Hello! My bluetooth randomly stop! I have had this problem for several months and can’t solve it.When listening to music, the problem manifests itself as a sudden interruption of sound.
Laptop is MSI GF63Thin 11UD, Plasma 22, Kernel 515, using Pulseaudio. Sorry for my English and help me please.
inxi -Fza:
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=03393aca-55f7-4d41-972f-ecb45ea8f3e7 rw quiet splash
resume=UUID=4869e7ef-9a66-4bf1-80f6-cbc1220c74dc udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GF63 Thin 11UD v: REV:1.0
serial: Chassis: type: 10 serial:
Mobo: Micro-Star model: MS-16R6 v: REV:1.0 serial:
UEFI: American Megatrends LLC. v: E16R6IMS.10E date: 09/21/2022
ID-1: BAT1 charge: 49.6 Wh (100.0%) condition: 49.6/51.3 Wh (96.7%)
volts: 12.9 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: full
Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x42
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3533 high: 4167 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 4127 2: 2298 3: 3554
4: 4167 5: 2776 6: 3761 7: 3222 8: 4020 9: 3543 10: 3909 11: 3347 12: 3675
bogomips: 64536
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a68
class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 525.60.11
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a0 class-ID: 0302
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0xaf90 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel UHD Graphics (TGL GT1)
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF: wlo1 state: up mac:
vendor: Micro-Star MSI driver: N/A modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
bus-ID: 3-14:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.14 TiB used: 140.87 GiB (12.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3256B-AI1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: rev: EDFK0S03 temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: rev: 1002 scheme: GPT
ID-1: / raw-size: 222.55 GiB size: 218 GiB (97.95%) used: 109.7 GiB (50.3%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 301 Uptime: 1m wakeups: 1 Memory: 7.47 GiB used: 1.85 GiB (24.7%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 1298 pm: pacman pkgs: 1291
libs: 366 tools: pamac,yay pm: flatpak pkgs: 7 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
