Hello,
I recently installed updates and when I rebooted, I got a black screen (did not reach the login screen). I tried rebooting again a few times: same result.
I searched for a solution on the forum. I booted up from a live Manjaro environment on a USB key and used chroot
to access my system.
I ran the following commands:
sudo pacman-mirrors -f 5
sudo pacman -Syyu
but that didn’t fix the problem when I rebooted.
I went back and I did some research and noticed that there’s a few commands that can help troubleshoot this problem. Below are the commands I ran and their respective output:
startx
_XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
_XSERVTransMakeAllCOTSServerListeners: server already running
(EE)
Fatal server error:
(EE) Cannot establish any listening sockets - Make sure an X server isn't already running(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
Invalid MIT-MAGIC-COOKIE-1 key
xinit: giving up
xinit: unable to connect to X server: Resource temporarily unavailable
xinit: server error
mhwd-kernel -li
Currently running: 6.1.11-1-MANJARO (linux61)
* linux61
mhwd -l
> 0000:01:00.0 (0300:10de:2504) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
mhwd -li
> Installed PCI configs:
inxi -Fyza
12System:
12Kernel 6.1.11-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 12.2.1
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2203 quiet systemd.show_status=1
splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
12Console N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
12Type Desktop 12Mobo Micro-Star 12model Z590 PRO WIFI (MS-7D09) 12v 1.0
12serial <filter> 12UEFI American Megatrends LLC. 12v 1.00 12date 01/14/2021
12CPU:
12Info 12model 11th Gen Intel Core i5-11600K 12socket U3E1 12bits 64 12type MT MCP
12arch Rocket Lake 12gen core 11 12level v4 12note check 12built 2021+
12process Intel 14nm 12family 6 12model-id 0xA7 (167) 12stepping 1 12microcode 0x56
12Topology 12cpus 1x 12cores 6 12tpc 2 12threads 12 12smt enabled 12cache 12L1 480 KiB
12desc d-6x48 KiB; i-6x32 KiB 12L2 3 MiB 12desc 6x512 KiB 12L3 12 MiB 12desc 1x12 MiB
12Speed (MHz) 12avg 4551 12high 4806 12min/max 800/4900 12base/boost 3900/8500
12scaling 12driver intel_pstate 12governor powersave 12volts 1.1 V 12ext-clock 100 MHz
12cores 121 4625 122 4603 123 4601 124 4680 125 4611 126 4366 127 4590 128 4600 129 4630
1210 3900 1211 4806 1212 4600 12bogomips 93924
12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
12Vulnerabilities
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12mitigation Clear CPU buffers; SMT vulnerable
12Type retbleed 12mitigation Enhanced IBRS
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
12Type spectre_v2 12mitigation Enhanced IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: SW sequence
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] 12vendor Gigabyte
12driver nouveau 12v kernel 12non-free 525.xx+ 12status current (as of 2023-02)
12arch Ampere 12code GAxxx 12process TSMC n7 (7nm) 12built 2020-22 12pcie 12gen 4
12speed 16 GT/s 12lanes 16 12ports 12active HDMI-A-2 12empty DP-1,DP-2,HDMI-A-1
12bus-ID 01:00.0 12chip-ID 10de:2504 12class-ID 0300
12Display 12server X.org 12v 1.21.1.7 12compositor kwin_x11 12driver 12gpu nouveau
12note X driver n/a 12tty 80x40
12Monitor-1 HDMI-A-2 12model LG (GoldStar) ULTRAGEAR 12serial <filter> 12built 2021
12res 1920x1080 12dpi 93 12gamma 1.2 12size 527x296mm (20.75x11.65")
12diag 604mm (23.8") 12ratio 16:9 12modes 12max 1920x1080 12min 640x480
12API OpenGL 12Message GL data unavailable in console for root.
12Audio:
12Device-1 Intel Tiger Lake-H HD Audio 12vendor Micro-Star MSI
12driver snd_hda_intel 12bus-ID 1-8:7 12v kernel 12bus-ID 00:1f.3 12chip-ID 046d:0a37
12chip-ID 8086:43c8 12class-ID 0300 12serial <filter> 12class-ID 0403
12Device-2 NVIDIA GA106 High Definition Audio 12vendor Gigabyte
12driver snd_hda_intel 12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16
12bus-ID 01:00.1 12chip-ID 10de:228e 12class-ID 0403
12Device-3 Logitech USB Headset H540 12type USB
12driver hid-generic,snd-usb-audio,usbhid
12Sound API ALSA 12v k6.1.11-1-MANJARO 12running yes
12Sound Server-1 JACK 12v 1.9.22 12running no
12Sound Server-2 PulseAudio 12v 16.1 12running yes
12Sound Server-3 PipeWire 12v 0.3.65 12running yes
12Network:
12Device-1 Intel Ethernet I225-V 12vendor Micro-Star MSI 12driver igc 12v kernel 12pcie
12gen 2 12speed 5 GT/s 12lanes 1 12port N/A 12bus-ID 04:00.0 12chip-ID 8086:15f3
12class-ID 0200
12IF enp4s0 12state down 12mac <filter>
12Device-2 Intel Wi-Fi 6 AX210/AX211/AX411 160MHz 12driver iwlwifi 12v kernel
12pcie 12gen 2 12speed 5 GT/s 12lanes 1 12bus-ID 05:00.0 12chip-ID 8086:2725
12class-ID 0280
12IF wlp5s0 12state up 12mac <filter>
12Bluetooth:
12Device-1 Intel AX210 Bluetooth 12type USB 12driver btusb 12v 0.8 12bus-ID 1-14:11
12chip-ID 8087:0032 12class-ID e001
12Report rfkill 12ID hci0 12rfk-id 0 12state up 12address see --recommends
12Drives:
12Local Storage 12total 983.68 GiB 12used 28.07 GiB (2.9%)
12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Intel 12model SSDPEKNW010T8
12size 953.87 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s
12lanes 4 12type SSD 12serial <filter> 12rev 004C 12temp 37.9 C
12SMART yes 12health PASSED 12on 205d 21h 12cycles 930
12read-units 15,522,518 [7.94 TB] 12written-units 15,808,397 [8.09 TB]
12ID-2 /dev/sda 12maj-min 8:0 12type USB 12vendor Lexar 12model USB Flash Drive
12size 29.81 GiB 12block-size 12physical 512 B 12logical 512 B 12type SSD
12serial <filter> 12rev 8.07
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition:
12ID-1 / 12raw-size 292.97 GiB 12size 287.31 GiB (98.07%) 12used 28.04 GiB (9.8%)
12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p5 12maj-min 259:5
12ID-2 /boot/efi 12raw-size 100 MiB 12size 96 MiB (96.00%) 12used 25.4 MiB (26.4%)
12fs vfat 12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1
12Swap:
12Alert No swap data was found.
12Sensors:
12System Temperatures 12cpu 36.0 C 12mobo N/A
12Fan Speeds (RPM) N/A
12Info:
12Processes 305 12Uptime 1h 40m 12wakeups 0 12Memory 15.52 GiB 12used 4 GiB (25.8%)
12Init systemd 12v 252 12default graphical 12tool systemctl 12Compilers 12gcc 12.2.1
12clang 15.0.7 12Packages 12pm pacman 12pkgs 1273 12libs 330 12tools pamac 12pm flatpak
12pkgs 0 12Client Unknown Client: systemd 12inxi 3.3.25
Any help would be appreciated. Thank you.
P.S. I’m not a Linux expert and I’ve been using Manjaro for over a month
