Btw, after running hid-recorder, you can also run “sudo hid-replay hid_reports” to see if the problem can be reproduced.
I froze for several swipes.
When I replay the log file the cursor seems to make the same freeze, but it only moves on the upper edge of the screen; my touchpad movements were done in the middle part of the screen.
Here’s what I see on my screen,
(left to right)
…a…b…
(right to left)
…c…
I see three pauses at point a, b and c respective. All the movements are done in a non-stop, continuous way, right?
Can you try GitHub - coiby/standalone_i2c_hid at polling_regardless_of_gpio_pin_state and then paste the result of hid-recorder?
Hello @coiby
I still get freezes with the github code. DO you need some more traces?
Thank you for providing the feedback! It seems your touchpad hasn’t been set up properly by the driver. Is it possible for me to access your OS via Teamviewer to debug this issue?
Hello @coiby I’ve send you a private message
Thank you! Meanwhile can you do me a favor to show me the result of sudo cat /sys/kernel/debug/gpio|grep -A1 "pin16\s"?
$ sudo cat /sys/kernel/debug/gpio|grep -A1 "pin16\s"
pin16 interrupt is disabled| interrupt is masked| disable wakeup in S0i3 state| disable wakeup in S3 state|
disable wakeup in S4/S5 state| input is low| pull-up is disabled| pull-down is enabled| output is disabled| 0x40000
I’m going to submit a patch soon to fix another touchpad (https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1887190) and I need to make sure it won’t cause any regression.
On my laptop the output looks like this
pin16 Level trigger| Active low| interrupt is enabled| interrupt is unmasked| enable wakeup in S0i3 state| disable wakeup in S3 state|
disable wakeup in S4/S5 state| input is high| 4k pull-up| pull-up is enabled| Pull-down is disabled| output is disabled| 0x153b40
Hi guys, is there any progress on this? I’m using ASUS M513 and Ubuntu 20.04 and I can confirm the same touchpad mouse freezes that are random. The touchpad scroll works all the time as well. I noticed the same issues using GParted bootable iso. It works fine on Windows 10 so it can’t be a hardware issue. Also I tried both synaptics driver and libinput
@coiby do you have some new ideas about this problem? I could give you remote access again if you need it
Any news on this issue?
I recently got a Lenovo Thinkpad T490 and in the past week, started to experience this problem…when using the trackpoint or when using trackpad.
Very frustrating…
Hope there’s progress on this problem.
Thanks,
Mark
Hi @ArchiMark,
Could you share your laptop’s ACPI DST? https://bugzilla.kernel.org/show_bug.cgi?id=212379 provides a new clue to investigate the root cause of this bug.
You can use the following commands to get dsdt.dsl (you need to install acpica which provides iasl)
a) sudo acpidump > acpidata.out
b) acpixtract -sSSDT acpidata.out
c) acpixtract -sDSDT acpidata.out
d) iasl -da dsdt.dat ssdt*.dat
If the steps after a) fail, you can simply upload acpidata.out.
If you can understand the discussion in https://bugzilla.kernel.org/show_bug.cgi?id=212379, you can even check if the workaround in https://bugzilla.kernel.org/show_bug.cgi?id=212379#c31 works .
I had similar issue, here is my post with solution
Hi @coiby
Sorry for the very very late reply…
I had another issue with laptop and Lenovo tech guy came and decided that trackpoint unit was problem. So, he replaced keyboard / trackpoint.
Thank you @Caraffa it seems that using the latest RT kernel is the solution for this problem.
I will get back if I get the error again.
I have been experiencing the same random short freeze of touchpad on my laptop as well.
$ sudo inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=06d7363a-23c3-4c3d-97e3-3bc65484e084 ro quiet apparmor=1
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513IA_KM513IA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X513IA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X513IA.300 date: 06/05/2020
ID-1: BAT0 charge: 28.9 Wh (87.8%) condition: 32.9/42.1 Wh (78.1%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 503
RAM: total: 7.25 GiB used: 3.01 GiB (41.4%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM 0 size: 4 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Hynix part-no: HMA851S6CJR6N-XN serial: N/A
Device-2: DIMM 0 size: 4 GiB speed: 3200 MT/s type: DDR4
total: 64 bits manufacturer: Samsung part-no: M471A5244CB0-CWE
serial: <filter>
Info: model: AMD Ryzen 7 4700U with Radeon Graphics socket: FP6 bits: 64
type: MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1475 high: 2000 min/max: 1400/2000 boost: enabled
base/boost: 2000/4200 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 2000 6: 1400 7: 1400 8: 1400 bogomips: 31958
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 2-2:4 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp3s0f3u2 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 1.14 TiB used: 79.67 GiB (6.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 80001C00 temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 24d 20h cycles: 5,266
read-units: 52,307,627 [26.7 TB] written-units: 9,075,129 [4.64 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SPZX-80Z10T2 family: Blue Mobile (SMR) size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1A04 temp: 31 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 162d 2h cycles: 5264 Old-Age:
g-sense error rate: 413
ID-1: / raw-size: 52.2 GiB size: 51.13 GiB (97.95%) used: 24.09 GiB (47.1%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 06d7363a-23c3-4c3d-97e3-3bc65484e084
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 66.8 MiB (26.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: SYSTEM uuid: DA44-C033
ID-3: /home raw-size: 34.8 GiB size: 34 GiB (97.71%)
used: 30.41 GiB (89.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: N/A uuid: 941c21f5-3c1e-45ab-8989-ce9c68b0c218
ID-4: /run/timeshift/backup raw-size: 30 GiB size: 29.36 GiB (97.86%)
used: 24.37 GiB (83.0%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: Manjaro-recovery
uuid: ab4be4b9-eb3d-43ea-a32c-8763e70be217
ID-1: swap-1 type: partition size: 11 GiB used: 755.2 MiB (6.7%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: feb7c417-87a9-413c-ae17-fb925a517a01
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 139.18 GiB fs: ntfs label: OS
uuid: DC20475720473832
ID-3: /dev/nvme0n1p7 maj-min: 259:7 size: 1.03 GiB fs: ntfs
label: RECOVERY uuid: E6BAAD46BAAD13D9
ID-4: /dev/sda1 maj-min: 8:1 size: 901.51 GiB fs: ntfs label: New Volume
uuid: 800C3F790C3F6974
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:8 info: No brand USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 2188:0ae1 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:4 info: ASIX AX88179 Gigabit Ethernet type: Network
driver: ax88179_178a interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 496mA
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 3-3:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): cpu: 2300
Processes: 280 Uptime: 2d 1h 48m wakeups: 47 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1418
pacman: 1415 lib: 387 flatpak: 3 Shell: Zsh (sudo) v: 5.8
running-in: konsole inxi: 3.3.12
