Random PC Freezes, probably nvidia related
Hello,
I had a PC Freeze and wasn’t doing anything special. I was about to maximize a Firefox Window on my KDE Desktop after i was done watching a movie and out of nowhere my PC Froze… TTY wasn’t working but REISUB commands still was doing his job.
After a restart here is the output:
$ journalctl -p err -b -1
Jun 25 23:14:32 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
Jun 25 23:14:33 koboldx-z170 kernel: irq 16: nobody cared (try booting with the "irqpoll" option)
Jun 25 23:14:33 koboldx-z170 kernel: handlers:
Jun 25 23:14:33 koboldx-z170 kernel: [<00000000eeaa766e>] i801_isr [i2c_i801]
Jun 25 23:14:33 koboldx-z170 kernel: [<000000007f4ac70b>] azx_interrupt [snd_hda_codec]
Jun 25 23:14:33 koboldx-z170 kernel: Disabling IRQ #16
Jun 25 23:14:37 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
Jun 25 23:14:37 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:2:0:0x0000000f
Jun 25 23:14:37 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
Jun 25 23:14:37 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
Jun 25 23:14:37 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: DP-4: Failed to disable DisplayPort audio stream-3
$ inxi --admin --verbosity=5 --filter --no-host --width
  Kernel: 6.12.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
    root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw sysrq_always_enabled=1
    retbleed=off resume=UUID=717b267e-7322-4bf9-a840-f1210d422d1a
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.15.0
  Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
    uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: F23d
    date: 12/01/2017
  System RAM: total: 16 GiB available: 15.57 GiB used: 2.48 GiB (16.0%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2800 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: G.Skill part-no: F4-2800C16-8GRR
    serial: N/A
  Device-3: ChannelB-DIMM0 type: no module installed
  Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
    serial: N/A
  Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 4500 min/max: 800/4700 scaling: driver: intel_pstate
    governor: performance cores: 1: 4500 2: 4500 3: 4500 4: 4500 5: 4500 6: 4500
    7: 4500 8: 4500 bogomips: 64026
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Type: retbleed status: Vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
    driver: nvidia v: 575.64 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: DP-3 empty: DP-1, DP-2, HDMI-A-1, Unknown-2
    bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 532x302mm (20.94x11.89")
    s-diag: 612mm (24.08")
  Monitor-1: DP-3 mapped: DP-4 note: disabled model: Dell S2417DG
    serial: <filter> built: 2018 res: N/A dpi: 123 gamma: 1.2
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
    max: 2560x1440 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
    memory: 10.74 GiB
  API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 2080 Ti driver: nvidia v: 575.64 device-ID: 10de:1e07
    surfaces: N/A
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a170 class-ID: 0403
  Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
  Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
    Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 0b:00.0 chip-ID: 1102:0012 class-ID: 0403
  API: ALSA v: k6.12.34-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.5 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
    tools: pacat,pactl
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: NetworkManager
  Local Storage: total: 5.93 TiB used: 437.69 GiB (7.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 PRO LPX
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM31.6 temp: 37.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HDN724030ALE640
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A5E0 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: Portable SSD T5
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    scheme: MBR
  ID-1: / raw-size: 88.61 GiB size: 86.66 GiB (97.80%) used: 23.05 GiB (26.6%)
    fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: eb235aa7-d461-413d-800e-ea57385703fb
  ID-2: /boot raw-size: 2.93 GiB size: 2.82 GiB (96.15%)
    used: 220.4 MiB (7.6%) fs: ext3 dev: /dev/sdc3 maj-min: 8:35 label: N/A
    uuid: cbfeca98-b99d-4383-9ded-fe66cd598006
  ID-3: /home raw-size: 332.03 GiB size: 325.75 GiB (98.11%)
    used: 17.81 GiB (5.5%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
    uuid: ada4a6a2-bd0a-4652-b386-7c637bba7ee9
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: 717b267e-7322-4bf9-a840-f1210d422d1a
  System Temperatures: cpu: 34.2 C mobo: N/A gpu: nvidia temp: 35 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 25%
  Processes: 259 Power: uptime: 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,upowerd
  Packages: 1632 pm: pacman pkgs: 1626 libs: 457 tools: pamac pm: flatpak
    pkgs: 6 Compilers: clang: 20.1.6 gcc: 15.1.1 Shell: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.38
Edit: Spoiler alert… Nvidia Flatpak related again.
Looks like you are on X11 and that the freeze has something to do with kernel mode setting.
What is the output of sudo cat /sys/module/nvidia_drm/parameters/modeset ?
On Wayland at least, the modeset=1 kernel module parameter needs to be enabled (should already be enabled by default on nvidia 575). Not sure about on X11.
https://wiki.archlinux.org/title/NVIDIA
I just had a second freeze, which i had while i minimized a flatpak game:
Jun 27 01:38:24 koboldx-z170 kernel: irq 16: nobody cared (try booting with the "irqpoll" option)
Jun 27 01:38:24 koboldx-z170 kernel: handlers:
Jun 27 01:38:24 koboldx-z170 kernel: [<00000000140ec8cf>] i801_isr [i2c_i801]
Jun 27 01:38:24 koboldx-z170 kernel: [<0000000052f1e304>] azx_interrupt [snd_hda_codec]
Jun 27 01:38:24 koboldx-z170 kernel: Disabling IRQ #16
Jun 27 01:38:24 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
Jun 27 01:38:25 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0:0:0x0000000f
Jun 27 01:38:25 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:2:0:0x0000000f
Jun 27 01:38:25 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4:0:0x0000000f
Jun 27 01:38:25 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6:0:0x0000000f
Jun 27 01:38:25 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: DP-4: Failed to disable DisplayPort audio stream-3
Nothing is happening when i type in that command :man_shrugging:
But after i openend that path in dolphin and double clicked on modeset… my PC froze again with that info after i did REISUB again (right after the reboot… double freeze):
Jun 27 01:50:19 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:6>
Jun 27 01:50:19 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:0>
Jun 27 01:50:19 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:2>
Jun 27 01:50:19 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57e:4>
Jun 27 01:50:19 koboldx-z170 kernel: nvidia-modeset: ERROR: GPU:0: DP-4: Failed to disable DisplayPort audio stream-3
Jun 27 01:50:20 koboldx-z170 kernel: irq 16: nobody cared (try booting with the "irqpoll" option)
Jun 27 01:50:20 koboldx-z170 kernel: handlers:
Jun 27 01:50:20 koboldx-z170 kernel: [<00000000224a6d5d>] i801_isr [i2c_i801]
Jun 27 01:50:20 koboldx-z170 kernel: [<00000000e4692f78>] azx_interrupt [snd_hda_codec]
Jun 27 01:50:20 koboldx-z170 kernel: Disabling IRQ #16
Jun 27 01:54:28 koboldx-z170 systemd[1]: Failed to start CUPS Scheduler.
Is that normal that a double mouse click lead to a system freeze when clicking on modeset in dolphin?
Edit:
I was wrong…
I openend with sudo nano and it showed only a Y that was in there.
Just the: Y and nothing else.
$ sudo cat /sys/module/nvidia_drm/parameters/modeset
Y
No idea as I normally just cat or read file contents with nano.
That’s positive as at least the modeset=1 parameter is passed to the kernel.
Just need to figure out now why there is still a problem.
I assume that you use GRUB as the bootloader ?
If so, can you post output from these two commands :
cat /etc/default/grub
cat /etc/mkinitcpio.conf
Yeah of course… its in my system settings in my first post.
$ cat /etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=1
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="sysrq_always_enabled=1 retbleed=off resume=UUID=717b267e-7322-4bf9-a840-f1210d422d1a udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=true
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
$ cat /etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(usbhid xhci_hcd)
MODULES=()
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image.  This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way.  This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file.  The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added.  Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
##   This setup specifies all modules in the MODULES setting above.
##   No RAID, lvm2, or encrypted root is needed.
#    HOOKS=(base)
##   This setup will autodetect all modules for your system and should
##   work as a sane default
#    HOOKS=(base udev autodetect modconf block filesystems fsck)
##   This setup will generate a 'full' image which supports most systems.
##   No autodetection is done.
#    HOOKS=(base udev modconf block filesystems fsck)
##   This setup assembles a mdadm array with an encrypted root file system.
##   Note: See 'mkinitcpio -H mdadm_udev' for more information on RAID devices.
#    HOOKS=(base udev modconf keyboard keymap consolefont block mdadm_udev encrypt filesystems fsck)
##   This setup loads an lvm2 volume group.
#    HOOKS=(base udev modconf block lvm2 filesystems fsck)
##   This will create a systemd based initramfs which loads an encrypted root filesystem.
#    HOOKS=(base systemd autodetect modconf kms keyboard sd-vconsole sd-encrypt block filesystems fsck)
##   NOTE: If you have /usr on a separate partition, you MUST include the
#    usr and fsck hooks.
HOOKS=(base udev autodetect microcode modconf kms keyboard keymap consolefont block filesystems fsck)
# COMPRESSION
# Use this to compress the initramfs image. By default, zstd compression
# is used for Linux ≥ 5.9 and gzip compression is used for Linux < 5.9.
# Use 'cat' to create an uncompressed image.
#COMPRESSION="zstd"
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# MODULES_DECOMPRESS
# Decompress loadable kernel modules and their firmware during initramfs
# creation. Switch (yes/no).
# Enable to allow further decreasing image size when using high compression
# (e.g. xz -9e or zstd --long --ultra -22) at the expense of increased RAM usage
# at early boot.
# Note that any compressed files will be placed in the uncompressed early CPIO
# to avoid double compression.
#MODULES_DECOMPRESS="no"
You may need to try early loading of the nvidia, nvidia_modeset, nvidia_uvm and nvidia_drm modules, as described in the Arch wiki :
https://wiki.archlinux.org/title/NVIDIA#Early_loading
Before you head down that route, I would try Wayland first to see if you still experience freezes.
Addendum:
Also, the nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state error appears in the thread below - the problem there is at least partly power related, so it may or may not apply to you.
https://bbs.archlinux.org/viewtopic.php?id=301930
Do you run a single PCIE cable with a Y-splitter from the power supply to the GPU ?
If so, it’s quite possible the GPU does not get enough power. The first thing to try is therefore to run two cables to the GPU instead of just one.
I have a Multi Rail GPU Power Supply, i already splitted 2 rails into the GPU.
Anyways, after several investigation i think my freezes are gaming related… Specially related to the newest Nvidia Flatpak Driver… its not the first time where i face system freezes because of some buggy Flatpak Nvidia drivers that lead to system freezes:
$ flatpak list
Name                    Application ID                               Version                     Branch       Installation
Beyond All Reason       info.beyondallreason.bar                     1.2988.0.1                  stable       system
Freedesktop Platform    org.freedesktop.Platform                     freedesktop-sdk-24.08.22    24.08        system
Mesa                    org.freedesktop.Platform.GL.default          25.1.3                      24.08        system
Mesa (Extra)            org.freedesktop.Platform.GL.default          25.1.3                      24.08extra   system
nvidia-575-64           org.freedesktop.Platform.GL.nvidia-575-64                                1.4          system
openh264                org.freedesktop.Platform.openh264            2.5.1                       2.5.1        system
Damn i wish i could download a older Nvidia Flatpak driver as 575.64 the second last version was running fine.
@Kobold Didn’t realise that nvidia drivers could be installed from flatpak.
Also didn’t realise that you had already experienced a near-exact occurrence of the same error last year, and that you had already posted about it.
If you had led with that, it would have saved some time.
If I were you, I would remove the flatpak nvidia driver, install linux612-nvidia / linux612-nvidia-open from the extra repo, install the game from the AUR as @Xephon suggested, fully configure the driver (early module loading, etc), and see if you still have issues.
Bonne soirée.
Yeah sry, after i faced that first freeze where i created this topic, it was 20min later after my flatpak game closed and when my system froze.
That’s also one of confusion problem’s when we are on a rolling release distro, because after a release update i was think that it could be related to the OS Driver.
It took time till a realised that it could be related to the Flatpak Nvidia Driver again :frowning:
Anyways thanks so far, for your help.
