Are you saying it will not display anything or boot up showing text lines then halting.
If you get nothing at all something is wrong with your image
Imma try with 32 gb sd card see if it works my friend says his 16gb doesn’t work but his 64 did so maybe my 32 will
There are issues with some cards. Also some card readers do not do well with 32G and above sdcards.
Hey guys would it work if I resized the drive to fill manually?
Thanks for the tip @Darksky - this worked great!
I’ve been using Manjaro on Raspberry PI 4 all weekend, and it’s just fantastic.
Manjaro is awesome, and it pumps on Raspberry PI 4.
Nice work guys!
