Raspberry Pi Kernels (2.0)
Yes it’s chromium. My pi5 is overclocked to 2800.
My pi5 in config.txt:
# Pi5
over_voltage_delta=500000
arm_freq=2800
#gpu_freq=800    # Caused issues
usb_max_current_enable=1
# Pi5 only. Enable for faster read/writes for
# A2 SD cards. If card supports it you will see
# "mmc0: Command Queue Engine enabled" in dmesg
dtparam=sd_cqe
One window showing cpu usage with htop.
One window compiling a kernel at the same time running the aquarium test page.
The other window showing scx service started.
Been making preparations today to do so as a test for people. I will also have to push my scx-scheds-git package also.
Yeah i recognised htop. You know if you are making a movie about hackers, that is what you put on the monitors :smile:
So you are 400mhz faster then me, and my fps is around 55-57 so i guess it makes sense. I can’t overclock because i am on 15watts. It probably can’t take it.
I thought it would sense a low powered PSU and cut the cpu back. Really I am surprised you have not run into some other things due to low power.
scx_lavd update:
Fetch active profile from power-profiles-daemon dbus interface when using autopower.
I refuse to buy their ■■■■■■ ass power adapter :slight_smile:
Being new I search for best setup and get different opinions. Following the cachyos forum they seem to settle on this:
● scx.service - Start scx_scheduler
     Loaded: loaded (/usr/lib/systemd/system/scx.service; enabled; preset: disabled)
     Active: active (running) since Mon 2024-12-02 09:58:30 CST; 7min ago
 Invocation: cb5e1ca8b08041558bd7e835b1aa58cb
   Main PID: 500469 (scx_lavd)
      Tasks: 4 (limit: 9025)
        CPU: 903ms
     CGroup: /system.slice/scx.service
             └─500469 scx_lavd --performance --no-core-compaction
Dec 02 09:58:30 jellyfin systemd[1]: Started Start scx_scheduler.
Dec 02 09:58:31 jellyfin bash[500469]: 15:58:31 [INFO] scx_lavd scheduler is initialized (build ID: 1.0.7-gfa1e12ae-dirty aarch64-unknown-linux-gnu)
Dec 02 09:58:31 jellyfin bash[500469]: 15:58:31 [INFO] scx_lavd scheduler starts running.
Quote:
Basically, --performance is pretty straightforward, it make zero compromise on performance. --no-core-compaction disable core compaction which is a feature meant to save power, which is the opposite of “performance”.
Updated:
I noticed they fixed another aarch64 issue so I rebuilt sch-scheds-git and pushed it to unstable. I switched to commit 246fad9 (which is the fix) in my PKGBUILD as they had build failures in the latest commits above it here.
https://github.com/sched-ext/scx/commits
Cloning into 'scx'...
done.
==> Starting prepare()...
==> Starting pkgver()...
Note: switching to '246fad9aad90aabc212347a0a97af57874ed0930'.
HEAD is now at 246fad9a vmlinux: Increase cpumask size in vmlinux.h for all arch
==> Updated version: scx-scheds-git 1.0.6.r262.g246fad9a-1
==> Starting build()...
what is raspi-firmware PiOS package?
PiOS 6.6.62 set NUMA option and start test, but won’t work on MarjaroArm 6.6.12(numa added).
It has various files in /boot and some wifi firmware files. You should be up to date with them all. I have no idea what a start test is and what you are talking about what won’t work.
Added:
According to this you need to flash the eeprom with the beta image. Did you do that? Or it also looks like you can just add numa=fake=3 (for pi4) in cmdline.txt. For my pi5 after rebooting:
[ray@jellyfin ~]$ dmesg | grep -i numa
[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000001ffffffff]
[    0.000000] NUMA: Initialized distance table, cnt=1
[    0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=D8:3A:DD:BB:67:3A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  root=PARTUUID=cb41f4dc-03 rw rootwait console=ttyAMA10,115200 console=tty0 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 usbhid.mousepoll=8 audit=0 cgroup_enable=memory psi=1 delayacct lsm=landlock,lockdown,yama,integrity,apparmor,bpf numa=fake=1
[    0.000000] mempolicy: NUMA default policy overridden to 'interleave:0'1
https://forums.raspberrypi.com/viewtopic.php?t=378276
https://forums.raspberrypi.com/viewtopic.php?t=379745&start=50#p2273685
Looking at those tests make me wonder if numa is worth messing with.
Update:
I ran glmark2 in my xfce with kernel 6.12.1.
With scx-scheds disabled and numa disabled:      glmark2 Score:  390
With scx-scheds and numa enabled:                glmark2 Score:  394
With scx-scheds enabled and numa disabled:       glmark2 Score:  438
Will have to wait and see in 6.13 kernel if the new commits for scx-scheds to make sch-scheds more compatible with numa helps.
Tested with vulkan’s vkmark:
With scx-scheds disabled and numa disabled       vkmark score: 1015
With scx-scheds enabled and numa enabled         vkmark score: 1023
With scx-scheds enabled and numa disabled        vkmark score: 1394
no scx kernel to test, will wait 6.12.2 or 6.13-rc1.
I have no clue why upstream and RPi have been dragging their feet with upgrades the last couple of weeks. I built pi4 6.12.2 for you to test and also me to see if all of my changes were good. It seems to work booted on my pi5.
Linux jellyfin 6.12.1-2-MANJARO-RPI4 #1 SMP PREEMPT Wed Dec  4 18:42:09 UTC 2024 aarch64 GNU/Linux
     Active: active (running) since Wed 2024-12-04 12:54:17 CST; 1min 3s ago
 Invocation: 5a3ce6a8629d4eff9a6e77ecfda47daf
   Main PID: 922 (scx_lavd)
      Tasks: 4 (limit: 8897)
        CPU: 596ms
             └─922 scx_lavd --performance --no-core-compaction
Dec 04 12:54:17 jellyfin systemd[1]: Started Start scx_scheduler.
Dec 04 12:54:18 jellyfin bash[922]: 18:54:18 [INFO] scx_lavd scheduler is initialized (build ID: 1.0.7-g246fad9a-dirty aarch64-unknown-linux-gnu)
Dec 04 12:54:18 jellyfin bash[922]: 18:54:18 [INFO] scx_lavd scheduler starts running.
Download link:
https://gitlab.manjaro.org/manjaro-arm/packages/core/linux-rpi4-mainline/-/jobs/15212/artifacts/download
/etc/default/scx:
SCX_SCHEDULER=scx_lavd
SCX_FLAGS='--performance --no-core-compaction'
Pi4/test, freeze 5 secs randomly than alive.
ps, NUMA disabled.
Have not seen any freezes here. Been testing for 3 days. I have given up on NUMA. Seems things are not as good with it enabled. Might have to do with the fake in numa=fake=.
Change SCX_SCHEDULER= to another one to see if there is any change with your system you are using. I found some work better than others here. The scx_rustland was just horrible here with the fish tank. Some times what you are doing makes a differenc with different ones.
Might also get off that beta firmware on your eeprom also if you are on it.
rpi-eeprom 2711 is 2024-10-21-latest.
2712 is 2024-11-27-default.
so, where is beta?
Looks like you are where you should be. Did you install the scx-scheds-git in unstable. It had a fix for freezing due to low memory being allotted.
@Rip2 While doing today’s upgrade on unstable I ran into files being existing on my system. I had forgotten last week that I had built bpf and libbpf from the kernel v6.12 source tree under tools/bpf/bpftools trying to have the latest versions to get scx-scheds to compile before their fix. Today’s upgrade includes the latest libbpf 1.5.0 package and the linux-tools-meta package that is compiled against kernel v6.12 which has bpf v1.5.0.
Do an upgrade and reboot and see if it helps your issue.
packages updated no luck, scx_rusty.
Must be someting related to sway. Hooked up my pi400 and with xfce scx_rusty rustland and lavd and bpfland all works.
ha, xfce will wayland soon.
want a clean sway/wayland install, but no work img.
In preparing for adding sched_ext to the next v6.12.and 6.13 kernels I am making this post with some helpful info to get started.
If you want to test it modify /etc/default/scx with your desired SCX_SCHEDULER= and any SCX_FLAGS= you want. Right now
I am testing with these settings right now:
The list of Rust and C schedulers can be found here:
The flags can be obtained with each sheduler like this example:
scx_lavd -help
