Hi,
THE ERROR MESSAGE
Here is the error message that I get when I boot on my machine:
Here is the messages that I have on the boot:
[FAILED] Failed to start File System Check on Root Device.
[ OK ] Finished Record System Boot/Shutdown in ...
[ OK ] Finished rebuild Journal Catalog.
[ OK ] Reached target sound card.
[ OK ] Started network time synchronisation.
[ OK ] Reached target Bluetooth Support.
[ OK ] Reached target system Time set.
[ OK ] Finished rebuild dynamic linked cache
Starting update is completed...
[ OK ] FInished update is completed.
[ OK ] Started Load/Save RF Kill switch status.
You are in emergency mode, after logging in type "journalctl -xb" to view system logs, "systemctl reboot" to reboot, "systemctl default" or "exit" to boot into default mode.
Cannot open access to console, the root account is locked.
See sulogin(S) man page for details,
Press Enter to continue.
I want to specify that this happened after I removed linux kernel v.5.4:
sudo mhwd-kernel -r linux54
sudo pacman -R linux54-headers
sudo pacman -R linux54-extramodules
And tried to remove v.5.10 but failed:
sudo mhwd-kernel -r linux510-rt
sudo pacman -R linux510-rt-headers
sudo pacman -R linux510-rt-extramodules
Here are all my installed kernels:
$ mhwd-kernel -li
Currently running: 5.12.19-1-MANJARO (linux512)
* linux510
* linux511
* linux512
* linux510-rt
* linux511-rt
I am unable to remove linux510-rt, linux511-rt and linux511 maybe it is linked with my problem?
INFOS ABOUT THE SYSTEM:
Here is infos about my system:
$ inxi -F
Host: manjaro Kernel: 5.12.19-1-MANJARO x86_64 bits: 64
Desktop: GNOME 40.3 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: B450 I AORUS PRO WIFI v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450 I AORUS PRO WIFI-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F51
date: 07/29/2020
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP cache:
L2: 4 MiB
Speed: 3169 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 3169 2: 2154
3: 3594 4: 2137 5: 2196 6: 2196 7: 2196 8: 2194 9: 4262 10: 2057 11: 2196
12: 2196 13: 2195 14: 2196 15: 3906 16: 2081
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] driver: amdgpu
v: kernel
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Display: wayland server: X.org 1.20.11 driver: loaded: amdgpu
note: n/a (using device driver) - try sudo/root
OpenGL: renderer: Radeon RX 5500 XT (NAVI14 DRM 3.40.0 5.12.19-1-MANJARO
LLVM 12.0.1)
v: 4.6 Mesa 21.1.5
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: Razer USA Kraken Tournament Edition type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Sound Server-3: PipeWire v: 0.3.32 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi
IF: wlp7s0 state: down mac: 7e:b9:88:dc:e5:20
Device-2: Intel I211 Gigabit Network driver: igb
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: 18:c0:4d:2d:6e:d9
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
Local Storage: total: 1.01 TiB used: 337.64 GiB (32.8%)
ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP510 size: 447.13 GiB
ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
ID-3: /dev/sdb type: USB vendor: Corsair model: Corsair Voyager SliderX2
ID-1: / size: 404.85 GiB used: 270.14 GiB (66.7%) fs: ext4 dev: /dev/dm-0
ID-2: /boot/efi size: 299.4 MiB used: 476 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 34.51 GiB used: 0 KiB (0.0%)
dev: /dev/dm-1
System Temperatures: cpu: 51.4 C mobo: N/A gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 412 Uptime: 16m Memory: 31.37 GiB used: 2.98 GiB (9.5%)
Shell: Zsh inxi: 3.3.06
The logs of the journal:
$ journalctl -p3 -b-1
-- Journal begins at Wed 2021-01-20 10:01:00 CET, ends at Thu 2021-07-29 08:09:58 CEST. --
Jul 28 19:19:02 manjaro systemd-fsck[432]: fsck failed with exit status 4.
Jul 28 19:19:02 manjaro systemd[1]: Failed to start File System Check on Root Device.
Jul 28 19:19:36 manjaro gdm-password][3329]: gkr-pam: unable to locate daemon control file
Jul 28 19:19:39 manjaro systemd[3344]: Failed to start Application launched by gnome-session-binary.
Jul 28 19:19:39 manjaro pulseaudio[3526]: Found duplicated D-Bus path for adapter /org/bluez/hci0
Jul 28 19:19:39 manjaro bluetoothd[3843]: Failed to set mode: Blocked through rfkill (0x12)
Jul 28 19:26:30 manjaro systemd-coredump[6081]: [🡕] Process 5821 (ledger-live-des) of user 1000 dumped core.
Stack trace of thread 5835:
#0 0x00007f513a055af3 n/a (libudev.so.1 + 0x12af3)
#1 0x00007f513a056729 udev_monitor_receive_device (libudev.so.1 + 0x13729)
#2 0x00007f513a076bf5 n/a (/tmp/.org.chromium.Chromium.QXKsRX + 0x7bf5)
#3 0x0000559a9888dc54 n/a (ledger-live-desktop + 0x18f1c54)
#4 0x00007f515fb58259 start_thread (libpthread.so.0 + 0x9259)
#5 0x00007f515e4b15e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 5821:
#0 0x00007f515fb648ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007f515fb59743 __pthread_clockjoin_ex (libpthread.so.0 + 0xa743)
#2 0x0000559a9889bf4e uv_thread_join (ledger-live-desktop + 0x18fff4e)
#3 0x0000559a9888d48b n/a (ledger-live-desktop + 0x18f148b)
#4 0x0000559a9889077c uv_library_shutdown (ledger-live-desktop + 0x18f477c)
#5 0x00007f51602071a4 _dl_fini (ld-linux-x86-64.so.2 + 0x101a4)
#6 0x00007f515e3f24a7 __run_exit_handlers (libc.so.6 + 0x3f4a7)
#7 0x00007f515e3f264e exit (libc.so.6 + 0x3f64e)
#8 0x0000559a9e6cab6f n/a (ledger-live-desktop + 0x772eb6f)
#9 0x0000559a99662931 n/a (ledger-live-desktop + 0x26c6931)
#10 0x0000559a99661e8b n/a (ledger-live-desktop + 0x26c5e8b)
#11 0x0000559a996614a1 n/a (ledger-live-desktop + 0x26c54a1)
#12 0x0000559a9a043078 n/a (ledger-live-desktop + 0x30a7078)
#13 0x0000559a99fd50f8 n/a (ledger-live-desktop + 0x30390f8)
#14 0x0000559a99fd50f8 n/a (ledger-live-desktop + 0x30390f8)
#15 0x00001d48000b7147 n/a (n/a + 0x0)
#16 0x00001d48001fa988 n/a (n/a + 0x0)
#17 0x0000559a99fcd558 n/a (ledger-live-desktop + 0x3031558)
#18 0x0000559a99fd50f8 n/a (ledger-live-desktop + 0x30390f8)
#19 0x0000559a99fd50f8 n/a (ledger-live-desktop + 0x30390f8)
#20 0x0000559a99fd2c1b n/a (ledger-live-desktop + 0x3036c1b)
#21 0x0000559a99fd29f8 n/a (ledger-live-desktop + 0x30369f8)
#22 0x0000559a9970e9ac n/a (ledger-live-desktop + 0x27729ac)
#23 0x0000559a9970de27 _ZN2v88internal9Execution4CallEPNS0_7IsolateENS0_6HandleINS0_6ObjectEEES6_iPS6_ (ledger-live-desktop + 0x2771e27)
#24 0x0000559a996125f9 _ZN2v88Function4CallENS_5LocalINS_7ContextEEENS1_INS_5ValueEEEiPS5_ (ledger-live-desktop + 0x26765f9)
#25 0x0000559a9e699d4a n/a (ledger-live-desktop + 0x76fdd4a)
#26 0x0000559a9e69a08a n/a (ledger-live-desktop + 0x76fe08a)
#27 0x0000559a9e6abb23 n/a (ledger-live-desktop + 0x770fb23)
#28 0x0000559a9e7cd936 n/a (ledger-live-desktop + 0x7831936)
#29 0x0000559a9e7cf711 n/a (ledger-live-desktop + 0x7833711)
#30 0x0000559a9e7d4330 n/a (ledger-live-desktop + 0x7838330)
#31 0x0000559a9889a322 n/a (ledger-live-desktop + 0x18fe322)
#32 0x0000559a9889f4f1 n/a (ledger-live-desktop + 0x19034f1)
#33 0x0000559a98891199 uv_run (ledger-live-desktop + 0x18f5199)
#34 0x0000559a98a00d7e n/a (ledger-live-desktop + 0x1a64d7e)
TEMPORAY SOLUTION:
My temporary solution is to simply press the Enter key and everything seems to work properly. But I want to understand and resolve this issue anyway.
Thank you for your help.
