I wanted to install Manjaro sway and after logo with the circle the monitor states input not supported. I have an older monitor right now 1080p 75hz aspect ratio 5:4 but i couldn’t find any solution to configure it I also mention that it’s a VGA so I use an HDMI adaptor. Every other OS worked out of the box. I know I don’t need to tweak boot/config.txt because I see what’s going on untill this stage. Is there a solution?
