This problem is happening randomly and can usually (temporarily) fixed by rebooting.
When the problem happens, the battery consumption is high (>10W with only kconsole opened, compared with normal <6W). And if I close the lid to put it into sleep, I can’t wake it up. I can only hold the power button and do a force shutdown.
According to my (limited) experiments, high battery consumption and failing to wake up from sleep are strongly related. There should be caused by one problem.
Two of powertop output when there is the problem (power est. is inaccurate):
The battery reports a discharge rate of 11.7 W
The energy consumed was 259 J
The estimated remaining time is 3 hours, 0 minutes
Summary: 540.8 wakeups/second, 0.0 GPU ops/seconds, 0.0 VFS ops/sec and 5.9% CPU use
Power est. Usage Events/s Category Description
4.70 W 5.1% Device Display backlight
126 mW 9.4 ms/s 63.4 Process [PID 1076] /usr/bin/plasmashell
112 mW 8.3 ms/s 75.3 Process [PID 994] /usr/bin/kwin_x11
112 mW 8.5 ms/s 37.9 Process [PID 808] /usr/lib/Xorg -nolisten tcp -background none -seat s
57.2 mW 4.4 ms/s 19.8 Process [PID 1213] /usr/bin/ksystemstats
50.0 mW 3.4 ms/s 76.9 Interrupt [74] amdgpu
38.4 mW 2.9 ms/s 17.4 Process [PID 7668] /usr/bin/konsole
29.5 mW 1.7 ms/s 85.2 Process [PID 1006] /usr/bin/kwin_x11
17.3 mW 0.9 ms/s 68.5 Timer tick_sched_timer
14.8 mW 1.0 ms/s 18.8 Process [PID 724] [gfx]
14.6 mW 1.1 ms/s 0.9 Process [PID 1270] /usr/lib/kf5/kioslave5 /usr/lib/qt/plugins/kf5/kio/
14.5 mW 1.1 ms/s 0.8 Process [PID 1266] /usr/lib/kf5/kioslave5 /usr/lib/qt/plugins/kf5/kio/
14.3 mW 1.1 ms/s 5.9 Interrupt [7] sched(softirq)
14.0 mW 1.1 ms/s 0.05 Process [PID 9358] systemd-udevd
13.3 mW 1.0 ms/s 1.4 Process [PID 1268] /usr/lib/kf5/kioslave5 /usr/lib/qt/plugins/kf5/kio/
13.2 mW 1.0 ms/s 1.7 Process [PID 1272] /usr/lib/kf5/kioslave5 /usr/lib/qt/plugins/kf5/kio/
13.1 mW 1.0 ms/s 0.00 Process [PID 5054] [kworker/u32:4]
PowerTOP 2.14 Overview Idle stats Frequency stats Device stats Tunables WakeUp
The battery reports a discharge rate of 11.3 W
The energy consumed was 225 J
The estimated remaining time is 3 hours, 9 minutes
Summary: 455.6 wakeups/second, 0.0 GPU ops/seconds, 0.0 VFS ops/sec and 5.7% CPU use
6.10 W 10.2% Device Display backlight
93.3 mW 8.1 ms/s 41.3 Process [PID 1014] /usr/bin/plasmashell
63.1 mW 5.5 ms/s 51.5 Process [PID 945] /usr/bin/kwin_x11
61.9 mW 5.4 ms/s 21.6 Process [PID 750] /usr/lib/Xorg -nolisten tcp -background none -seat s
57.9 mW 5.0 ms/s 25.7 Process [PID 1153] /usr/bin/ksystemstats
38.3 mW 3.3 ms/s 69.3 Interrupt [74] amdgpu
30.8 mW 2.7 ms/s 0.20 Process [PID 426] /usr/bin/dbus-daemon --system --address=systemd: --n
26.3 mW 2.3 ms/s 4.9 Process [PID 8653] /usr/lib/kauth/backlighthelper
19.3 mW 1.7 ms/s 8.5 Process [PID 7067] /usr/bin/konsole
15.3 mW 1.3 ms/s 2.2 Process [PID 8658] systemd-udevd
13.8 mW 1.2 ms/s 1.8 Process [PID 8657] systemd-udevd
12.8 mW 1.1 ms/s 1.3 Process [PID 1204] /usr/lib/kf5/kioslave5 /usr/lib/qt/plugins/kf5/kio/
12.8 mW 1.1 ms/s 53.5 Process [PID 956] /usr/bin/kwin_x11
12.6 mW 1.1 ms/s 1.4 Process [PID 1209] /usr/lib/kf5/kioslave5 /usr/lib/qt/plugins/kf5/kio/
12.4 mW 1.1 ms/s 1.2 Process [PID 1206] /usr/lib/kf5/kioslave5 /usr/lib/qt/plugins/kf5/kio/
12.4 mW 1.1 ms/s 1.2 Process [PID 1211] /usr/lib/kf5/kioslave5 /usr/lib/qt/plugins/kf5/kio/
And powertop currently with Firefox (and others) opened:
The battery reports a discharge rate of 7.83 W
The energy consumed was 146 J
The estimated remaining time is 3 hours, 55 minutes
Summary: 1201.2 wakeups/second, 0.0 GPU ops/seconds, 0.0 VFS ops/sec and 39.3% CPU use
6.05 W 10.2% Device Display backlight
909 mW 264.7 ms/s 99.3 Process [PID 3373] /usr/lib/firefox/firefox -contentproc -childID 6 -i
373 mW 5.2 ms/s 197.5 Process [PID 970] /usr/bin/kwin_x11
326 mW 2.3 ms/s 202.5 Timer tick_sched_timer
287 mW 30.4 ms/s 120.7 Process [PID 2935] /usr/lib/firefox/firefox
139 mW 2.6 ms/s 68.6 Process [PID 3013] /usr/lib/firefox/firefox
116 mW 4.2 ms/s 66.1 Interrupt [74] amdgpu
106 mW 10.4 ms/s 43.1 Process [PID 732] /usr/lib/Xorg -nolisten tcp -background none -seat s
95.5 mW 3.9 ms/s 53.3 Process [PID 2955] /usr/lib/firefox/firefox
82.9 mW 7.3 ms/s 37.0 Process [PID 1049] /usr/bin/plasmashell
78.0 mW 22.5 ms/s 8.9 kWork commit_work
53.6 mW 5.6 ms/s 23.9 Process [PID 3141] /usr/lib/firefox/firefox -contentproc -childID 2 -i
52.9 mW 1.3 ms/s 31.1 Process [PID 589] [gfx]
52.4 mW 416.3 µs/s 31.2 Process [PID 13] [rcu_preempt]
40.2 mW 3.4 ms/s 19.3 Process [PID 1174] /usr/bin/ksystemstats
journal when put into sleep and can’t wake up:
12月 04 09:21:30 AC-Staff systemd-logind[429]: Lid closed.
12月 04 09:21:30 AC-Staff kded5[941]: bluedevil: About to suspend
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6036] manager: sleep: sleep requested (sleeping: no enabled: yes)
12月 04 09:21:30 AC-Staff ModemManager[463]: <info> [sleep-monitor] system is about to suspend
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6038] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6047] manager: NetworkManager state is now ASLEEP
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6050] device (wlp1s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
12月 04 09:21:30 AC-Staff kded5[941]: plasma-nm: Unhandled active connection state change: 3
12月 04 09:21:30 AC-Staff dbus-daemon[426]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=427 comm="/usr/bin/NetworkManager --no-daemon ")
12月 04 09:21:30 AC-Staff systemd[1]: Starting Network Manager Script Dispatcher Service...
12月 04 09:21:30 AC-Staff dbus-daemon[426]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
12月 04 09:21:30 AC-Staff systemd[1]: Started Network Manager Script Dispatcher Service.
12月 04 09:21:30 AC-Staff audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12月 04 09:21:30 AC-Staff kernel: audit: type=1130 audit(1638580890.629:97): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12月 04 09:21:30 AC-Staff kernel: wlp1s0: deauthenticating from 5c:83:8f:43:79:7c by local choice (Reason: 3=DEAUTH_LEAVING)
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=5c:83:8f:43:79:7c reason=3 locally_generated=1
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=0 noise=9999 txrate=0
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6569] device (wlp1s0): supplicant interface state: completed -> disconnected
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6569] device (wlp1s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Withdrawing address record for 2001:da8:201:3002:54d1:13e9:72d2:bc60 on wlp1s0.
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address 2001:da8:201:3002:54d1:13e9:72d2:bc60.
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6573] dhcp4 (wlp1s0): canceled DHCP transaction
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::60db:b202:17c7:4a3c.
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6574] dhcp4 (wlp1s0): state changed extended -> terminated
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Registering new address record for fe80::60db:b202:17c7:4a3c on wlp1s0.*.
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Withdrawing address record for fe80::60db:b202:17c7:4a3c on wlp1s0.
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::60db:b202:17c7:4a3c.
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Interface wlp1s0.IPv6 no longer relevant for mDNS.
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:43:79:7c 0
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Interface wlp1s0.IPv4 no longer relevant for mDNS.
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Leaving mDNS multicast group on interface wlp1s0.IPv4 with address 10.0.79.79.
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:50:58:2c 0
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Withdrawing address record for 10.0.79.79 on wlp1s0.
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:43:79:73 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:43:77:23 0
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6601] device (wlp1s0): set-hw-addr: set MAC address to BE:C9:B5:11:C1:64 (scanning)
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:50:58:23 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 48:4a:e9:cd:f6:22 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:43:77:2c 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 48:4a:e9:cd:f6:32 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:92:75:4c 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:3f:a8:5c 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:b6:21:73 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 80:8d:b7:7f:c7:42 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:92:75:43 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:3f:a8:53 0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:82:ce:fc 0
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 10.0.79.79.
12月 04 09:21:30 AC-Staff avahi-daemon[424]: New relevant interface wlp1s0.IPv4 for mDNS.
12月 04 09:21:30 AC-Staff avahi-daemon[424]: Registering new address record for 10.0.79.79 on wlp1s0.IPv4.
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6677] device (wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
12月 04 09:21:30 AC-Staff NetworkManager[427]: <info> [1638580890.6700] device (wlp1s0): set-hw-addr: reset MAC address to 98:2C:BC:8B:69:2E (unmanage)
12月 04 09:21:30 AC-Staff kded5[941]: plasma-nm: Not emitting connection deactivated notification as we're about to suspend
12月 04 09:21:30 AC-Staff kscreenlocker_greet[9207]: Qt: Session management error: networkIdsList argument is NULL
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: nl80211: deinit ifname=p2p-dev-wlp1s0 disabled_11b_rates=0
12月 04 09:21:30 AC-Staff wpa_supplicant[738]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
12月 04 09:21:30 AC-Staff systemd[1]: Reached target Sleep.
12月 04 09:21:30 AC-Staff systemd[1]: Starting System Suspend...
12月 04 09:21:31 AC-Staff kded5[941]: ktp-kded-module: "screen-saver-away" presence change request: "away" ""
12月 04 09:21:31 AC-Staff kded5[941]: ktp-kded-module: plugin queue activation: "away" ""
12月 04 09:21:31 AC-Staff systemd-sleep[9236]: Entering sleep state 'suspend'...
12月 04 09:21:31 AC-Staff kernel: PM: suspend entry (deep)
journal when normal:
12月 04 09:24:03 AC-Staff systemd-logind[451]: Lid closed.
12月 04 09:24:03 AC-Staff kded5[966]: bluedevil: About to suspend
12月 04 09:24:03 AC-Staff ModemManager[506]: <info> [sleep-monitor] system is about to suspend
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.5441] manager: sleep: sleep requested (sleeping: no enabled: yes)
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.5442] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.5449] manager: NetworkManager state is now ASLEEP
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.5451] device (wlp1s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
12月 04 09:24:03 AC-Staff kded5[966]: plasma-nm: Unhandled active connection state change: 3
12月 04 09:24:03 AC-Staff dbus-daemon[444]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=446 comm="/usr/bin/NetworkManager --no-daemon ")
12月 04 09:24:03 AC-Staff systemd[1]: Starting Network Manager Script Dispatcher Service...
12月 04 09:24:03 AC-Staff dbus-daemon[444]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
12月 04 09:24:03 AC-Staff systemd[1]: Started Network Manager Script Dispatcher Service.
12月 04 09:24:03 AC-Staff audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12月 04 09:24:03 AC-Staff kernel: audit: type=1130 audit(1638581043.565:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
12月 04 09:24:03 AC-Staff kernel: wlp1s0: deauthenticating from 5c:83:8f:43:79:7c by local choice (Reason: 3=DEAUTH_LEAVING)
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=5c:83:8f:43:79:7c reason=3 locally_generated=1
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.5900] device (wlp1s0): supplicant interface state: completed -> disconnected
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.5901] device (wlp1s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Withdrawing address record for 2001:da8:201:3002:54d1:13e9:72d2:bc60 on wlp1s0.
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address 2001:da8:201:3002:54d1:13e9:72d2:bc60.
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::60db:b202:17c7:4a3c.
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Registering new address record for fe80::60db:b202:17c7:4a3c on wlp1s0.*.
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Withdrawing address record for fe80::60db:b202:17c7:4a3c on wlp1s0.
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::60db:b202:17c7:4a3c.
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Interface wlp1s0.IPv6 no longer relevant for mDNS.
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.6108] dhcp4 (wlp1s0): canceled DHCP transaction
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.6108] dhcp4 (wlp1s0): state changed bound -> terminated
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:43:79:7c 0
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Interface wlp1s0.IPv4 no longer relevant for mDNS.
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Leaving mDNS multicast group on interface wlp1s0.IPv4 with address 10.0.79.79.
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:b6:21:7c 0
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Withdrawing address record for 10.0.79.79 on wlp1s0.
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:43:77:23 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:43:77:2c 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:92:75:4c 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:b6:21:73 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:50:58:2c 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:43:79:73 0
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.6140] device (wlp1s0): set-hw-addr: set MAC address to 66:52:33:CF:7A:F5 (scanning)
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:50:58:23 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:3f:a8:5c 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 48:4a:e9:cd:f6:32 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:3f:a8:53 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 48:4a:e9:cd:f6:22 0
12月 04 09:24:03 AC-Staff wpa_supplicant[689]: wlp1s0: PMKSA-CACHE-REMOVED 5c:83:8f:3f:9f:d3 0
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 10.0.79.79.
12月 04 09:24:03 AC-Staff avahi-daemon[441]: New relevant interface wlp1s0.IPv4 for mDNS.
12月 04 09:24:03 AC-Staff avahi-daemon[441]: Registering new address record for 10.0.79.79 on wlp1s0.IPv4.
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.6402] device (wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
12月 04 09:24:03 AC-Staff NetworkManager[446]: <info> [1638581043.6429] device (wlp1s0): set-hw-addr: reset MAC address to 98:2C:BC:8B:69:2E (unmanage)
12月 04 09:24:03 AC-Staff kded5[966]: plasma-nm: Not emitting connection deactivated notification as we're about to suspend
12月 04 09:24:03 AC-Staff kscreenlocker_greet[2411]: Qt: Session management error: networkIdsList argument is NULL
12月 04 09:24:03 AC-Staff systemd[1]: Reached target Sleep.
12月 04 09:24:03 AC-Staff systemd[1]: Starting System Suspend...
12月 04 09:24:03 AC-Staff kded5[966]: ktp-kded-module: "screen-saver-away" presence change request: "away" ""
12月 04 09:24:03 AC-Staff kded5[966]: ktp-kded-module: plugin queue activation: "away" ""
12月 04 09:24:04 AC-Staff systemd-sleep[2439]: Entering sleep state 'suspend'...
12月 04 09:24:04 AC-Staff kernel: PM: suspend entry (deep)
12月 04 09:24:04 AC-Staff kernel: Filesystems sync: 0.005 seconds
12月 04 09:24:07 AC-Staff kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
12月 04 09:24:07 AC-Staff kernel: OOM killer disabled.
12月 04 09:24:07 AC-Staff kernel: Freezing remaining freezable tasks ... (elapsed 0.000 seconds) done.
12月 04 09:24:07 AC-Staff kernel: printk: Suspending console(s) (use no_console_suspend to debug)
12月 04 09:24:07 AC-Staff kernel: [drm] free PSP TMR buffer
12月 04 09:24:07 AC-Staff kernel: ACPI: EC: interrupt blocked
12月 04 09:24:07 AC-Staff kernel: ACPI: Preparing to enter system sleep state S3
12月 04 09:24:07 AC-Staff kernel: ACPI: EC: event blocked
12月 04 09:24:07 AC-Staff kernel: ACPI: EC: EC stopped
12月 04 09:24:07 AC-Staff kernel: PM: Saving platform NVS memory
12月 04 09:24:07 AC-Staff kernel: Disabling non-boot CPUs ...
12月 04 09:24:07 AC-Staff kernel: smpboot: CPU 1 is now offline
12月 04 09:24:07 AC-Staff kernel: smpboot: CPU 2 is now offline
12月 04 09:24:07 AC-Staff kernel: smpboot: CPU 3 is now offline
12月 04 09:24:07 AC-Staff kernel: smpboot: CPU 4 is now offline
12月 04 09:24:07 AC-Staff kernel: smpboot: CPU 5 is now offline
12月 04 09:24:07 AC-Staff kernel: smpboot: CPU 6 is now offline
12月 04 09:24:07 AC-Staff kernel: smpboot: CPU 7 is now offline
12月 04 09:24:07 AC-Staff kernel: ACPI: Low-level resume complete
12月 04 09:24:07 AC-Staff kernel: ACPI: EC: EC started
12月 04 09:24:07 AC-Staff kernel: PM: Restoring platform NVS memory
12月 04 09:24:07 AC-Staff kernel: Enabling non-boot CPUs ...
12月 04 09:24:07 AC-Staff kernel: x86: Booting SMP configuration:
12月 04 09:24:07 AC-Staff kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
12月 04 09:24:07 AC-Staff kernel: microcode: CPU1: patch_level=0x08108102
12月 04 09:24:07 AC-Staff kernel: ACPI: \_PR_.C001: Found 2 idle states
12月 04 09:24:07 AC-Staff kernel: CPU1 is up
12月 04 09:24:07 AC-Staff kernel: smpboot: Booting Node 0 Processor 2 APIC 0x2
12月 04 09:24:07 AC-Staff kernel: microcode: CPU2: patch_level=0x08108102
12月 04 09:24:07 AC-Staff kernel: ACPI: \_PR_.C002: Found 2 idle states
12月 04 09:24:07 AC-Staff kernel: CPU2 is up
12月 04 09:24:07 AC-Staff kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
12月 04 09:24:07 AC-Staff kernel: microcode: CPU3: patch_level=0x08108102
12月 04 09:24:07 AC-Staff kernel: ACPI: \_PR_.C003: Found 2 idle states
12月 04 09:24:07 AC-Staff kernel: CPU3 is up
12月 04 09:24:07 AC-Staff kernel: smpboot: Booting Node 0 Processor 4 APIC 0x4
12月 04 09:24:07 AC-Staff kernel: microcode: CPU4: patch_level=0x08108102
12月 04 09:24:07 AC-Staff kernel: ACPI: \_PR_.C004: Found 2 idle states
12月 04 09:24:07 AC-Staff kernel: CPU4 is up
12月 04 09:24:07 AC-Staff kernel: smpboot: Booting Node 0 Processor 5 APIC 0x5
12月 04 09:24:07 AC-Staff kernel: microcode: CPU5: patch_level=0x08108102
12月 04 09:24:07 AC-Staff kernel: ACPI: \_PR_.C005: Found 2 idle states
12月 04 09:24:07 AC-Staff kernel: CPU5 is up
12月 04 09:24:07 AC-Staff kernel: smpboot: Booting Node 0 Processor 6 APIC 0x6
12月 04 09:24:07 AC-Staff kernel: microcode: CPU6: patch_level=0x08108102
12月 04 09:24:07 AC-Staff kernel: ACPI: \_PR_.C006: Found 2 idle states
12月 04 09:24:07 AC-Staff kernel: CPU6 is up
12月 04 09:24:07 AC-Staff kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
12月 04 09:24:07 AC-Staff kernel: microcode: CPU7: patch_level=0x08108102
12月 04 09:24:07 AC-Staff kernel: ACPI: \_PR_.C007: Found 2 idle states
12月 04 09:24:07 AC-Staff kernel: CPU7 is up
12月 04 09:24:07 AC-Staff kernel: ACPI: Waking up from system sleep state S3
12月 04 09:24:07 AC-Staff kernel: ACPI: EC: interrupt unblocked
12月 04 09:24:07 AC-Staff kernel: ACPI: EC: event unblocked
12月 04 09:24:07 AC-Staff kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
12月 04 09:24:07 AC-Staff kernel: [drm] PSP is resuming...
12月 04 09:24:07 AC-Staff kernel: nvme nvme0: Shutdown timeout set to 8 seconds
12月 04 09:24:07 AC-Staff kernel: [drm] reserve 0x400000 from 0xf43fc00000 for PSP TMR
12月 04 09:24:07 AC-Staff kernel: nvme nvme0: 16/0/0 default/read/poll queues
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
12月 04 09:24:07 AC-Staff kernel: usb 1-2: reset full-speed USB device number 2 using xhci_hcd
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
12月 04 09:24:07 AC-Staff kernel: [drm] kiq ring mec 2 pipe 1 q 0
12月 04 09:24:07 AC-Staff kernel: amdgpu: dpm has been enabled
12月 04 09:24:07 AC-Staff kernel: usb 3-1: reset high-speed USB device number 2 using xhci_hcd
12月 04 09:24:07 AC-Staff kernel: [drm] VCN decode and encode initialized successfully(under SPG Mode).
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
12月 04 09:24:07 AC-Staff kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
12月 04 09:24:07 AC-Staff kernel: usb 1-4: reset full-speed USB device number 3 using xhci_hcd
12月 04 09:24:07 AC-Staff kernel: OOM killer enabled.
12月 04 09:24:07 AC-Staff kernel: Restarting tasks ... done.
12月 04 09:24:07 AC-Staff kernel: PM: suspend exit
12月 04 09:24:07 AC-Staff systemd-logind[451]: Lid opened.
This is my inxi
output:
Kernel: 5.10.79-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
root=UUID=eb7ffe38-7cc4-4664-aa0e-121e202fe7da rw quiet udev.log_priority=3
processor.max_cstates=5
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1
dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HUAWEI product: KPR-WX9 v: M1020
serial: <superuser required>
Mobo: HUAWEI model: KPR-WX9-PCB v: M1020 serial: <superuser required>
UEFI: HUAWEI v: 1.10 date: 08/15/2019
ID-1: BAT1 charge: 31.4 Wh (66.5%) condition: 47.2/56.3 Wh (83.8%)
volts: 7.7 min: 7.6 model: DYNAPACK HB4593R1ECW type: Li-ion
serial: <filter> status: Discharging cycles: 517
RAM: total: 6.78 GiB used: 3.72 GiB (54.9%)
Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 cache: L1: 384 KiB L2: 2 MiB L3: 4 MiB
bogomips: 33547
Speed: 1888 MHz max: 1400 MHz boost: enabled Core speeds (MHz): 1: 2158
2: 1532 3: 1212 4: 1221 5: 1230 6: 1233 7: 1304 8: 1198
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Picasso vendor: Huawei driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: Quanta hm1091_techfront type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 0408:1020 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.10.79-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Huawei
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Huawei driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.79-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: no
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-2:2 chip-ID: 8087:0a2b class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch hold sniff
link-mode: peripheral accept
Local Storage: total: 476.94 GiB used: 63.42 GiB (13.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-00000
lanes: 4 type: SSD serial: <filter> rev: EXA7301Q temp: 35.9 C scheme: GPT
ID-1: / raw-size: 40 GiB size: 39.25 GiB (98.12%) used: 25.85 GiB (65.9%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: eb7ffe38-7cc4-4664-aa0e-121e202fe7da
ID-2: /boot raw-size: 512 MiB size: 487.2 MiB (95.16%) used: 59 MiB (12.1%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 5d626753-f3e9-4e7c-bef0-c743af2aa988
ID-3: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
used: 27.4 MiB (28.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 1E94-A0EE
ID-4: /home raw-size: 40.09 GiB size: 39.34 GiB (98.11%)
used: 26.78 GiB (68.1%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
label: N/A uuid: 3e1df06c-36ab-4dfe-b081-eae833496b14
ID-5: /run/media/ac/Share raw-size: 20 GiB size: 20 GiB (100.00%)
used: 10.7 GiB (53.5%) fs: ntfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: Share uuid: 86B8057AB80569CF
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 1e866917-544a-4b33-97a0-150be4b0bbb0
ID-1: /dev/nvme0n1p10 maj-min: 259:10 size: 512 MiB fs: vfat label: WINPE
uuid: B896-3FEE
ID-2: /dev/nvme0n1p11 maj-min: 259:11 size: 12 GiB fs: ntfs label: Onekey
uuid: 74329888329850CA
ID-3: /dev/nvme0n1p12 maj-min: 259:12 size: 1024 MiB fs: ntfs label: N/A
uuid: 5056135956133F62
ID-4: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/nvme0n1p3 maj-min: 259:3 size: 120 GiB fs: ntfs label: Windows
uuid: 72B849A6B84969A5
ID-6: /dev/nvme0n1p4 maj-min: 259:4 size: 234.73 GiB fs: ntfs label: Data
uuid: 3CB8B9E7B8B9A036
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-4:3 info: Shenzhen Goodix Fingerprint Reader
type: Communication,CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5117 class-ID: 0a00
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: Quanta hm1091_techfront type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:1020
class-ID: 0e02
Device-2: 3-2:3 info: Lite-On USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 04ca:0061 class-ID: 0301
Hub-4: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.2 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 252 Uptime: 22m wakeups: 2 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1780 lib: 394
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.09
I tried to set max_cstates
to 5 but without luck:
> cat /proc/cmdline
BOOT_IMAGE=/vmlinuz-5.10-x86_64 root=UUID=eb7ffe38-7cc4-4664-aa0e-121e202fe7da rw quiet udev.log_priority=3 processor.max_cstates=5
