Raspberry Pi Kernels (2.0)
in my case, read slower is like freeze but not dead.
maybe should build a f2fs img?
I would defiantly use a usb 3.0 stick plugged into the pi’s usb 3.0 port.
my usb stick is 3.2 printed in box.
so, maybe is Pi’s firmware issue?
should bought large sdcard not usb-stick :rofl:
edit,
ok, set quirks parameter to cmdline, no luck.
ADDED 01-04-2024:
These latest updated kernel packages has been pushed to the unstable branch when the mirrors sync.
@tartanpion 6by9 thinks he has ERROR Failed to allocate DLIST entry fixed here. Could you test and report your findings back to him?
https://github.com/raspberrypi/linux/issues/5674
linux-rpi4 6.1.70-2
linux-rpi4-headers 6.1.70-2
linux-rpi4-mainline 6.6.9-2
linux-rpi4-mainline-headers 6.6.9-2
linux-rpi5 6.1.70-2
linux-rpi5-headers 6.1.70-2
linux-rpi5-mainline 6.6.9-2
linux-rpi5-mainline-headers 6.6.9-2
Because of this bug, I went ahead and purchased a Pi 5. I felt a bit lonely dealing with this critical bug. Suddenly, many others started reporting the same issue, and 24 hours later, there’s a patch. The Pi 4 is now waiting on the shelf to be sold or repurposed as a pi-hole.
I have a new bug with the Pi 5: despite having the same hardware, my screen goes into sleep mode properly, but I can’t turn it back on using the mouse or keyboard. I’m forced to use the physical button on the screen, turning it off and on again manually. I have the same issue under PiOS.
Well it looks like it did not fix it. So back to the waiting game again.
where can check ‘drm/v3d: CPU jobs’ merge 6.8-drm-next or not?
in mesa side its already done.
Looks like it is there. The drivers/gpu/drm/v3d/Makefile Patch:
diff --git a/drivers/gpu/drm/v3d/Makefile b/drivers/gpu/drm/v3d/Makefile
index 4b21b20e4998..b7d673f1153b 100644
--- a/drivers/gpu/drm/v3d/Makefile
+++ b/drivers/gpu/drm/v3d/Makefile
@@ -12,7 +12,8 @@ v3d-y := \
 	v3d_perfmon.o \
 	v3d_trace_points.o \
 	v3d_sched.o \
-	v3d_sysfs.o
+	v3d_sysfs.o \
+	v3d_submit.o
https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/tree/drivers/gpu/drm/v3d/Makefile?h=next-20240105
ok, wait 6.8-rc1 :innocent:
Would this run Manjaro?
inxi -FazyG
  Kernel: 6.1.21+ armv6l bits: 32 compiler: gcc v: 10.2.1
  parameters: coherent_pool=1M snd_bcm2835.enable_headphones=0
  snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1
  bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1
  vc_mem.mem_base=0xec00000 vc_mem.mem_size=0x10000000 console=ttyAMA0,115200
  console=tty1 root=PARTUUID=a1ddfa5e-02 rootfstype=ext4 fsck.repair=yes
  rootwait quiet splash plymouth.ignore-serial-consoles
  cfg80211.ieee80211_regdom=AU
  Console: tty 0 DM: LightDM 1.26.0 Distro: Raspbian GNU/Linux 11 (bullseye)
  Type: ARM Device System: Raspberry Pi Model B Rev 1 details: BCM2835
  rev: 0003 serial: <filter>
  Info: Single Core model: ARMv6-compatible v6l variant: arm1176jzf-s bits: 32
  type: UP arch: v6l family: 7 model-id: N/A stepping: 7
  features: Use -f option to see features bogomips: 697
  Speed: 700 MHz max: 700 MHz Core speed (MHz): 1: 700
  Vulnerabilities: No CPU vulnerability/bugs data available.
  Device-1: bcm2708-fb driver: bcm2708_fb v: kernel bus ID: N/A
  chip ID: brcm:soc class ID: fb
  Device-2: bcm2835-hdmi driver: N/A bus ID: N/A chip ID: brcm:soc
  class ID: hdmi
  Display: server: X.org 1.20.11 driver: loaded: fbturbo tty: 102x51
  Message: Advanced graphics data unavailable in console. Try -G --display
  Device-1: bcm2835-hdmi driver: N/A bus ID: N/A chip ID: brcm:soc
  class ID: hdmi
  Sound Server: ALSA v: k6.1.21+
  Device-1: Microchip (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
  type: USB driver: smsc95xx bus ID: 1-1.1:3 chip ID: 0424:ec00 class ID: ff00
  IF: eth0 state: down mac: <filter>
  Device-2: Ralink RT5370 Wireless Adapter type: USB driver: rt2800usb
  bus ID: 1-1.3:4 chip ID: 148f:5370 class ID: 0000 serial: <filter>
  Local Storage: total: 28.97 GiB used: 3.35 GiB (11.6%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 model: SD32G size: 28.97 GiB block size:
  physical: 512 B logical: 512 B rotation: SSD serial: <filter> scheme: MBR
  ID-1: / raw size: 28.71 GiB size: 28.19 GiB (98.18%) used: 3.3 GiB (11.7%)
  fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2
  ID-2: /boot raw size: 256 MiB size: 255 MiB (99.60%) used: 50.4 MiB (19.8%)
  fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
  ID-1: swap-1 type: file size: 100 MiB used: 83.5 MiB (83.5%) priority: -2
  file: /var/swap
  System Temperatures: cpu: 44.9 C mobo: N/A
  Processes: 118 Uptime: 3m Memory: 240.1 MiB used: 160.1 MiB (66.7%)
  gpu: 64 MiB Init: systemd v: 247 runlevel: 5 target: graphical.target
  Compilers: gcc: 10.2.1 alt: 10 Packages: apt: 1427 lib: 753 Shell: Bash
  v: 5.1.4 running in: tty 0 (SSH) inxi: 3.3.01
Nope and neither will arch-arm. arch-arm supports armv7 and above. We only do armv8 64bit
The latest linux-rpi4/5 and rpi5-eeprom packages has been pushed to the unstable branch when the mirrors sync.
I have gone ahead and upgraded linux-rpi4/5 kernels from the rpi-6.1.y tree to the rpi-6.6.y LTS tree to make room for the 6.7 kernels in the linux-rpi4-mainline / linux-rpi5-mainline and the new 6.8-rc kernels when RPi updates their trees.
A couple of fixups for the pi5 with the rpi-eeprom package. See under 2024-01-05: Fix handling of FAT files without LFNs. here:
https://github.com/raspberrypi/rpi-eeprom/blob/master/firmware-2712/release-notes.md
linux-rpi4 6.6.10-1
linux-rpi4-headers 6.6.10-1
linux-rpi5 6.6.10-1
linux-rpi5-headers 6.6.10-1
rpi5-eeprom 20240108-1
remove [kms] hook, warning is gone.
When you order Pi5 did you also have your DHL parcel on hold by DHL?
Not on hold per say but held up several days by Germany customs due to large volumes they told me when I called the pi people.
DHL was a total nightmare for me. My pi5 spent several days everytime it reached different places.
The latest linux-rpi4/5 kernel packages has been pushed to the unstable branch when the mirrors sync. I am patiently waiting for them to upgrade their 6.7.y tree. There has been no updated since -rc6.
linux-rpi4 6.6.11-1
linux-rpi4-headers 6.6.11-1
linux-rpi5 6.6.11-1
linux-rpi5-headers 6.6.11-1
I see an error from the initramfs8 build when upgrading linux-rpi4-mainline, seems able to boot alright though
==> Using configuration file: '/etc/mkinitcpio.conf'
  -> -k 6.6.8-1-MANJARO-RPI4 -c /etc/mkinitcpio.conf -g /boot/initramfs8
==> Starting build: '6.6.8-1-MANJARO-RPI4'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [kms]
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs8'
==> WARNING: errors were encountered during the build. The image may not be complete.
error: command failed to execute correctly
It has been that way for a couple of months. Maybe they will fix it some day.
https://archlinuxarm.org/forum/viewtopic.php?f=15&t=16672
Or try this:
This is probably the reason.
https://www.tomshardware.com/raspberry-pi/raspberry-pi-is-now-manufacturing-70000-pi-5s-per-week-will-surge-to-90000-in-february
