I have been using Manjaro on TUF Gaming FX505GT_FX505GT 1.0 and am currently on the kernel version 5.18.17-1-MANJARO. When I continue my system from sleep, I frequently pause on the UI for some random amount of time, especially triggered by mouse movement. After this pause the cursor then skips to some point on the screen. It like the display manager is reading the input but not refreshing the monitor.
While writing this question, whenever I used the trackpad, there was some pause in initial movement.
Here is neofetch output
And inxi output
Kernel: 5.18.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=722ab607-768e-474a-b27b-25c329d85c00 rw
resume=UUID=72408540-0d23-4d2c-9b52-2f0c2af417b9 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX505GT.311 date: 02/08/2021
ID-1: BAT0 charge: 30.0 Wh (90.6%) condition: 33.1/48.1 Wh (68.9%)
volts: 11.1 min: 11.7 model: Simplo SDI ICR18650 type: Li-ion
serial: <filter> status: discharging cycles: 41
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-11:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: eDP-1 model: Najing CEC Panda 0x0036 built: 2018 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.18.17-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br-1eccf73e6106 state: down mac: <filter>
IF-ID-2: br-a0596a8d9fbb state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: vboxnet0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.38 TiB used: 388.06 GiB (27.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron
model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size: physical: 512 B
rev: P1MA0V4 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SPZX-11Z10T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: GPT
ID-1: / raw-size: 117.19 GiB size: 114.79 GiB (97.95%) used: 38.06 GiB
(33.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%) used: 274 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 343.05 GiB size: 336.6 GiB (98.12%) used: 160.67 GiB
(47.7%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 16.5 GiB used: 598 MiB (3.5%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 42.0 C pch: 53.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2300
Processes: 333 Uptime: 10d 7h 8m wakeups: 97 Memory: 15.48 GiB used: 5.04
GiB (32.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pm: pacman pkgs: 1402
libs: 357 tools: pamac,yay Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.21
I tested on Debian. kde, there is no such bug.
