Raspberry Pi 3B stuck at boot
boot
#1
I’ve installed the latest Manjaro-ARM-lxqt-rpi2-18.10.zip on my Raspberry Pi 3B & updated it (which was around 450MB). But after updating, the Pi got stuck at boot with the following messages:
IMG_20190131_224438__01_20190131230306348
So I flashed the SD Card again (I’m using Etcher) to start from scratch & everything was fine. But after updating it got stuck at boot again with the same messages.
I’m sure there isn’t any problem with the voltage/power supply (as seen in the messages) because it works fine until the update. Also, the other distros work fine too.
#2
Try the new minimal image for rpi2 instead. That was built not long ago.
Or you can try the lxqt image again and ignore the linux-raspberrypi update.
#3
I know this might sound weird, but Manjaro ARM on the Rpi3 has been much easier to work with than the official editions on the X86 platform
