On my brand new system and I am experiencing seemingly random system crashes. Out of the blue, the mousepointer will begin stuttering and become very sluggish for about 10 seconds, then the machine just reboots.
At first I ran Gnome, where it happened more or less daily. Then I reinstalled XFCE edition, and now it happens about once a week. That is, I have found a way to reproduce it: If I have Deluge running with a bunch of active torrents, and play a video in VLC at the same time it will happen within 10-15 minutes. When running Deluge only it will crash within a couple of hours.
I also ran Deluge and VLC simultaneously on Windows for 2-3 hours without any symptoms, so I doubt this is a hardware issue.
The log from journalctl does not yield anything interesting as far as I can tell, but really my knowledge of these things is limited. I notice that there is nothing at the exact times when the crashes occur.
In one case while I was running Gnome, I came back from a walk and all the icons on the Gnome desktop had been replaced with dummy icons. When I rebooted the machine GRUB was gone and it booted straight into Windows. The data on the Manjaro-partition was all good, though. Don’t know if these issues are related.
What I have tried:
Disable global c-states in BIOS
This did not help. Also I doubt that this is the problem, since grep . /sys/devices/system/cpu/cpu0/cpuidle/state*/name
outputs (without disabled c-states in BIOS):
/sys/devices/system/cpu/cpu0/cpuidle/state0/name:POLL
/sys/devices/system/cpu/cpu0/cpuidle/state1/name:C1
/sys/devices/system/cpu/cpu0/cpuidle/state2/name:C2
/sys/devices/system/cpu/cpu0/cpuidle/state3/name:C3
This means that the max c-state is 3, right? On some systems c-state 6 can cause problems, but that does not seem to be in play here.
Disable NVMe power states
Did this by adding nvme_core.default_ps_max_latency_us=0
to GRUB. Did not help. I assume it is switched off since nvme get-feature /dev/nvme0n1 -f 0x0c -H
outputs Autonomous Power State Transition Enable (APSTE): Disabled
Lowering speed of RAM
Tried lowering speed of RAM from 3200MHz (advertised speed) to 2400. Had no effect.
Kernels 5.10.x and 5.11.x
Both of these has the same issue.
CPU stress tests
Running s-tui and Prime95 on Windows for at least 45 minutes made the fan speed up like I have never witnessed before, but did not trigger the issue.
Windows memory check (mdsched.exe)
Reports no errors.
Using another wall socket
The extension cord I was using was one of those with an on/off switch. The switch has seemed to be unstable, so I switched to another wall socket. Unfortunately it did not help.
Output from journalctl around the time of one of the instances:
april 26 19:46:54 johs-pc kernel: audit: type=1130 audit(1619459214.492:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd>
april 26 19:47:24 johs-pc systemd[1]: systemd-hostnamed.service: Succeeded.
april 26 19:47:24 johs-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=>
april 26 19:47:24 johs-pc kernel: audit: type=1131 audit(1619459244.528:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd>
april 26 19:47:24 johs-pc audit: BPF prog-id=18 op=UNLOAD
april 26 19:47:24 johs-pc audit: BPF prog-id=17 op=UNLOAD
april 26 19:47:24 johs-pc kernel: audit: type=1334 audit(1619459244.652:107): prog-id=18 op=UNLOAD
april 26 19:47:24 johs-pc kernel: audit: type=1334 audit(1619459244.652:108): prog-id=17 op=UNLOAD
-- Boot fc730bf8e8b34d86999ea1d45598d4af --
april 26 19:50:42 johs-pc kernel: Linux version 5.11.14-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Apr 14 08:25:29 UTC 2021
april 26 19:50:42 johs-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=c398a086-6f8a-42e7-8d87-54c4578033a3 rw quiet apparmor=1 security=apparmor udev.log_priority=3 nvme_core.default_ps>
april 26 19:50:42 johs-pc kernel: KERNEL supported cpus:
april 26 19:50:42 johs-pc kernel: Intel GenuineIntel
april 26 19:50:42 johs-pc kernel: AMD AuthenticAMD
april 26 19:50:42 johs-pc kernel: Hygon HygonGenuine
april 26 19:50:42 johs-pc kernel: Centaur CentaurHauls
april 26 19:50:42 johs-pc kernel: zhaoxin Shanghai
april 26 19:50:42 johs-pc kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
april 26 19:50:42 johs-pc kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
april 26 19:50:42 johs-pc kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
april 26 19:50:42 johs-pc kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
april 26 19:50:42 johs-pc kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
april 26 19:50:42 johs-pc kernel: BIOS-provided physical RAM map:
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009c7efff] usable
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x0000000009c7f000-0x0000000009ffffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20efff] ACPI NVS
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000000a20f000-0x000000000affffff] usable
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000000b020000-0x0000000098801fff] usable
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x0000000098802000-0x0000000099df1fff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x0000000099df2000-0x000000009a029fff] ACPI data
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000009a02a000-0x000000009bab4fff] ACPI NVS
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000009bab5000-0x000000009c961fff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000009c962000-0x000000009c9fefff] type 20
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000009c9ff000-0x000000009dffffff] usable
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x000000009e000000-0x00000000bfffffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fd600000-0x00000000fd6fffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
april 26 19:50:42 johs-pc kernel: BIOS-e820: [mem 0x0000000100000000-0x000000043e2fffff] usable
Output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.11.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
security=apparmor udev.log_priority=3 nvme_core.default_ps_max_latency_us=0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
Type: Desktop System: Komplett product: Komplett PC v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 4301 date: 03/04/2021
RAM: total: 15.07 GiB used: 3.25 GiB (21.6%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM_A1 size: No Module Installed
Device-2: DIMM_A2 size: 8 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Kingston part-no: KHX3200C18D4/8G
serial: <filter>
Device-3: DIMM_B1 size: No Module Installed
Device-4: DIMM_B2 size: 8 GiB speed: 3200 MT/s type: DDR4
serial: <filter>
Info: 6-Core model: AMD Ryzen 5 PRO 4650G with Radeon Graphics socket: AM4
bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96)
stepping: 1 microcode: 8600106 cache: L1: 384 KiB L2: 3 MiB L3: 8 MiB
bogomips: 88668
Speed: 1397 MHz min/max: 1400/3700 MHz base/boost: 3700/4300 boost: enabled
volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz): 1: 1397 2: 1830 3: 1397
4: 1397 5: 1709 6: 1397 7: 1397 8: 1397 9: 2863 10: 1518 11: 1386 12: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 09:00.0 chip-ID: 1002:1636 class-ID: 0300
Display: server: X.Org 1.20.11 driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.11.14-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.2 direct render: Yes
Device-1: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 09:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 09:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Mackie Designs Onyx Blackjack type: USB driver: snd-usb-audio
bus-ID: 3-1:2 chip-ID: 0a73:0010 class-ID: 0102
Sound Server-1: ALSA v: k5.11.14-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.17 running: no
Sound Server-4: PipeWire v: 0.3.25 running: no
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-2: Realtek RTL8192CE PCIe Wireless Network Adapter vendor: ASUSTeK
driver: rtl8192ce v: kernel port: c000 bus-ID: 04:00.0 chip-ID: 10ec:8178
class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Local Storage: total: 5.44 TiB used: 118.8 GiB (2.1%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 211210WD temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37960G
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: K1B3 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD Elements 25A3 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B serial: <filter> rev: 1019 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Verbatim model: STORE N GO
size: 14.75 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00 scheme: MBR
ID-1: / raw-size: 734.07 GiB size: 721.48 GiB (98.28%)
used: 118.77 GiB (16.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: c398a086-6f8a-42e7-8d87-54c4578033a3
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 25.6 MiB (10.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: SYSTEM uuid: 6E20-5105
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 196.69 GiB fs: ntfs label: Windows
uuid: 5C0A20F70A20D036
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 500 MiB fs: ntfs
label: Recovery tools uuid: 8018214D1821438E
ID-4: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System Reserved
uuid: 083643023642EFEC
ID-5: /dev/sda2 maj-min: 8:2 size: 98.46 GiB fs: ntfs label: N/A
uuid: 7CCC44A3CC445992
ID-6: /dev/sda3 maj-min: 8:3 size: 795.69 GiB fs: ext4 label: N/A
uuid: 43b36098-6834-4fc2-80c6-3ff8a4910117
ID-7: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ext4 label: ElementsJohs
uuid: 35d2289c-e2aa-4951-a2a1-657936e58196
ID-8: /dev/sdc1 maj-min: 8:33 size: 14.75 GiB fs: ntfs label: N/A
uuid: 03C0A47A7F1FA59C
Device-1: 1-5:2 info: Primax USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0461:4d22 class-ID: 0301
Device-1: 2-1:2 info: Western Digital Elements Desktop (WDBWLG)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 8mA chip-ID: 1058:25a3 class-ID: 0806 serial: <filter>
Device-2: 2-3:3 info: Verbatim Flash Drive (StorenGo) type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 304mA
chip-ID: 18a5:0243 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Mackie Designs Onyx Blackjack type: Audio
driver: snd-usb-audio interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-1:2 info: Logitech Illuminated Keyboard type: Keyboard,Mouse
power: 300mA chip-ID: 046d:c318 class-ID: 0300
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 28.2 C mobo: 0 C gpu: amdgpu temp: 25.0 C
Processes: 333 Uptime: 4h 05m wakeups: 0 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1196 lib: 333
flatpak: 0 Shell: Bash (sudo) v: 5.1.0 running-in: xfce4-terminal
inxi: 3.3.04
