My ~/.profile
looks like this :
# enable gnome-keyring-daemon
eval $(gnome-keyring-daemon --start)
export SSH_AUTH_SOCK
# expand user path to local/bin for xterm link
export PATH=$HOME/.local/bin:~/.npm-global/bin:$PATH
Nothing special, just add ~/.npm-global/bin
to $PATH
to avoid EACCESS error from npm (I use hexo to write blog ).
It works flawless most of the time ,however ,when I login remotely from SSH ,sometimes $PATH
is wrong so hexo
could not be found. I have to run source ~/.profile
twice to make everything looks normal as the first run of source ~/.profile
returns something suspicious like this :
** Message: 16:07:15.517: couldn't access control socket: /run/user/1000/keyring/control: No such file or directory
The second run of source ~/.profile
returns silent output and everything looks fine now.
