I am booting the iso from a usb-stick, where ventoy is installed.
Tried the latest manjaro-iso of kde from april 21, the same error happens.
What can I do to install the manjaro-cinnamon desktop ?
franz@lmde5 ~> sudo inxi --admin --verbosity=7 --filter --no-host --width
[sudo] Passwort für franz:
Kernel: 5.10.0-21-amd64 x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10.0-21-amd64
root=UUID=ffe059e3-3bc1-4383-9970-b2a226f98227 ro quiet splash
Console: tty 0 wm: muffin DM: LightDM 1.26.0 Distro: LMDE 5 Elsie
base: Debian 11.2 bullseye
Type: Desktop System: Wortmann_AG product: TERRA_PC v: N/A serial: N/A
Chassis: Gigabyte Technology Co., Ltd. type: 3 serial: N/A
Mobo: Gigabyte model: H61M-S2PV serial: N/A UEFI: American Megatrends
v: FH WG date: 04/24/2013
RAM: total: 3.8 GiB used: 1.88 GiB (49.5%)
Array-1: capacity: 32 GiB slots: 2 EC: None max module size: 16 GiB
note: est.
Device-1: ChannelB-DIMM0 size: No Module Installed
Device-2: ChannelA-DIMM0 size: 4 GiB speed: 1333 MT/s type: DDR3
detail: synchronous bus width: 64 bits total: 64 bits manufacturer: 029E
part-no: CMX8GX3M2A1333C9 serial: N/A
Info: Dual Core model: Intel Core i3-3220 bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L1 cache: 64 KiB L2 cache: 3 MiB L3 cache: 2.9 MiB bogomips: 26341
Speed: 1640 MHz min/max: 1600/3300 MHz base/boost: 3300/7000 volts: 1.0 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1640 2: 1955 3: 1936 4: 1597
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs lahf_lm
lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp
rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
xtpr
Type: l1tf
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Redwood XT [Radeon HD 5670/5690/5730]
vendor: PC Partner Limited driver: radeon v: kernel bus ID: 01:00.0
chip ID: 1002:68d8 class ID: 0300
Display: server: X.Org 1.20.11 driver: loaded: ati,radeon
unloaded: fbdev,modesetting,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.0x12.5")
s-diag: 599mm (23.6")
Monitor-1: HDMI-0 res: 1920x1200 hz: 60 dpi: 103
size: 474x296mm (18.7x11.7") diag: 559mm (22")
OpenGL: renderer: AMD REDWOOD (DRM 2.50.0 / 5.10.0-21-amd64 LLVM 11.0.1)
v: 3.3 Mesa 20.3.5 compat-v: 3.1 direct render: Yes
vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20 class ID: 0403
Device-2: AMD Redwood HDMI Audio [Radeon HD 5000 Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aa60 class ID: 0403
Sound Server: ALSA v: k5.10.0-21-amd64
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168 class ID: 0200
Message: No Bluetooth data was found.
Local Storage: total: 704.24 GiB used: 249.3 GiB (35.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN256HMJP-00000
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: 100Q temp: 36 C scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: KC45 temp: 40 C scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224DB rev: SB00
dev-links: cdrom,cdrw,dvd,dvdrw
ID-1: / raw size: 35.33 GiB size: 34.48 GiB (97.59%) used: 10.34 GiB (30.0%)
fs: ext4 block size: 4096 B dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: ffe059e3-3bc1-4383-9970-b2a226f98227
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 56.5 MiB (58.8%) fs: vfat block size: 512 B dev: /dev/sda1
maj-min: 8:1 label: EFI uuid: C632-CBD5
ID-3: /mnt/DATA raw size: 404.06 GiB size: 396.65 GiB (98.17%)
used: 238.9 GiB (60.2%) fs: ext4 block size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: DATA uuid: bee41684-b15c-4f6f-8511-77ea6624ad21
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 6.84 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 40951ef9-753d-4128-9a7e-a8ec6628cfd5
ID-1: /dev/sda12 maj-min: 8:12 size: 515 MiB fs: ntfs label: N/A
uuid: DA5204CC5204AEF7
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 53.49 GiB fs: ntfs label: N/A
uuid: 5460449560447FAA
ID-4: /dev/sda4 maj-min: 8:4 size: 526 MiB fs: ntfs label: N/A
uuid: FEAC7D64AC7D17FB
ID-5: /dev/sda5 maj-min: 8:5 size: 40.52 GiB fs: ext4 label: N/A
uuid: db897649-4c09-400f-b64e-087f5285c9bc
ID-6: /dev/sda6 maj-min: 8:6 size: 28.31 GiB fs: ext4 label: Mint-LXDE
uuid: 70086c2b-dd71-4f51-a0ce-fc6b00840fe0
ID-7: /dev/sda7 maj-min: 8:7 size: 28.79 GiB fs: ext4 label: ROS-Plasma
uuid: 9bc5380e-6cb4-425b-9c72-a43a80304aaa
ID-8: /dev/sda9 maj-min: 8:9 size: 44.91 GiB fs: ext4 label: ROS-LXQt
uuid: e2afdfe0-c7df-42f7-8d2c-746283288d6c
ID-9: /dev/sdb3 maj-min: 8:19 size: 54.87 GiB fs: ext4 label: Mint-Cinnamon
uuid: 1cbd3ca6-fad2-4b57-a6ec-a1a2e482b7fa
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 8087:0024 class ID: 0900
Device-1: 1-1.1:3 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 10c4:8105 class ID: 0301
Device-2: 1-1.2:4 info: Chicony KU-0833 Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
chip ID: 04f2:0833 class ID: 0300
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 2-1.5:3 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 0424:2514 class ID: 0900
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 36.5 C
Processes: 213 Uptime: 9m wakeups: 0 Init: systemd v: 247 runlevel: 5
Compilers: gcc: 10.2.1 alt: 10 Packages: apt: 2132 lib: 1069 flatpak: 0
Shell: fish (sudo) v: 3.1.2 default: Bash v: 5.1.4
running in: gnome-terminal inxi: 3.3.01
franz@lmde5 ~>
