Last two freezes:
mar 02 07:04:54 manjaro-su kernel: Could not retrieve perf counters (-19)
mar 02 07:04:54 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
mar 02 07:04:54 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
mar 02 07:04:54 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: Secure display: Generic Failure.
mar 02 07:04:54 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
mar 02 07:04:54 manjaro-su systemd-modules-load[363]: Failed to find module 'v4l2loopback_dc'
mar 02 07:04:54 manjaro-su kernel: nvidia: loading out-of-tree module taints kernel.
mar 02 07:04:54 manjaro-su kernel: nvidia: module license 'NVIDIA' taints kernel.
mar 02 07:04:54 manjaro-su kernel: Disabling lock debugging due to kernel taint
mar 02 07:04:54 manjaro-su kernel: nvidia: module license taints kernel.
mar 02 07:04:55 manjaro-su kernel:
mar 02 07:04:55 manjaro-su kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.144.03 Mon Dec 30 17:44:08 UTC 2024
mar 02 07:04:55 manjaro-su kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
mar 02 07:04:55 manjaro-su (udev-worker)[438]: hiddev2: /etc/udev/rules.d/mixxx.usb.rules:25 Only network interfaces can be renamed, ignoring NAME="usb/%k".
mar 02 07:04:55 manjaro-su (udev-worker)[411]: hiddev0: /etc/udev/rules.d/mixxx.usb.rules:25 Only network interfaces can be renamed, ignoring NAME="usb/%k".
mar 02 07:04:55 manjaro-su kernel: VBoxNetAdp: Successfully started.
mar 02 07:04:55 manjaro-su kernel: VBoxNetFlt: Successfully started.
mar 02 07:04:56 manjaro-su systemd[1]: shadow.service: Failed with result 'exit-code'.
mar 02 07:05:00 manjaro-su dbus-broker-launch[1009]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
mar 02 07:05:00 manjaro-su dbus-broker-launch[1009]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
mar 02 07:05:00 manjaro-su unix_chkpwd[1341]: could not obtain user info (sddm)
mar 02 07:05:00 manjaro-su (systemd)[1340]: PAM failed: Authentication service cannot retrieve authentication info
mar 02 07:05:00 manjaro-su (systemd)[1340]: user@968.service: Failed to set up PAM session: Operation not permitted
mar 02 07:05:00 manjaro-su (systemd)[1340]: user@968.service: Failed at step PAM spawning /usr/lib/systemd/systemd: Operation not permitted
mar 02 07:05:00 manjaro-su systemd[1]: user@968.service: Failed with result 'exit-code'.
mar 02 07:05:00 manjaro-su systemd[1]: Failed to start User Manager for UID 968.
mar 02 07:05:02 manjaro-su nmbd[1366]: [2025/03/02 07:05:02.146813, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
mar 02 07:05:02 manjaro-su nmbd[1366]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
mar 02 07:05:25 manjaro-su systemd-xdg-autostart-generator[1596]: Configuration file /root/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 07:05:25 manjaro-su systemd-xdg-autostart-generator[1596]: Configuration file /root/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 07:05:25 manjaro-su systemd-xdg-autostart-generator[1596]: Configuration file /root/.config/autostart/live-session.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 07:05:25 manjaro-su systemd-xdg-autostart-generator[1596]: Configuration file /root/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 07:05:32 manjaro-su sddm-greeter-qt6[1343]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
mar 02 07:05:32 manjaro-su sddm-helper[1630]: gkr-pam: unable to locate daemon control file
mar 02 07:05:32 manjaro-su systemd-xdg-autostart-generator[1657]: Configuration file /home/ciacnorris/.config/autostart/manjaro-hello.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 07:05:32 manjaro-su systemd-xdg-autostart-generator[1657]: Configuration file /home/ciacnorris/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 07:05:32 manjaro-su dbus-broker-launch[1674]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 02 07:05:32 manjaro-su dbus-broker-launch[1674]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 02 07:05:32 manjaro-su dbus-broker-launch[1674]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 02 07:05:33 manjaro-su systemd-xdg-autostart-generator[1726]: Configuration file /home/ciacnorris/.config/autostart/manjaro-hello.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 07:05:33 manjaro-su systemd-xdg-autostart-generator[1726]: Configuration file /home/ciacnorris/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 07:05:33 manjaro-su wireplumber[1664]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
mar 02 07:05:33 manjaro-su wireplumber[1664]: spa.bluez5: BlueZ system service is not available
mar 02 07:05:33 manjaro-su kded6[1815]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
mar 02 07:05:33 manjaro-su kded6[1815]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
mar 02 07:05:34 manjaro-su kconf_update[1917]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
mar 02 07:05:34 manjaro-su kconf_update[1917]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
mar 02 07:05:34 manjaro-su kconf_update[1917]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
mar 02 07:05:34 manjaro-su kconf_update[1917]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
mar 02 07:05:34 manjaro-su kconf_update[1917]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
mar 02 07:05:34 manjaro-su kconf_update[1917]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
mar 02 07:05:34 manjaro-su kded6[1815]: kf.bluezqt: PendingCall Error: "The name is not activatable"
mar 02 07:05:34 manjaro-su kded6[1815]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1.monitor"
mar 02 07:05:34 manjaro-su kded6[1815]: kf.bluezqt: PendingCall Error: "Could not activate remote peer 'org.bluez': unit failed"
mar 02 07:05:34 manjaro-su kded6[1815]: kscreen.kded: PowerDevil SuspendSession action not available!
mar 02 07:05:34 manjaro-su baloo_file[1747]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.39'
mar 02 07:05:34 manjaro-su baloo_file[1747]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.43'
mar 02 07:05:34 manjaro-su org_kde_powerdevil[1955]: Failed to create wl_display (File o cartella non trovati)
mar 02 07:05:34 manjaro-su plasmashell[1877]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
mar 02 07:05:34 manjaro-su plasmashell[1877]: Toolbox not loading, toolbox package is either invalid or disabled.
mar 02 07:05:35 manjaro-su plasmashell[1877]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
mar 02 07:05:35 manjaro-su org_kde_powerdevil[1955]: busno=3, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
mar 02 07:05:35 manjaro-su org_kde_powerdevil[1955]: busno=3, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
mar 02 07:05:35 manjaro-su org_kde_powerdevil[1955]: busno=3, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
mar 02 07:05:35 manjaro-su org_kde_powerdevil[1955]: busno=3, All features that should not exist detected. Monitor does not indicate unsupported
mar 02 07:05:35 manjaro-su org_kde_powerdevil[1955]: org.kde.powerdevil: [DDCutilDetector]: Failed to initialize callback
mar 02 07:05:35 manjaro-su kdeconnectd[2132]: 2025-03-02T07:05:35 default: Cannot find a compatible running Bluez. Please check the Bluez installation. QtBluetooth requires at least BlueZ version 5.
mar 02 07:05:35 manjaro-su plasmashell[1877]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
mar 02 07:05:35 manjaro-su kdeconnectd[2132]: 2025-03-02T07:05:35 kdeconnect.core: No local bluetooth adapter found
mar 02 07:05:35 manjaro-su backlighthelper[2175]: org.kde.powerdevil: no kernel backlight interface found
mar 02 07:05:36 manjaro-su org_kde_powerdevil[1955]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 02 07:05:36 manjaro-su org_kde_powerdevil[1955]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
mar 02 07:05:36 manjaro-su org_kde_powerdevil[1955]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mar 02 07:05:36 manjaro-su kdeconnectd[2204]: QThreadStorage: Thread 0x590aa5b7bb50 exited after QThreadStorage 8 destroyed
mar 02 07:05:36 manjaro-su kdeconnectd[2204]: QThreadStorage: Thread 0x590aa5b7bb50 exited after QThreadStorage 7 destroyed
mar 02 07:05:36 manjaro-su kdeconnectd[2204]: QThreadStorage: Thread 0x590aa5b7bb50 exited after QThreadStorage 6 destroyed
mar 02 07:05:36 manjaro-su kdeconnectd[2204]: QThreadStorage: Thread 0x590aa5b7bb50 exited after QThreadStorage 2 destroyed
mar 02 07:05:36 manjaro-su DiscoverNotifier[2237]: couldn't load "/usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Impossibile caricare la libreria /usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so: libpackagekitqt6.so.1: impossibile aprire il file oggetto condiviso: File o directory non esistente"
mar 02 07:05:36 manjaro-su akonadi_control[2372]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 02 07:05:37 manjaro-su plasmashell[1877]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
mar 02 07:05:37 manjaro-su baloo_file[1747]: kf.baloo: KDE Baloo File Indexer has reached the inotify folder watch limit. File changes will be ignored.
mar 02 07:05:37 manjaro-su plasmashell[1877]: qt.core.qabstractitemmodel.checkindex: Index QModelIndex(-1,-1,0x0,QObject(0x0)) is not valid (expected valid)
mar 02 07:05:37 manjaro-su plasmashell[1877]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1.monitor"
mar 02 07:05:42 manjaro-su akonadiserver[2391]: org.kde.pim.akonadiserver: database server stopped unexpectedly
mar 02 07:05:42 manjaro-su akonadiserver[2391]: org.kde.pim.akonadiserver: Database process exited unexpectedly during initial connection!
mar 02 07:05:42 manjaro-su akonadiserver[2391]: org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
mar 02 07:05:42 manjaro-su akonadiserver[2391]: org.kde.pim.akonadiserver: arguments: QList("--defaults-file=/home/ciacnorris/.local/share/akonadi/mysql.conf", "--datadir=/home/ciacnorris/.local/share/akonadi/db_data/", "--socket=/run/user/1001/akonadi/mysql.socket", "--pid-file=/run/user/1001/akonadi/mysql.pid")
mar 02 07:05:42 manjaro-su akonadiserver[2391]: org.kde.pim.akonadiserver: stdout: ""
mar 02 07:05:42 manjaro-su akonadiserver[2391]: org.kde.pim.akonadiserver: stderr: "/usr/bin/mysqld: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadbd' instead\n"
mar 02 07:05:42 manjaro-su akonadiserver[2391]: org.kde.pim.akonadiserver: exit code: 1
mar 02 07:05:42 manjaro-su akonadiserver[2391]: org.kde.pim.akonadiserver: process error: "Errore sconosciuto"
mar 02 07:05:42 manjaro-su akonadiserver[2391]: org.kde.pim.akonadiserver: See "/home/ciacnorris/.local/share/akonadi/db_data/mysql.err" for more details
mar 02 07:05:42 manjaro-su kalendarac[2238]: org.kde.pim.akonadicore: Job error: "" for collection: QList()
mar 02 07:25:56 manjaro-su baloo_file_extractor[2991]: kf.baloo: "/home/ciacnorris/.local/state/wireplumber/stream-properties" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mar 02 07:26:09 manjaro-su baloo_file_extractor[2991]: kf.baloo: "/home/ciacnorris/.config/google-chrome/Local State" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mar 02 07:27:35 manjaro-su baloo_file_extractor[2991]: kf.baloo: "/home/ciacnorris/.config/google-chrome/Default/TransportSecurity" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mar 02 07:55:18 manjaro-su kwin_x11[1816]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
mar 02 07:55:18 manjaro-su baloorunner[2518]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
mar 02 07:55:18 manjaro-su baloorunner[2518]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
mar 02 07:55:18 manjaro-su kwin_x11[1816]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
mar 02 07:55:21 manjaro-su chromium[3164]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 07:55:22 manjaro-su chromium[3164]: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 07:55:22 manjaro-su chromium[3164]: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 07:55:22 manjaro-su chromium[3164]: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 07:55:22 manjaro-su chromium[3164]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 07:55:22 manjaro-su chromium[3164]: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 07:58:52 manjaro-su xkeyclicker[4278]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 08:11:03 manjaro-su firefox[5293]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 08:11:03 manjaro-su firefox[5293]: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 08:11:03 manjaro-su firefox[5293]: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 08:11:03 manjaro-su firefox[5293]: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 08:11:03 manjaro-su firefox[5293]: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 08:11:14 manjaro-su kwin_x11[1816]: <Unknown File>:97: TypeError: Cannot read property 'translucencyWindowTypeAnimation' of undefined
mar 02 08:18:20 manjaro-su plasmashell[1877]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
mar 02 08:19:23 manjaro-su kioworker[8651]: qt.gui.imageio.jpeg: Not a JPEG file: starts with 0x89 0x50
mar 02 08:19:35 manjaro-su kioworker[8651]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
mar 02 08:19:35 manjaro-su kioworker[8651]: kf.kio.core: An error occurred during write. The worker terminates now.
mar 02 08:19:35 manjaro-su kioworker[8651]: QThreadStorage: Thread 0x5bc22573d600 exited after QThreadStorage 10 destroyed
mar 02 08:19:35 manjaro-su kioworker[8651]: QThreadStorage: Thread 0x5bc22573d600 exited after QThreadStorage 9 destroyed
mar 02 08:19:35 manjaro-su kioworker[8651]: QThreadStorage: Thread 0x5bc22573d600 exited after QThreadStorage 8 destroyed
mar 02 08:19:35 manjaro-su kioworker[8651]: QThreadStorage: Thread 0x5bc22573d600 exited after QThreadStorage 7 destroyed
mar 02 08:19:35 manjaro-su kioworker[8651]: QThreadStorage: Thread 0x5bc22573d600 exited after QThreadStorage 6 destroyed
mar 02 08:19:35 manjaro-su kioworker[8651]: QThreadStorage: Thread 0x5bc22573d600 exited after QThreadStorage 1 destroyed
mar 02 08:19:36 manjaro-su kioworker[8797]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
mar 02 08:19:36 manjaro-su kioworker[8797]: kf.kio.core: An error occurred during write. The worker terminates now.
mar 02 08:19:36 manjaro-su kioworker[8797]: QThreadStorage: Thread 0x58163c06a600 exited after QThreadStorage 8 destroyed
mar 02 08:19:36 manjaro-su kioworker[8797]: QThreadStorage: Thread 0x58163c06a600 exited after QThreadStorage 7 destroyed
mar 02 08:19:36 manjaro-su kioworker[8797]: QThreadStorage: Thread 0x58163c06a600 exited after QThreadStorage 6 destroyed
mar 02 08:19:36 manjaro-su kioworker[8797]: QThreadStorage: Thread 0x58163c06a600 exited after QThreadStorage 1 destroyed
mar 02 08:19:37 manjaro-su kioworker[8829]: qt.gui.imageio.jpeg: Not a JPEG file: starts with 0x89 0x50
mar 02 08:19:38 manjaro-su dolphin[8602]: QThreadStorage: Thread 0x56372c2081d0 exited after QThreadStorage 9 destroyed
mar 02 08:19:38 manjaro-su kioworker[8829]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
mar 02 08:19:38 manjaro-su kioworker[8829]: kf.kio.core: An error occurred during write. The worker terminates now.
mar 02 08:19:38 manjaro-su kioworker[8829]: QThreadStorage: Thread 0x55a779d67600 exited after QThreadStorage 10 destroyed
mar 02 08:19:38 manjaro-su kioworker[8829]: QThreadStorage: Thread 0x55a779d67600 exited after QThreadStorage 9 destroyed
mar 02 08:19:38 manjaro-su kioworker[8829]: QThreadStorage: Thread 0x55a779d67600 exited after QThreadStorage 8 destroyed
mar 02 08:19:38 manjaro-su kioworker[8829]: QThreadStorage: Thread 0x55a779d67600 exited after QThreadStorage 7 destroyed
mar 02 08:19:38 manjaro-su kioworker[8829]: QThreadStorage: Thread 0x55a779d67600 exited after QThreadStorage 6 destroyed
mar 02 08:19:38 manjaro-su kioworker[8829]: QThreadStorage: Thread 0x55a779d67600 exited after QThreadStorage 1 destroyed
mar 02 08:19:43 manjaro-su plasmashell[1877]: qt.svg: <input>:26:6: Could not resolve property: #b-7
mar 02 08:19:50 manjaro-su kwin_x11[1816]: <Unknown File>:97: TypeError: Cannot read property 'translucencyWindowTypeAnimation' of undefined
mar 02 09:16:30 manjaro-su pipewire[1663]: spa.alsa: hdmi:1,1p: (0 suppressed) snd_pcm_avail after recover: Pipe interrotta
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (0 suppressed)
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:15/19 s:7905705805846 a:7907777650960 f:7907777677800 waiting:2071845114 process:26840 status:triggered
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Chromium-141) xrun state:0x72130bb4d008 pending:0/1 s:7909849178754 a:7909849300986 f:7905705874767 waiting:122232 process:18446744069566125397 status:awake
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Chromium-87) xrun state:0x72130bb73008 pending:0/1 s:7909849178754 a:7909849314216 f:7905705893678 waiting:135462 process:18446744069566131078 status:awake
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Chromium-135) xrun state:0x72130bfbb008 pending:0/1 s:7909849178754 a:7905705900208 f:7905705905058 waiting:18446744069566273070 process:4850 status:triggered
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Chromium-153) xrun state:0x72130bb27008 pending:0/1 s:7909849178754 a:7909849332386 f:7905705911088 waiting:153632 process:18446744069566130318 status:awake
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Chromium-105) xrun state:0x72130bfbc008 pending:0/1 s:7909849178754 a:7909849338696 f:7905705917378 waiting:159942 process:18446744069566130298 status:awake
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Chromium-165) xrun state:0x72130bafd008 pending:0/1 s:7909849178754 a:7909849349717 f:7905705929168 waiting:170963 process:18446744069566131067 status:awake
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Chromium-171) xrun state:0x72130baf9008 pending:0/1 s:7909849178754 a:7909849356177 f:7905705934818 waiting:177423 process:18446744069566130257 status:awake
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Chromium-98) xrun state:0x721311878008 pending:0/1 s:7909849178754 a:7905705941408 f:7905705947389 waiting:18446744069566314270 process:5981 status:triggered
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Chromium-176) xrun state:0x721310356008 pending:0/1 s:7909849178754 a:7909849373567 f:7905705953399 waiting:194813 process:18446744069566131448 status:awake
mar 02 09:16:37 manjaro-su pipewire[1663]: pw.node: (Firefox-180) xrun state:0x721310352008 pending:0/1 s:7909849178754 a:7909849379827 f:7905705985689 waiting:201073 process:18446744069566157478 status:awake
mar 02 09:16:39 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (18 suppressed)
mar 02 09:16:39 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:2/19 s:7911277852260 a:7911277914781 f:7911277933701 waiting:62521 process:18920 status:triggered
mar 02 09:16:45 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (3 suppressed)
mar 02 09:16:45 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:1/18 s:7913920682498 a:7914777830155 f:7914777862956 waiting:857147657 process:32801 status:triggered
mar 02 09:16:48 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (4 suppressed)
mar 02 09:16:48 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:1/17 s:7917277915186 a:7917920731993 f:7917920757933 waiting:642816807 process:25940 status:triggered
mar 02 09:17:04 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (15 suppressed)
mar 02 09:17:04 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:5/17 s:7935921160030 a:7935921342293 f:7935921357763 waiting:182263 process:15470 status:triggered
mar 02 09:17:04 manjaro-su pipewire[1663]: pw.node: (Chromium-183) xrun state:0x72130ba11008 pending:0/1 s:7936778201664 a:7936778317006 f:7935921254902 waiting:115342 process:18446744072852489512 status:awake
mar 02 09:17:04 manjaro-su pipewire[1663]: pw.node: (Firefox-180) xrun state:0x721310352008 pending:0/1 s:7936778201664 a:7936778328986 f:7935921309292 waiting:127322 process:18446744072852531922 status:awake
mar 02 09:17:14 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:17:19 manjaro-su pipewire[1663]: spa.alsa: hdmi:1,1p: (20 suppressed) snd_pcm_avail after recover: Pipe interrotta
mar 02 09:17:43 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:17:58 manjaro-su kernel: hrtimer: interrupt took 214290667 ns
mar 02 09:18:19 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (0 suppressed)
mar 02 09:18:19 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:6/17 s:8007708126056 a:8007708287708 f:8007708308089 waiting:161652 process:20381 status:triggered
mar 02 09:18:19 manjaro-su pipewire[1663]: pw.node: (Firefox-180) xrun state:0x721310352008 pending:0/1 s:8011636614778 a:8011636759930 f:8007708244398 waiting:145152 process:18446744069781036084 status:awake
mar 02 09:18:21 manjaro-su pipewire[1663]: spa.alsa: hdmi:1,1p: (25 suppressed) snd_pcm_avail after recover: Pipe interrotta
mar 02 09:18:25 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (3 suppressed)
mar 02 09:18:25 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:6/17 s:8017065319427 a:8017779557392 f:8017779594403 waiting:714237965 process:37011 status:triggered
mar 02 09:18:25 manjaro-su pipewire[1663]: pw.node: (Chromium-183) xrun state:0x72130ba11008 pending:0/1 s:8017922606546 a:8017065461630 f:8017065467390 waiting:18446744072852406700 process:5760 status:triggered
mar 02 09:18:25 manjaro-su pipewire[1663]: pw.node: (Chromium-176) xrun state:0x721310356008 pending:0/1 s:8017922606546 a:8017922728918 f:8017065474150 waiting:122372 process:18446744072852296848 status:awake
mar 02 09:18:25 manjaro-su pipewire[1663]: pw.node: (Firefox-180) xrun state:0x721310352008 pending:0/1 s:8017922606546 a:8017922735388 f:8017065505120 waiting:128842 process:18446744072852321348 status:awake
mar 02 09:18:35 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (53 suppressed)
mar 02 09:18:35 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:8/17 s:8026779886882 a:8026780055865 f:8026780067895 waiting:168983 process:12030 status:triggered
mar 02 09:18:35 manjaro-su pipewire[1663]: pw.node: (Chromium-171) xrun state:0x72130baf9008 pending:0/1 s:8027636910703 a:8027637035435 f:8026780026475 waiting:124732 process:18446744072852542656 status:awake
mar 02 09:18:35 manjaro-su pipewire[1663]: pw.node: (Chromium-183) xrun state:0x72130ba11008 pending:0/1 s:8027636910703 a:8027637043185 f:8026779913723 waiting:132482 process:18446744072852422154 status:awake
mar 02 09:18:35 manjaro-su pipewire[1663]: pw.node: (Firefox-180) xrun state:0x721310352008 pending:0/1 s:8027636910703 a:8026779923363 f:8026779958953 waiting:18446744072852564276 process:35590 status:triggered
mar 02 09:18:36 manjaro-su pipewire[1663]: spa.alsa: hdmi:1,1p: (5 suppressed) snd_pcm_avail after recover: Pipe interrotta
mar 02 09:18:38 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (4 suppressed)
mar 02 09:18:38 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:6/17 s:8027636969754 a:8027637200908 f:8027637214698 waiting:231154 process:13790 status:triggered
mar 02 09:18:38 manjaro-su pipewire[1663]: pw.node: (Chromium-171) xrun state:0x72130baf9008 pending:0/1 s:8030708413285 a:8027637130456 f:8027637134336 waiting:18446744070638268787 process:3880 status:triggered
mar 02 09:18:38 manjaro-su pipewire[1663]: pw.node: (Chromium-183) xrun state:0x72130ba11008 pending:0/1 s:8030708413285 a:8030708558738 f:8027637139227 waiting:145453 process:18446744070638132105 status:awake
mar 02 09:18:38 manjaro-su pipewire[1663]: pw.node: (Chromium-176) xrun state:0x721310356008 pending:0/1 s:8030708413285 a:8030708567218 f:8027637143587 waiting:153933 process:18446744070638127985 status:awake
mar 02 09:18:38 manjaro-su pipewire[1663]: pw.node: (Firefox-180) xrun state:0x721310352008 pending:0/1 s:8030708413285 a:8030708573498 f:8027637163597 waiting:160213 process:18446744070638141715 status:awake
mar 02 09:19:03 manjaro-su kernel: clocksource: Long readout interval, skipping watchdog check: cs_nsec: 1071424199 wd_nsec: 1071423742
mar 02 09:19:12 manjaro-su pipewire[1663]: spa.alsa: hdmi:1,1p: (13 suppressed) snd_pcm_avail after recover: Pipe interrotta
mar 02 09:19:16 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (13 suppressed)
mar 02 09:19:16 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:0/17 s:8066637645285 a:8066637803157 f:8066637817178 waiting:157872 process:14021 status:triggered
mar 02 09:19:28 manjaro-su pipewire[1663]: spa.alsa: hdmi:1,1p: (3 suppressed) snd_pcm_avail after recover: Pipe interrotta
mar 02 09:19:36 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (3 suppressed)
mar 02 09:19:36 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:8/17 s:8088066586698 a:8088066799332 f:8088066820612 waiting:212634 process:21280 status:triggered
mar 02 09:19:36 manjaro-su pipewire[1663]: pw.node: (Chromium-171) xrun state:0x72130baf9008 pending:0/1 s:8088780776131 a:8088780899083 f:8088066738701 waiting:122952 process:18446744072995391234 status:awake
mar 02 09:19:36 manjaro-su pipewire[1663]: pw.node: (Chromium-176) xrun state:0x721310356008 pending:0/1 s:8088780776131 a:8088780911613 f:8088066752561 waiting:135482 process:18446744072995392564 status:awake
mar 02 09:19:36 manjaro-su pipewire[1663]: pw.node: (Firefox-180) xrun state:0x721310352008 pending:0/1 s:8088780776131 a:8088780918434 f:8088066791362 waiting:142303 process:18446744072995424544 status:awake
mar 02 09:19:37 manjaro-su pipewire[1663]: spa.alsa: hdmi:1,1p: (2 suppressed) snd_pcm_avail after recover: Pipe interrotta
mar 02 09:19:43 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (14 suppressed)
mar 02 09:19:43 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:8/17 s:8095066858310 a:8095067039933 f:8095067047984 waiting:181623 process:8051 status:triggered
mar 02 09:19:43 manjaro-su pipewire[1663]: pw.node: (Chromium-165) xrun state:0x72130bafd008 pending:0/1 s:8095709442461 a:8095709558663 f:8095066948992 waiting:116202 process:18446744073066941945 status:awake
mar 02 09:19:43 manjaro-su pipewire[1663]: pw.node: (Chromium-171) xrun state:0x72130baf9008 pending:0/1 s:8095709442461 a:8095709564754 f:8095066955092 waiting:122293 process:18446744073066941954 status:awake
mar 02 09:19:43 manjaro-su pipewire[1663]: pw.node: (Chromium-183) xrun state:0x72130ba11008 pending:0/1 s:8095709442461 a:8095709578964 f:8095066961402 waiting:136503 process:18446744073066934054 status:awake
mar 02 09:19:43 manjaro-su pipewire[1663]: pw.node: (Chromium-176) xrun state:0x721310356008 pending:0/1 s:8095709442461 a:8095709585664 f:8095066969872 waiting:143203 process:18446744073066935824 status:awake
mar 02 09:19:43 manjaro-su pipewire[1663]: pw.node: (Firefox-180) xrun state:0x721310352008 pending:0/1 s:8095709442461 a:8095709591644 f:8095067015373 waiting:149183 process:18446744073066975345 status:awake
mar 02 09:19:47 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (2 suppressed)
mar 02 09:19:47 manjaro-su pipewire[1663]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x721311879008 pending:6/17 s:8098709534214 a:8099352368615 f:8099352399676 waiting:642834401 process:31061 status:triggered
mar 02 09:19:47 manjaro-su pipewire[1663]: pw.node: (Chromium-171) xrun state:0x72130baf9008 pending:0/1 s:8100066833914 a:8100066967146 f:8098709647396 waiting:133232 process:18446744072352231866 status:awake
mar 02 09:19:47 manjaro-su pipewire[1663]: pw.node: (Chromium-176) xrun state:0x721310356008 pending:0/1 s:8100066833914 a:8098709653946 f:8098709659366 waiting:18446744072352371648 process:5420 status:triggered
mar 02 09:19:47 manjaro-su pipewire[1663]: pw.node: (Firefox-180) xrun state:0x721310352008 pending:0/1 s:8100066833914 a:8100066989437 f:8098709691026 waiting:155523 process:18446744072352253205 status:awake
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u32:0:5259 blocked for more than 122 seconds.
mar 02 09:19:57 manjaro-su kernel: Tainted: P OE 6.12.12-2-MANJARO #1
mar 02 09:19:57 manjaro-su kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u33:14:6539 blocked for more than 122 seconds.
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u33:8:10972 blocked for more than 122 seconds.
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u33:10:11225 blocked for more than 122 seconds.
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u33:13:11585 blocked for more than 122 seconds.
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u33:16:11718 blocked for more than 122 seconds.
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u33:0:12379 blocked for more than 122 seconds.
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u33:1:12380 blocked for more than 122 seconds.
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u33:2:12550 blocked for more than 122 seconds.
mar 02 09:19:57 manjaro-su kernel: INFO: task kworker/u33:3:12606 blocked for more than 122 seconds.
mar 02 09:20:41 manjaro-su kernel: Could not retrieve perf counters (-19)
mar 02 09:20:41 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
mar 02 09:20:41 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
mar 02 09:20:41 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: Secure display: Generic Failure.
mar 02 09:20:41 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
mar 02 09:20:41 manjaro-su systemd-modules-load[361]: Failed to find module 'v4l2loopback_dc'
mar 02 09:20:41 manjaro-su systemd-journald[379]: File /var/log/journal/75b33a2dc1da4002a7b90c23e7e67f40/system.journal corrupted or uncleanly shut down, renaming and replacing.
mar 02 09:20:41 manjaro-su kernel: nvidia: loading out-of-tree module taints kernel.
mar 02 09:20:41 manjaro-su kernel: nvidia: module license 'NVIDIA' taints kernel.
mar 02 09:20:41 manjaro-su kernel: Disabling lock debugging due to kernel taint
mar 02 09:20:41 manjaro-su kernel: nvidia: module license taints kernel.
mar 02 09:20:42 manjaro-su kernel:
mar 02 09:20:42 manjaro-su kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.144.03 Mon Dec 30 17:44:08 UTC 2024
mar 02 09:20:42 manjaro-su kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
mar 02 09:20:42 manjaro-su (udev-worker)[391]: hiddev0: /etc/udev/rules.d/mixxx.usb.rules:25 Only network interfaces can be renamed, ignoring NAME="usb/%k".
mar 02 09:20:42 manjaro-su (udev-worker)[433]: hiddev2: /etc/udev/rules.d/mixxx.usb.rules:25 Only network interfaces can be renamed, ignoring NAME="usb/%k".
mar 02 09:20:42 manjaro-su kernel: VBoxNetAdp: Successfully started.
mar 02 09:20:42 manjaro-su kernel: VBoxNetFlt: Successfully started.
mar 02 09:20:46 manjaro-su dbus-broker-launch[1013]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
mar 02 09:20:47 manjaro-su dbus-broker-launch[1013]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
mar 02 09:20:47 manjaro-su unix_chkpwd[1329]: could not obtain user info (sddm)
mar 02 09:20:47 manjaro-su (systemd)[1328]: PAM failed: Authentication service cannot retrieve authentication info
mar 02 09:20:47 manjaro-su (systemd)[1328]: user@968.service: Failed to set up PAM session: Operation not permitted
mar 02 09:20:47 manjaro-su (systemd)[1328]: user@968.service: Failed at step PAM spawning /usr/lib/systemd/systemd: Operation not permitted
mar 02 09:20:47 manjaro-su systemd[1]: user@968.service: Failed with result 'exit-code'.
mar 02 09:20:47 manjaro-su systemd[1]: Failed to start User Manager for UID 968.
mar 02 09:20:48 manjaro-su nmbd[1350]: [2025/03/02 09:20:48.728651, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
mar 02 09:20:48 manjaro-su nmbd[1350]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
mar 02 09:21:01 manjaro-su systemd-xdg-autostart-generator[1583]: Configuration file /root/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 09:21:01 manjaro-su systemd-xdg-autostart-generator[1583]: Configuration file /root/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 09:21:01 manjaro-su systemd-xdg-autostart-generator[1583]: Configuration file /root/.config/autostart/live-session.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 09:21:01 manjaro-su systemd-xdg-autostart-generator[1583]: Configuration file /root/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 09:21:07 manjaro-su sddm-greeter-qt6[1331]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
mar 02 09:21:07 manjaro-su sddm-helper[1611]: gkr-pam: unable to locate daemon control file
mar 02 09:21:07 manjaro-su systemd-xdg-autostart-generator[1638]: Configuration file /home/ciacnorris/.config/autostart/manjaro-hello.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 09:21:07 manjaro-su systemd-journald[379]: File /var/log/journal/75b33a2dc1da4002a7b90c23e7e67f40/user-1001.journal corrupted or uncleanly shut down, renaming and replacing.
mar 02 09:21:07 manjaro-su systemd-xdg-autostart-generator[1638]: Configuration file /home/ciacnorris/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 09:21:07 manjaro-su dbus-broker-launch[1654]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 02 09:21:07 manjaro-su dbus-broker-launch[1654]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 02 09:21:07 manjaro-su dbus-broker-launch[1654]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 02 09:21:08 manjaro-su systemd-xdg-autostart-generator[1707]: Configuration file /home/ciacnorris/.config/autostart/manjaro-hello.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 09:21:08 manjaro-su systemd-xdg-autostart-generator[1707]: Configuration file /home/ciacnorris/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 02 09:21:08 manjaro-su wireplumber[1645]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
mar 02 09:21:08 manjaro-su wireplumber[1645]: spa.bluez5: BlueZ system service is not available
mar 02 09:21:09 manjaro-su kded6[1794]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
mar 02 09:21:09 manjaro-su kded6[1794]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
mar 02 09:21:09 manjaro-su kconf_update[1896]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
mar 02 09:21:09 manjaro-su kconf_update[1896]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
mar 02 09:21:09 manjaro-su kconf_update[1896]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
mar 02 09:21:09 manjaro-su kconf_update[1896]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
mar 02 09:21:09 manjaro-su kconf_update[1896]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
mar 02 09:21:09 manjaro-su kconf_update[1896]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
mar 02 09:21:09 manjaro-su kded6[1794]: kf.bluezqt: PendingCall Error: "The name is not activatable"
mar 02 09:21:09 manjaro-su kded6[1794]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1.monitor"
mar 02 09:21:09 manjaro-su kded6[1794]: kf.bluezqt: PendingCall Error: "Could not activate remote peer 'org.bluez': unit failed"
mar 02 09:21:09 manjaro-su kded6[1794]: kscreen.kded: PowerDevil SuspendSession action not available!
mar 02 09:21:09 manjaro-su baloo_file[1727]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.39'
mar 02 09:21:09 manjaro-su baloo_file[1727]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.43'
mar 02 09:21:09 manjaro-su org_kde_powerdevil[1935]: Failed to create wl_display (File o cartella non trovati)
mar 02 09:21:09 manjaro-su plasmashell[1856]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
mar 02 09:21:09 manjaro-su plasmashell[1856]: Toolbox not loading, toolbox package is either invalid or disabled.
mar 02 09:21:10 manjaro-su plasmashell[1856]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
mar 02 09:21:10 manjaro-su org_kde_powerdevil[1935]: busno=3, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
mar 02 09:21:10 manjaro-su org_kde_powerdevil[1935]: busno=3, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
mar 02 09:21:10 manjaro-su org_kde_powerdevil[1935]: busno=3, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
mar 02 09:21:10 manjaro-su org_kde_powerdevil[1935]: busno=3, All features that should not exist detected. Monitor does not indicate unsupported
mar 02 09:21:10 manjaro-su org_kde_powerdevil[1935]: org.kde.powerdevil: [DDCutilDetector]: Failed to initialize callback
mar 02 09:21:10 manjaro-su kdeconnectd[2110]: 2025-03-02T09:21:10 default: Cannot find a compatible running Bluez. Please check the Bluez installation. QtBluetooth requires at least BlueZ version 5.
mar 02 09:21:10 manjaro-su plasmashell[1856]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
mar 02 09:21:10 manjaro-su kdeconnectd[2110]: 2025-03-02T09:21:10 kdeconnect.core: No local bluetooth adapter found
mar 02 09:21:10 manjaro-su backlighthelper[2149]: org.kde.powerdevil: no kernel backlight interface found
mar 02 09:21:10 manjaro-su org_kde_powerdevil[1935]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 02 09:21:10 manjaro-su org_kde_powerdevil[1935]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
mar 02 09:21:11 manjaro-su org_kde_powerdevil[1935]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mar 02 09:21:11 manjaro-su org_kde_powerdevil[1935]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 02 09:21:11 manjaro-su kdeconnectd[2183]: QThreadStorage: Thread 0x5d0870586b50 exited after QThreadStorage 8 destroyed
mar 02 09:21:11 manjaro-su kdeconnectd[2183]: QThreadStorage: Thread 0x5d0870586b50 exited after QThreadStorage 7 destroyed
mar 02 09:21:11 manjaro-su kdeconnectd[2183]: QThreadStorage: Thread 0x5d0870586b50 exited after QThreadStorage 6 destroyed
mar 02 09:21:11 manjaro-su kdeconnectd[2183]: QThreadStorage: Thread 0x5d0870586b50 exited after QThreadStorage 2 destroyed
mar 02 09:21:11 manjaro-su DiscoverNotifier[2213]: couldn't load "/usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Impossibile caricare la libreria /usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so: libpackagekitqt6.so.1: impossibile aprire il file oggetto condiviso: File o directory non esistente"
mar 02 09:21:11 manjaro-su akonadi_control[2344]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 02 09:21:12 manjaro-su plasmashell[1856]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
mar 02 09:21:12 manjaro-su baloo_file[1727]: kf.baloo: KDE Baloo File Indexer has reached the inotify folder watch limit. File changes will be ignored.
mar 02 09:21:12 manjaro-su plasmashell[1856]: qt.core.qabstractitemmodel.checkindex: Index QModelIndex(-1,-1,0x0,QObject(0x0)) is not valid (expected valid)
mar 02 09:21:12 manjaro-su plasmashell[1856]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1.monitor"
mar 02 09:21:18 manjaro-su akonadiserver[2362]: org.kde.pim.akonadiserver: database server stopped unexpectedly
mar 02 09:21:18 manjaro-su akonadiserver[2362]: org.kde.pim.akonadiserver: Database process exited unexpectedly during initial connection!
mar 02 09:21:18 manjaro-su akonadiserver[2362]: org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
mar 02 09:21:18 manjaro-su akonadiserver[2362]: org.kde.pim.akonadiserver: arguments: QList("--defaults-file=/home/ciacnorris/.local/share/akonadi/mysql.conf", "--datadir=/home/ciacnorris/.local/share/akonadi/db_data/", "--socket=/run/user/1001/akonadi/mysql.socket", "--pid-file=/run/user/1001/akonadi/mysql.pid")
mar 02 09:21:18 manjaro-su akonadiserver[2362]: org.kde.pim.akonadiserver: stdout: ""
mar 02 09:21:18 manjaro-su akonadiserver[2362]: org.kde.pim.akonadiserver: stderr: "/usr/bin/mysqld: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadbd' instead\n"
mar 02 09:21:18 manjaro-su akonadiserver[2362]: org.kde.pim.akonadiserver: exit code: 1
mar 02 09:21:18 manjaro-su akonadiserver[2362]: org.kde.pim.akonadiserver: process error: "Errore sconosciuto"
mar 02 09:21:18 manjaro-su akonadiserver[2362]: org.kde.pim.akonadiserver: See "/home/ciacnorris/.local/share/akonadi/db_data/mysql.err" for more details
mar 02 09:21:18 manjaro-su kalendarac[2215]: org.kde.pim.akonadicore: Job error: "" for collection: QList()
mar 02 09:21:26 manjaro-su firefox[2454]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:21:26 manjaro-su firefox[2454]: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:21:26 manjaro-su firefox[2454]: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:21:26 manjaro-su firefox[2454]: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:21:26 manjaro-su firefox[2454]: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:21:27 manjaro-su firefox[2454]: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:21:27 manjaro-su firefox[2454]: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:21:27 manjaro-su firefox[2454]: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:21:27 manjaro-su firefox[2454]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:21:27 manjaro-su firefox[2454]: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
mar 02 09:25:08 manjaro-su baloo_file_extractor[4529]: kf.baloo: "/home/ciacnorris/.cache/mozilla/firefox/h8vv0ay6.default-release-1597398977016/cache2/index" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mar 02 09:27:12 manjaro-su baloo_file_extractor[4529]: kf.baloo: "/home/ciacnorris/.cache/mozilla/firefox/h8vv0ay6.default-release-1597398977016/cache2/entries/D0F48A0632B6C451791F4257697E861961F06A6F" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
mar 02 09:28:18 manjaro-su kdeconnectd[2110]: 2025-03-02T09:28:18 default: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 02 09:28:18 manjaro-su kdeconnectd[2110]: 2025-03-02T09:28:18 kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
mar 02 09:28:18 manjaro-su kdeconnectd[2110]: 2025-03-02T09:28:18 kdeconnect.plugin.battery: Total quantity of batteries found: 1
mar 02 09:28:18 manjaro-su kdeconnectd[2110]: 2025-03-02T09:28:18 kdeconnect.plugin.battery: Primary Battery seems to have been removed. Suspending packets until it is reconnected.
mar 02 09:28:18 manjaro-su kdeconnectd[2110]: 2025-03-02T09:28:18 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1.monitor"
mar 02 09:29:30 manjaro-su kdeconnectd[2110]: 2025-03-02T09:29:30 kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/ciacnorris/.local/share/kpeoplevcard/kdeconnect-9d1ab3bf_d051_4dfb_a8c9_19ad366744d0/748i2c0837ca8d0c7d43.3789r3348-2E402A52303A2A36522A50502A422A42422A303A324032442A343A403A48483A443A.2146r5012-2E402A52303A2A36522A50502A422A42422A303A324032442A343A403A48483A443A.1782r5257-2E402A52303A2A36522A50502A422A42422A303A324032442A343A403A48483A443A.vcf"
mar 02 09:29:30 manjaro-su kdeconnectd[2110]: 2025-03-02T09:29:30 kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/ciacnorris/.local/share/kpeoplevcard/kdeconnect-9d1ab3bf_d051_4dfb_a8c9_19ad366744d0/748i17effff208cd8bbc.3789r2689-3A4C324432364C524848462E524050524C2A40324C3A2E4C322A503A5446303A2E46442E38324830.2146r3821-3A4C324432364C524848462E524050524C2A40324C3A2E4C322A503A5446303A2E46442E38324830.1782r4714-3A4C324432364C524848462E524050524C2A40324C3A2E4C322A503A5446303A2E46442E38324830.vcf"
mar 02 09:30:12 manjaro-su xdg-desktop-por[1732]: Failed to ReadAll() from Settings implementation: È stato raggiunto il timeout
mar 02 09:30:15 manjaro-su kernel: hrtimer: interrupt took 214292020 ns
mar 02 09:31:45 manjaro-su sddm-helper[1611]: Signal received: SIGTERM
mar 02 09:31:45 manjaro-su sddm[1162]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
mar 02 09:31:45 manjaro-su sddm[1162]: Auth: sddm-helper (--socket /tmp/sddm-auth-07eafbe5-b039-4fd1-b804-942c435e6667 --id 1 --start /usr/bin/startplasma-x11 --user system) crashed (exit code 1)
mar 02 09:31:45 manjaro-su sddm[1162]: Auth: sddm-helper exited with 1
mar 02 09:31:46 manjaro-su sddm[1162]: Signal received: SIGTERM
mar 02 09:31:46 manjaro-su kglobalacceld[1725]: The X11 connection broke (error 1). Did the X11 server die?
mar 02 09:31:46 manjaro-su kglobalacceld[1725]: The X11 connection broke: I/O error (code 1)
mar 02 09:31:46 manjaro-su kalendarac[2215]: The X11 connection broke (error 1). Did the X11 server die?
mar 02 09:31:46 manjaro-su kded6[1794]: The X11 connection broke: I/O error (code 1)
mar 02 09:31:46 manjaro-su kded6[1794]: kf.notifications: Had queued notifications on destruction. Was the eventloop running?
mar 02 09:31:46 manjaro-su kded6[1794]: kf.notifications: Playing audio notification failed: Destroyed
mar 02 09:31:46 manjaro-su pamac-tray-plasma[2220]: kf.statusnotifieritem: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
mar 02 09:31:46 manjaro-su msm_kde_notifier[2176]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
mar 02 09:31:46 manjaro-su kded6[1794]: QThreadStorage: Thread 0x5bdf73eba4c0 exited after QThreadStorage 10 destroyed
mar 02 09:31:46 manjaro-su kded6[1794]: QThreadStorage: Thread 0x5bdf73eba4c0 exited after QThreadStorage 9 destroyed
mar 02 09:31:46 manjaro-su kded6[1794]: QThreadStorage: Thread 0x5bdf73eba4c0 exited after QThreadStorage 8 destroyed
mar 02 09:31:46 manjaro-su kded6[1794]: QThreadStorage: Thread 0x5bdf73eba4c0 exited after QThreadStorage 7 destroyed
mar 02 09:31:46 manjaro-su kded6[1794]: QThreadStorage: Thread 0x5bdf73eba4c0 exited after QThreadStorage 6 destroyed
mar 02 09:31:46 manjaro-su kded6[1794]: QThreadStorage: Thread 0x5bdf73eba4c0 exited after QThreadStorage 1 destroyed
mar 02 09:31:46 manjaro-su kded6[1794]: QThreadStorage: Thread 0x5bdf73eba4c0 exited after QThreadStorage 0 destroyed
mar 02 09:31:46 manjaro-su ksmserver[1792]: The X11 connection broke (error 1). Did the X11 server die?
mar 02 09:31:46 manjaro-su ksmserver[1792]: QThreadStorage: Thread 0x57f0e0078980 exited after QThreadStorage 7 destroyed
mar 02 09:31:46 manjaro-su ksmserver[1792]: QThreadStorage: Thread 0x57f0e0078980 exited after QThreadStorage 6 destroyed
mar 02 09:31:46 manjaro-su ksmserver[1792]: QThreadStorage: Thread 0x57f0e0078980 exited after QThreadStorage 0 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 13 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 10 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 9 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 8 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 7 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 6 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 5 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 4 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 2 destroyed
mar 02 09:31:47 manjaro-su kdeconnectd[2110]: QThreadStorage: Thread 0x62bd08a56b50 exited after QThreadStorage 0 destroyed
mar 02 09:31:48 manjaro-su pipewire[1644]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) graph xrun not-triggered (0 suppressed)
mar 02 09:31:48 manjaro-su pipewire[1644]: pw.node: (alsa_output.pci-0000_27_00.1.hdmi-stereo-extra1-59) xrun state:0x7334d4679008 pending:1/1 s:557273715787 a:557273721937 f:557273739937 waiting:6150 process:18000 status:triggered
mar 02 09:31:51 manjaro-su systemd[1631]: plasma-kded6.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: plasma-kglobalaccel.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: app-org.kde.discover.notifier@autostart.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: plasma-gmenudbusmenuproxy.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: plasma-powerdevil.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: app-org.kde.kalendarac@autostart.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: plasma-xembedsniproxy.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: app-msm_kde_notifier@autostart.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: app-pamac\x2dtray\x2dplasma@autostart.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: plasma-polkit-agent.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: at-spi-dbus-bus.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:31:51 manjaro-su systemd[1631]: at-spi-dbus-bus.service: Main process exited, code=killed, status=9/KILL
mar 02 09:31:51 manjaro-su systemd[1631]: at-spi-dbus-bus.service: Failed with result 'timeout'.
mar 02 09:31:52 manjaro-su kactivitymanagerd[1929]: The X11 connection broke (error 1). Did the X11 server die?
mar 02 09:31:52 manjaro-su systemd[1631]: dbus-:1.62-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
mar 02 09:31:56 manjaro-su systemd[1631]: plasma-kded6.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:31:56 manjaro-su systemd[1631]: plasma-kglobalaccel.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:31:56 manjaro-su systemd[1631]: app-org.kde.discover.notifier@autostart.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:31:56 manjaro-su systemd[1631]: plasma-gmenudbusmenuproxy.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:31:56 manjaro-su systemd[1631]: plasma-powerdevil.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:31:56 manjaro-su systemd[1631]: app-org.kde.kalendarac@autostart.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:31:57 manjaro-su systemd[1631]: plasma-xembedsniproxy.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:31:57 manjaro-su systemd[1631]: plasma-polkit-agent.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:31:57 manjaro-su systemd[1631]: app-pamac\x2dtray\x2dplasma@autostart.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:31:57 manjaro-su systemd[1631]: app-msm_kde_notifier@autostart.service: Processes still around after SIGKILL. Ignoring.
mar 02 09:32:02 manjaro-su systemd[1631]: plasma-kded6.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:02 manjaro-su systemd[1631]: plasma-gmenudbusmenuproxy.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:02 manjaro-su systemd[1631]: plasma-powerdevil.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:02 manjaro-su systemd[1631]: app-org.kde.kalendarac@autostart.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:02 manjaro-su systemd[1631]: app-org.kde.discover.notifier@autostart.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:02 manjaro-su systemd[1631]: plasma-kglobalaccel.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:02 manjaro-su systemd[1631]: plasma-xembedsniproxy.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:02 manjaro-su systemd[1631]: app-msm_kde_notifier@autostart.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:02 manjaro-su systemd[1631]: app-pamac\x2dtray\x2dplasma@autostart.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:02 manjaro-su systemd[1631]: plasma-polkit-agent.service: State 'final-sigterm' timed out. Killing.
mar 02 09:32:06 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-kded6.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-kded6.service: Failed with result 'timeout'.
mar 02 09:32:07 manjaro-su systemd[1631]: app-msm_kde_notifier@autostart.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: app-msm_kde_notifier@autostart.service: Failed with result 'timeout'.
mar 02 09:32:07 manjaro-su systemd[1631]: app-org.kde.kalendarac@autostart.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: app-org.kde.kalendarac@autostart.service: Failed with result 'timeout'.
mar 02 09:32:07 manjaro-su systemd[1631]: app-org.kde.discover.notifier@autostart.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: app-org.kde.discover.notifier@autostart.service: Failed with result 'timeout'.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-kglobalaccel.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-kglobalaccel.service: Failed with result 'timeout'.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-gmenudbusmenuproxy.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-gmenudbusmenuproxy.service: Failed with result 'timeout'.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-powerdevil.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-powerdevil.service: Failed with result 'timeout'.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-xembedsniproxy.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-xembedsniproxy.service: Failed with result 'timeout'.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-polkit-agent.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: plasma-polkit-agent.service: Failed with result 'timeout'.
mar 02 09:32:07 manjaro-su systemd[1631]: app-pamac\x2dtray\x2dplasma@autostart.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:32:07 manjaro-su systemd[1631]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'timeout'.
mar 02 09:32:08 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:09 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:10 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:11 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:20 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:21 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:22 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:23 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:24 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:26 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:28 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:32:28 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:29 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:30 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:32:30 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:30 manjaro-su wireplumber[1645]: pw.core: 0x607bf1d3cee0: leaked proxy 0x607bf1ce3be0 id:3
mar 02 09:32:30 manjaro-su wireplumber[1645]: pw.core: 0x607bf1d3cee0: leaked proxy 0x607bf1d14860 id:4
mar 02 09:32:30 manjaro-su wireplumber[1645]: pw.core: 0x607bf1d3cee0: leaked proxy 0x607bf1fff680 id:5
mar 02 09:32:30 manjaro-su wireplumber[1645]: pw.core: 0x607bf1d3cee0: leaked proxy 0x607bf1cf5910 id:8
mar 02 09:32:31 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:32:31 manjaro-su systemd[1631]: plasma-ksmserver.service: Failed with result 'exit-code'.
mar 02 09:32:33 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:34 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:32:38 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:39 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 28b4 wait reg 28c6
mar 02 09:32:46 manjaro-su sddm[1162]: QProcess: Destroyed while process ("/usr/bin/X") is still running.
mar 02 09:32:48 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:32:51 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:32:52 manjaro-su kernel: INFO: task kworker/u33:6:1619 blocked for more than 122 seconds.
mar 02 09:32:52 manjaro-su kernel: Tainted: P OE 6.12.12-2-MANJARO #1
mar 02 09:32:52 manjaro-su kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
mar 02 09:32:52 manjaro-su kernel: INFO: task kworker/u33:8:1621 blocked for more than 122 seconds.
mar 02 09:32:52 manjaro-su kernel: INFO: task kworker/u33:12:1625 blocked for more than 122 seconds.
mar 02 09:32:52 manjaro-su kernel: INFO: task kworker/u33:14:1627 blocked for more than 122 seconds.
mar 02 09:32:52 manjaro-su kernel: INFO: task kworker/u33:15:1628 blocked for more than 122 seconds.
mar 02 09:32:54 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:32:55 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:32:56 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:32:59 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:33:00 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:33:05 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:33:16 manjaro-su systemd[1]: sddm.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:33:16 manjaro-su systemd[1]: sddm.service: Main process exited, code=killed, status=9/KILL
mar 02 09:33:16 manjaro-su systemd[1631]: plasma-kwin_x11.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:33:16 manjaro-su systemd[1631]: plasma-kaccess.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:33:16 manjaro-su systemd[1631]: plasma-xdg-desktop-portal-kde.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:33:17 manjaro-su systemd[1631]: kde-baloo.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:33:17 manjaro-su systemd[1631]: kde-baloo.service: Failed with result 'timeout'.
mar 02 09:33:23 manjaro-su systemd[1631]: plasma-kactivitymanagerd.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:33:24 manjaro-su kernel: amdgpu 0000:27:00.0: amdgpu: failed to write reg 1a6f4 wait reg 1a706
mar 02 09:34:00 manjaro-su systemd[1631]: app-firefox@cc99f45f403240e3840fb4aee323a972.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:34:00 manjaro-su systemd[1631]: dbus-:1.5-org.kde.kdeconnect@0.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:34:30 manjaro-su systemd[1]: user@1001.service: State 'stop-sigterm' timed out. Killing.
mar 02 09:34:31 manjaro-su systemd[1]: user@1001.service: Main process exited, code=killed, status=9/KILL
mar 02 09:34:46 manjaro-su systemd[1]: sddm.service: State 'final-sigterm' timed out. Killing.
mar 02 09:34:55 manjaro-su kernel: INFO: task kworker/R-ttm:229 blocked for more than 122 seconds.
mar 02 09:34:55 manjaro-su kernel: Tainted: P OE 6.12.12-2-MANJARO #1
mar 02 09:34:55 manjaro-su kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
mar 02 09:34:55 manjaro-su kernel: INFO: task Xorg:1171 blocked for more than 122 seconds.
mar 02 09:34:55 manjaro-su kernel: INFO: task kworker/u33:6:1619 blocked for more than 245 seconds.
mar 02 09:34:55 manjaro-su kernel: INFO: task kworker/u33:8:1621 blocked for more than 245 seconds.
mar 02 09:34:55 manjaro-su kernel: INFO: task kworker/u33:12:1625 blocked for more than 245 seconds.
mar 02 09:36:16 manjaro-su systemd[1]: sddm.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:36:16 manjaro-su systemd[1]: sddm.service: Failed with result 'timeout'.
mar 02 09:36:31 manjaro-su systemd[1]: user@1001.service: Processes still around after final SIGKILL. Entering failed mode.
mar 02 09:36:31 manjaro-su systemd[1]: user@1001.service: Failed with result 'timeout'.
mar 02 09:36:32 manjaro-su dbus-broker-launch[1013]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
mar 02 09:36:34 manjaro-su systemd[1]: Failed unmounting Temporary Directory /tmp.
mar 02 09:37:18 manjaro-su systemd-journald[379]: Failed to send WATCHDOG=1 notification message: Connection refused
