Hello. Bit of a non techie user so apologies. Trying to follow some tutorials for setting up things on a Pi4 and when I try to enter the Pi config I get this error in the terminal. Is there an alternative cmd for Manjaro?
Thanks
Jason
That is a Pi OS command.
raspi-config is used by raspian. but there is a way to install it from the aur. you have to enable the aur-repositories and from there you can search for raspi-config or otherwise you can install it via git
https://aur.archlinux.org/packages/raspi-config-git/
Thanks so much. Installed via AUR. Excellent.
Appreciate your help.
Has anyone tried using it on Manjaro? I believe some of the raspi-config options make changes to configuration files. I am concerned it may not function as desired on a non-raspian distro.
Supposed to be limited on what you can do with it.
If one knew what he wants to do then might be able to provide help configuring.
Well, for kicks and grins, I installed it. I only use it to flip between network and USB boot, so it has limited use for me but an important one. Maybe now I can forget about the Raspian SD I keep around for that sole purpose. I’ll try making a Manjaro SD with this version of raspi-config and see if it works well for that purpose. The description does say (ArchlinuxArm fork), so maybe it will work on Manjaro without significant issue.
Edit: Nice, it seems to work well enough for what I need it to do. I now have a Manjaro minimal image on SD that can run both raspi-config and rpi-eeprom-update for new RPi4, fresh out of the box.
