Hi everyone. First time posting here.
For a while I’ve been encountering a strange issue on my system. It happens seemingly at random.
When I boot my PC I sometimes end up in Emergency Mode. When checking journalctl, the last error thrown is failure to mount a non-OS drive.
Like I said, it happens randomly and a reboot, once in Emergency Mode, almost always results in a successful boot with all drives mounted correctly. This is not a dramatic issue, but it’s just very weird and I’d like to know what is going on. The drive also seems to be in good health.
Some further context, the drive in question is a WD_BLACK AN1500, which is a PCIe connected drive. Maybe that could have something to do with the issue?
Here is the segment of journalctl I think is relevant:
Sep 03 19:08:40 <hostname> systemd[1]: Mounting /boot/efi...
Sep 03 19:08:40 <hostname> systemd[1]: Mounting /home...
Sep 03 19:08:40 <hostname> systemd[1]: Mounting /mnt/nvme1n1...
Sep 03 19:08:40 <hostname> systemd[1]: Mounting /mnt/sda1...
Sep 03 19:08:40 <hostname> systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
Sep 03 19:08:40 <hostname> systemd[1]: Mounting /tmp...
Sep 03 19:08:40 <hostname> systemd[1]: var-cache.mount: Directory /var/cache to mount over is not empty, mounting anyway.
Sep 03 19:08:40 <hostname> systemd[1]: Mounting /var/cache...
Sep 03 19:08:40 <hostname> systemd[1]: Virtual Machine and Container Storage (Compatibility) skipped, unmet condition check ConditionPathExists=/var/lib/machines.raw
Sep 03 19:08:40 <hostname> systemd[1]: Listening on Disk Image Download Service Socket.
Sep 03 19:08:40 <hostname> systemd[1]: var-log.mount: Directory /var/log to mount over is not empty, mounting anyway.
Sep 03 19:08:40 <hostname> systemd-timesyncd[634]: Network configuration changed, trying to establish connection.
Sep 03 19:08:40 <hostname> systemd[1]: Mounting /var/log...
Sep 03 19:08:40 <hostname> mount[832]: mount: /mnt/nvme1n1: wrong fs type, bad option, bad superblock on /dev/nvme1n1p1, missing codepage or helper program, or other error.
Sep 03 19:08:40 <hostname> mount[832]: dmesg(1) may have more information after failed mount system call.
Sep 03 19:08:40 <hostname> kernel: EXT4-fs (nvme1n1p1): VFS: Can't find ext4 filesystem
Sep 03 19:08:40 <hostname> systemd[1]: mnt-nvme1n1.mount: Mount process exited, code=exited, status=32/n/a
Sep 03 19:08:40 <hostname> systemd[1]: mnt-nvme1n1.mount: Failed with result 'exit-code'.
Sep 03 19:08:40 <hostname> systemd[1]: Failed to mount /mnt/nvme1n1.
Sep 03 19:08:40 <hostname> systemd[1]: Dependency failed for Local File Systems.
Sep 03 19:08:40 <hostname> systemd[1]: local-fs.target: Job local-fs.target/start failed with result 'dependency'.
Sep 03 19:08:40 <hostname> systemd[1]: local-fs.target: Triggering OnFailure= dependencies.
Sep 03 19:08:40 <hostname> systemd[1]: Mounted /tmp.
Sep 03 19:08:40 <hostname> systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Sep 03 19:08:40 <hostname> systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Sep 03 19:08:40 <hostname> systemd[1]: Reached target Timer Units.
Sep 03 19:08:40 <hostname> systemd[1]: Listening on Boot Loader Control Service Socket.
Sep 03 19:08:40 <hostname> systemd[1]: Listening on System Extension Image Management.
Sep 03 19:08:40 <hostname> systemd[1]: Reached target Sound Card.
Sep 03 19:08:40 <hostname> systemd[1]: Reached target Bluetooth Support.
Sep 03 19:08:40 <hostname> systemd[1]: Starting Load JSON user/group Records from Credentials...
Sep 03 19:08:40 <hostname> systemd[1]: Reached target Preparation for Network.
Sep 03 19:08:40 <hostname> systemd[1]: Reached target Network.
Sep 03 19:08:40 <hostname> systemd[1]: Reached target Network is Online.
Sep 03 19:08:40 <hostname> systemd[1]: Reached target Path Units.
Sep 03 19:08:40 <hostname> systemd[1]: Reached target Socket Units.
Sep 03 19:08:40 <hostname> systemd[1]: Started Emergency Shell.
Sep 03 19:08:40 <hostname> systemd[1]: Reached target Emergency Mode.
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 1,8T 0 disk
└─sda1 8:1 0 1,8T 0 part /mnt/sda1
sdb 8:16 1 0B 0 disk
sdc 8:32 1 0B 0 disk
nvme1n1 259:1 0 931,4G 0 disk
└─nvme1n1p1 259:2 0 931,4G 0 part /mnt/nvme1n1
nvme0n1 259:3 0 931,5G 0 disk
├─nvme0n1p1 259:4 0 300M 0 part /boot/efi
├─nvme0n1p2 259:5 0 897,7G 0 part /home
│ /var/cache
│ /var/log
└─nvme0n1p3 259:6 0 33,5G 0 part [SWAP]
sudo parted -l:
Model: ATA ST2000DM008-2UB1 (scsi)
Disk /dev/sda: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 2000GB 2000GB btrfs root
Model: WD_BLACK SN770 1TB (nvme)
Disk /dev/nvme0n1: 1000GB
Disk Flags:
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 964GB 964GB btrfs root
3 964GB 1000GB 36,0GB linux-swap(v1) swap
Model: WD_BLACK AN1500 (nvme)
Disk /dev/nvme1n1: 1000GB
Disk Flags:
1 1049kB 1000GB 1000GB ext4
/etc/fstab:
#New Partition /mnt/sda /mnt/sda nofail,users 0 0 # /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=B50C-C336 /boot/efi vfat umask=0077 0 2
UUID=0e507121-812e-4b1b-8fdf-7e5ae3e9ee05 / btrfs subvol=/@,compress=zstd:1 0 0
UUID=0e507121-812e-4b1b-8fdf-7e5ae3e9ee05 /home btrfs subvol=/@home,compress=zstd:1 0 0
UUID=0e507121-812e-4b1b-8fdf-7e5ae3e9ee05 /var/cache btrfs subvol=/@cache,compress=zstd:1 0 0
UUID=0e507121-812e-4b1b-8fdf-7e5ae3e9ee05 /var/log btrfs subvol=/@log,compress=zstd:1 0 0
UUID=5c21c2a6-ff28-49ed-a484-f74faf79eb94 swap swap defaults 0 0
tmpfs /tmp tmpfs noatime,mode=1777 0 0
/dev/sda1 /mnt/sda1 btrfs nofail 0 0
/dev/nvme1n1p1 /mnt/nvme1n1 ext4 defaults 0 0
sudo smartctl -a /dev/nvme1n1:
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-7.2.0--1-MANJARO] (local build)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: WD_BLACK AN1500
Serial Number: WUBT22120252
Firmware Version: 10271043
PCI Vendor ID: 0x1b4b
PCI Vendor Subsystem ID: 0x1b96
IEEE OUI Identifier: 0x005043
Total NVM Capacity: 1.000.081.457.152 [1,00 TB]
Unallocated NVM Capacity: 0
Controller ID: 0
NVMe Version: 1.3
Number of Namespaces: 4
Namespace 1 Size/Capacity: 1.000.081.457.152 [1,00 TB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 005043 6b0b000001
Local Time is: Thu Sep 3 20:58:06 2026 CEST
Firmware Updates (0x04): 2 Slots
Optional Admin Commands (0x004c): Frmw_DL NS_Mngmt MI_Snd/Rec
Optional NVM Commands (0x0064): DS_Mngmt Resv Timestmp
Log Page Attributes (0x02): Cmd_Eff_Lg
Maximum Data Transfer Size: 32 Pages
Warning Comp. Temp. Threshold: 70 Celsius
Critical Comp. Temp. Threshold: 70 Celsius
Namespace 1 Features (0x08): No_ID_Reuse
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 0.00W - - 0 0 0 0 0 0
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02, NSID 0xffffffff)
Critical Warning: 0x00
Temperature: 59 Celsius
Available Spare: 0%
Available Spare Threshold: 0%
Percentage Used: 0%
Data Units Read: 0
Data Units Written: 0
Host Read Commands: 0
Host Write Commands: 0
Controller Busy Time: 0
Power Cycles: 0
Power On Hours: 0
Unsafe Shutdowns: 0
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 59 Celsius
Error Information (NVMe Log 0x01, 15 of 15 entries)
No Errors Logged
Self-tests not supported
Do let me know if any information is missing, and thank you to anyone taking their time reading this.
EDIT: Thank you all for the responses. I did not consider that the /dev paths could change, but it does make sense once pointed out. That would also explain why the issue occurred “randomly” and was seemingly fixed after a reboot. Of course, I can’t directly see any changes, but it sounds very plausible that the /dev paths in my fstab would have caused this.
