88 GiB
size: 232.88 GiB (100.00%) used: 217.07 GiB (93.2%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: N/A uuid: 12A89049A8902CEB
ID-4: /run/media/ian/8c0554b5-c319-4bfc-a007-c8d26e1e511f raw-size: 200 GiB
size: 195.8 GiB (97.90%) used: 147.39 GiB (75.3%) fs: ext4 dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 8c0554b5-c319-4bfc-a007-c8d26e1e511f
ID-5: /run/media/ian/b299298f-697d-44cc-a1a3-9d0455c845cd
raw-size: 119.75 GiB size: 117.31 GiB (97.96%) used: 91.21 GiB (77.8%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: b299298f-697d-44cc-a1a3-9d0455c845cd
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8 GiB used: 65.6 MiB (0.8%) priority: -2
dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 61bfbf7f-2e60-4c29-994b-162fa5eab2ef
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-3:4 info: HP HP Pocket Media Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 03f0:110c class-ID: 0806 serial: <filter>
Device-2: 1-4:5 info: Samsung Galaxy A5 (MTP)
type: Abstract (modem),CDC-Data driver: cdc_acm,usbfs interfaces: 5 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 04e8:6860 class-ID: 0a00
serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Device-1: 3-1:2 info: China Resource Semico USB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:4b81 class-ID: 0301
Device-2: 3-2:3 info: USB OPTICAL MOUSE type: Mouse,Keyboard
power: 100mA chip-ID: 4e53:5406 class-ID: 0301
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 30.0 C mobo: 29.0 C gpu: amdgpu temp: 30.0 C
Fan Speeds (RPM): cpu: 2800 case-1: 3358
Power: 12v: 11.88 5v: N/A 3.3v: 3.36 vbat: N/A gpu: amdgpu watts: 7.20
Processes: 235 Uptime: 9h 42m wakeups: 0 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1443 lib: 400
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Use smartctl
as root to check the status of your drive, or use the Info Center to view the S.M.A.R.T. status.
Also check the output of…
sudo dmesg | less
… to see if the kernel reported hardware issues at boot.
[ian@ian-manjaro ~]$ sudo smartctl -a /dev/sda
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.60-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST500DM002-1BC142
Serial Number: W2A1DL5J
LU WWN Device Id: 5 000c50 03d95a986
Firmware Version: JC4B
User Capacity: 500.107.862.016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Aug 30 22:40:56 2021 -03
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 600) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 81) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 109 096 006 Pre-fail Always - 25096119
3 Spin_Up_Time 0x0003 100 100 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 096 096 020 Old_age Always - 4609
5 Reallocated_Sector_Ct 0x0033 059 059 036 Pre-fail Always - 1693
7 Seek_Error_Rate 0x000f 078 060 030 Pre-fail Always - 39244322457
9 Power_On_Hours 0x0032 099 011 000 Old_age Always - 1655
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 097 097 020 Old_age Always - 4019
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 177
188 Command_Timeout 0x0032 100 055 000 Old_age Always - 8 9 1057
189 High_Fly_Writes 0x003a 097 097 000 Old_age Always - 3
190 Airflow_Temperature_Cel 0x0022 067 052 045 Old_age Always - 33 (Min/Max 19/37)
194 Temperature_Celsius 0x0022 033 048 000 Old_age Always - 33 (0 14 0 0 0)
195 Hardware_ECC_Recovered 0x001a 034 026 000 Old_age Always - 25096119
197 Current_Pending_Sector 0x0012 100 083 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 083 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 112 000 Old_age Always - 454134
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 88111h+45m+05.805s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 4174838768
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1822199572
SMART Error Log Version: 1
ATA Error Count: 196 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 196 occurred at disk power-on lifetime: 17057 hours (710 days + 17 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 03 01 ff ff ff ef 00 01:56:35.961 READ DMA EXT
25 03 01 ff ff ff ef 00 01:56:32.339 READ DMA EXT
25 03 01 ff ff ff ef 00 01:56:28.717 READ DMA EXT
25 03 01 ff ff ff ef 00 01:56:25.095 READ DMA EXT
25 03 01 ff ff ff ef 00 01:56:21.457 READ DMA EXT
Error 195 occurred at disk power-on lifetime: 17057 hours (710 days + 17 hours)
25 03 01 ff ff ff ef 00 01:56:17.836 READ DMA EXT
Error 194 occurred at disk power-on lifetime: 17057 hours (710 days + 17 hours)
25 03 01 ff ff ff ef 00 01:56:14.214 READ DMA EXT
Error 193 occurred at disk power-on lifetime: 17057 hours (710 days + 17 hours)
25 03 01 ff ff ff ef 00 01:56:10.592 READ DMA EXT
Error 192 occurred at disk power-on lifetime: 17057 hours (710 days + 17 hours)
25 03 01 ff ff ff ef 00 01:56:06.992 READ DMA EXT
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
dmesg | less :
Fabby
31 August 2021 09:13
8
Multiple READ DMA EXT
errors on your drive, but all were at the same time (so probably the power loss)
I beg to differ: your OS on this drive!
So do the following:
Take a full Cold system backup using a CloneZilla Live USB to an external drive.
download, burn and Boot a Manjaro USB stick
Go to KDE partition Manager,
write down all partitions as they are
Write a new GPT
partition table on that disk
Create the exact same partition(s) as before
Write zeroes to all the new partitions
cat /dev/zero /dev/XdYN
where X, Y and N denominate your partition names
Why, oh why: this is taking so long!
You still have 59 spare sectors:
and the cat
will ensure that all sectors in the disk are written to so that the disk can swap out any bad sectors with the spare ones (36 have been used already)
Boot the CloneZilla Live USB again
Restore your Cold System backup
Disable Fast Startup
One of the most problematic settings that causes slow boot times in Windows 10 is the fast startup option. This is enabled by default, and is supposed to reduce startup time by pre-loading some boot information before your PC shuts off. (Note that while it applies to shutting down, restarting your computer isn’t affected by this feature.)
While the name sounds promising, it causes issues for a lot of people. Thus, it’s the first step you should try when you have slow boot problems.
To disable it,:
open System Settings
browse to System → Power & sleep .
On the right side of this screen, click Additional power settings to open the Power Options menu
My systemd-analyze-blame
is below:
System Analyzed Boot
468ms cups.service
59ms polkit.service
4ms tmp.mount
Thank you, i’m going to do that eventually (i need to shuffle some files around to make space), but i’m a little bit confused by the following:
so, basically don’t change anything? or should i wipe the disk? this particular disk partitioning scheme looks like this:
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 16779263 16777216 8G 83 Linux
/dev/sda2 16779264 436209663 419430400 200G 83 Linux
/dev/sda3 436209664 976768064 540558401 257,8G 83 Linux
Fabby
31 August 2021 16:58
11
Yes, restore as is…
(Full disclosure: In CloneZille, if you use Disk-to-disk or disk-to-image, it doesn’t really matter, but if you use partition-to-image it does matter! )
i was having this issue before i had windows installed.
