Raspberry Pi 5 support for Manjaro when?
Hello and welcome to the Manjaro Community!
I think in this outlying case it’s justified.
ARM development is progressing, but since less of us use it compared to Intel/AMD, naturally the pace is a bit slower, at least for now.
However, usually it’s preferred to start a new topic and link to the old one, also providing system info etc. where necessary, as this will often result in more :eyes: on it. This may still be split to a new topic, you’ll have a notification if this happens so you can follow it. :wink:
Pretty much the only difference between the 2 images would be the kernel but I am assuming you have already upgraded the kernel on your pi4 and it is still ok. So maybe it may be an issue with the cm5. It uses a different kernel than the pi4. If it was me I would open a ticket here:
https://github.com/raspberrypi/linux/issues
The previous install was also on a rpi5 with the same hyperpixel screen. I hadn’t used it in a few weeks, so it wasn’t up-to-date. Unfortunately, I erased the NVMe so I can’t check what kernel was running on it.
On the new install (cm5, same DPI hyperpixel screen), I ran an upgrade and now the screen isn’t working anymore. I’ll open an issue on github.
Sounds like that is what you need to do. I do not have a cm5 or a hyperpixel screen. Our kernels always has RPi kernel configs as a base.
Added 2025-06-03:
Looks like some one using PiOS reported this and they are trying to fix it.
https://github.com/raspberrypi/linux/issues/6878
Looks like they think they have this fixed in kernel v6.12.31-1 I pushed to unstable today.
I’m facing the same issue on a CM5 with Hyperpixel Display (HackerryPi CM5).
Running Manjaro-ARM-gnome-rpi4-20250630.img works fine, after updating it is not booting anymore.
Any updates or workarounds on this?
