Jan 14 21:43:59 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x7fa21401ae80] stream 0, timescale not set
Jan 14 21:43:59 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x7fa21423aac0] stream 0, timescale not set
Jan 14 21:44:02 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x7fa214012c40] stream 0, timescale not set
Jan 14 21:44:30 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [matroska,webm @ 0x7fa214012c40] Element at 0x239877 ending at 0x1ff0784 exceeds containing master element ending at 0xae8119
Jan 14 21:44:30 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [matroska,webm @ 0x7fa214012c40] 0x00 at pos 170 (0xaa) invalid as first byte of an EBML number
Jan 14 21:44:30 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [matroska,webm @ 0x7fa214012c40] Element at 0x57 ending at 0x444dbb8d53abe4 exceeds containing master element ending at 0x1403
Jan 14 21:44:30 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [matroska,webm @ 0x7fa214012c40] 0x00 at pos 150 (0x96) invalid as first byte of an EBML number
Jan 14 21:44:30 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [matroska,webm @ 0x7fa214012c40] Duplicate element
Jan 14 21:44:39 manjaro vlc[12100]: QObject::~QObject: Timers cannot be stopped from another thread
Jan 14 21:45:33 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x7fa214012c40] stream 0, timescale not set
Jan 14 21:45:34 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x7fa214012c40] stream 0, timescale not set
Jan 14 21:45:34 manjaro org.freedesktop.thumbnails.Thumbnailer1[11762]: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x7fa214014a00] stream 0, timescale not set
Jan 14 21:46:09 manjaro vlc[12228]: QObject::~QObject: Timers cannot be stopped from another thread
Jan 14 21:46:12 manjaro vlc[12265]: QObject::~QObject: Timers cannot be stopped from another thread
Jan 14 21:46:15 manjaro vlc[12300]: QObject::~QObject: Timers cannot be stopped from another thread
Jan 14 21:46:17 manjaro vlc[12332]: QObject::~QObject: Timers cannot be stopped from another thread
Jan 14 21:47:08 manjaro vlc[12372]: qt.qpa.xcb: internal error: void QXcbWindow::setNetWmStateOnUnmappedWindow() called on mapped window
Jan 14 21:47:10 manjaro audit[537]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=537 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Jan 14 21:47:10 manjaro kernel: audit: type=1701 audit(1610657230.296:126): auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=537 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Jan 14 21:47:10 manjaro systemd[1]: Created slice system-systemd\x2dcoredump.slice.
Jan 14 21:47:10 manjaro audit: BPF prog-id=16 op=LOAD
Jan 14 21:47:10 manjaro audit: BPF prog-id=17 op=LOAD
Jan 14 21:47:10 manjaro systemd[1]: Started Process Core Dump (PID 12460/UID 0).
Jan 14 21:47:10 manjaro kernel: audit: type=1334 audit(1610657230.310:127): prog-id=16 op=LOAD
Jan 14 21:47:10 manjaro kernel: audit: type=1334 audit(1610657230.310:128): prog-id=17 op=LOAD
Jan 14 21:47:10 manjaro kernel: audit: type=1130 audit(1610657230.310:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-12460-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:10 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-12460-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:11 manjaro systemd-coredump[12461]: Process 537 (Xorg) of user 0 dumped core.
Stack trace of thread 537:
#0 0x00007fdb8cc09615 raise (libc.so.6 + 0x3d615)
#1 0x00007fdb8cbf2862 abort (libc.so.6 + 0x26862)
#2 0x0000556ad0f406ea OsAbort (Xorg + 0x14a6ea)
#3 0x0000556ad0f421b1 FatalError (Xorg + 0x14c1b1)
#4 0x0000556ad0f47e09 n/a (Xorg + 0x151e09)
#5 0x00007fdb8cc096a0 __restore_rt (libc.so.6 + 0x3d6a0)
#6 0x00007fdb8b03e21d n/a (libglxserver_nvidia.so + 0x8f821d)
Jan 14 21:47:11 manjaro systemd[1]: systemd-coredump@0-12460-0.service: Succeeded.
Jan 14 21:47:11 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-12460-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:11 manjaro kernel: audit: type=1131 audit(1610657231.683:130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-12460-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:11 manjaro audit[12372]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=12372 comm="vlc" exe="/usr/bin/vlc" sig=11 res=1
Jan 14 21:47:11 manjaro vlc[12372]: The X11 connection broke: I/O error (code 1)
Jan 14 21:47:11 manjaro kernel: traps: vlc[12401] general protection fault ip:7ff3ad876d86 sp:7ff34c4574f0 error:0 in libc-2.32.so[7ff3ad85d000+14d000]
Jan 14 21:47:11 manjaro kernel: audit: type=1701 audit(1610657231.696:131): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=12372 comm="vlc" exe="/usr/bin/vlc" sig=11 res=1
Jan 14 21:47:11 manjaro at-spi-bus-launcher[1037]: X connection to :0 broken (explicit kill or server shutdown).
Jan 14 21:47:11 manjaro pulseaudio[1052]: X connection to :0.0 broken (explicit kill or server shutdown).
Jan 14 21:47:11 manjaro msm_notifier[1132]: The X11 connection broke (error 1). Did the X11 server die?
Jan 14 21:47:11 manjaro bamfdaemon[1200]: bamfdaemon: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Jan 14 21:47:11 manjaro systemd[964]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
Jan 14 21:47:11 manjaro systemd[964]: bamfdaemon.service: Failed with result 'exit-code'.
Jan 14 21:47:11 manjaro systemd[964]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
Jan 14 21:47:11 manjaro systemd[964]: pulseaudio.service: Killing process 1283 (gmain) with signal SIGKILL.
Jan 14 21:47:11 manjaro systemd[964]: pulseaudio.service: Failed with result 'exit-code'.
Jan 14 21:47:11 manjaro polkitd[453]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.40, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8) (disconnected from bus)
Jan 14 21:47:11 manjaro audit: BPF prog-id=18 op=LOAD
Jan 14 21:47:11 manjaro audit: BPF prog-id=19 op=LOAD
Jan 14 21:47:11 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-12472-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:11 manjaro systemd[1]: Started Process Core Dump (PID 12472/UID 0).
Jan 14 21:47:11 manjaro kernel: audit: type=1334 audit(1610657231.740:132): prog-id=18 op=LOAD
Jan 14 21:47:11 manjaro kernel: audit: type=1334 audit(1610657231.740:133): prog-id=19 op=LOAD
Jan 14 21:47:11 manjaro kernel: audit: type=1130 audit(1610657231.740:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-12472-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:11 manjaro audit[12481]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=12481 comm="xfsettingsd" exe="/usr/bin/xfsettingsd" sig=5 res=1
Jan 14 21:47:11 manjaro audit: BPF prog-id=20 op=LOAD
Jan 14 21:47:11 manjaro audit: BPF prog-id=21 op=LOAD
Jan 14 21:47:11 manjaro systemd[1]: Started Process Core Dump (PID 12484/UID 0).
Jan 14 21:47:11 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-12484-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:11 manjaro audit: BPF prog-id=17 op=UNLOAD
Jan 14 21:47:11 manjaro audit: BPF prog-id=16 op=UNLOAD
Jan 14 21:47:11 manjaro systemd[964]: bamfdaemon.service: Scheduled restart job, restart counter is at 1.
Jan 14 21:47:11 manjaro systemd[964]: pulseaudio.service: Scheduled restart job, restart counter is at 1.
Jan 14 21:47:11 manjaro systemd[964]: Stopped BAMF Application Matcher Framework.
Jan 14 21:47:11 manjaro systemd[964]: Starting BAMF Application Matcher Framework...
Jan 14 21:47:11 manjaro systemd[964]: Stopped Sound Service.
Jan 14 21:47:11 manjaro systemd[964]: Starting Sound Service...
Jan 14 21:47:11 manjaro bamfdaemon[12493]: Unable to init server: Could not connect: Connection refused
Jan 14 21:47:11 manjaro bamfdaemon[12493]: cannot open display: :0
Jan 14 21:47:11 manjaro systemd[964]: Failed to start BAMF Application Matcher Framework.
Jan 14 21:47:11 manjaro audit[12492]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=12492 comm="xfsettingsd" exe="/usr/bin/xfsettingsd" sig=5 res=1
Jan 14 21:47:11 manjaro audit: BPF prog-id=22 op=LOAD
Jan 14 21:47:11 manjaro audit: BPF prog-id=23 op=LOAD
Jan 14 21:47:11 manjaro systemd[1]: Started Process Core Dump (PID 12496/UID 0).
Jan 14 21:47:11 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@3-12496-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:11 manjaro rtkit-daemon[1059]: Successfully made thread 12494 of process 12494 owned by '1000' high priority at nice level -11.
Jan 14 21:47:11 manjaro rtkit-daemon[1059]: Supervising 1 threads of 1 processes of 1 users.
Jan 14 21:47:11 manjaro pulseaudio[12494]: Stale PID file, overwriting.
Jan 14 21:47:11 manjaro systemd-coredump[12485]: Process 12481 (xfsettingsd) of user 1000 dumped core.
Stack trace of thread 12481:
#0 0x00007fa2c50f8b28 g_log_structured_array (libglib-2.0.so.0 + 0x59b28)
#1 0x00007fa2c50f9146 g_log_default_handler (libglib-2.0.so.0 + 0x5a146)
#2 0x00007fa2c50fa219 g_logv (libglib-2.0.so.0 + 0x5b219)
#3 0x00007fa2c50fa4c0 g_log (libglib-2.0.so.0 + 0x5b4c0)
#4 0x0000557ebe2db469 n/a (xfsettingsd + 0x6469)
#5 0x00007fa2c4edc152 __libc_start_main (libc.so.6 + 0x28152)
#6 0x0000557ebe2db69e n/a (xfsettingsd + 0x669e)
Jan 14 21:47:11 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-12484-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:11 manjaro systemd[1]: systemd-coredump@2-12484-0.service: Succeeded.
Jan 14 21:47:11 manjaro systemd-coredump[12497]: Process 12492 (xfsettingsd) of user 1000 dumped core.
Stack trace of thread 12492:
#0 0x00007f8b0c320b28 g_log_structured_array (libglib-2.0.so.0 + 0x59b28)
#1 0x00007f8b0c321146 g_log_default_handler (libglib-2.0.so.0 + 0x5a146)
#2 0x00007f8b0c322219 g_logv (libglib-2.0.so.0 + 0x5b219)
#3 0x00007f8b0c3224c0 g_log (libglib-2.0.so.0 + 0x5b4c0)
#4 0x000055e22f15a469 n/a (xfsettingsd + 0x6469)
#5 0x00007f8b0c104152 __libc_start_main (libc.so.6 + 0x28152)
#6 0x000055e22f15a69e n/a (xfsettingsd + 0x669e)
Jan 14 21:47:11 manjaro systemd[1]: systemd-coredump@3-12496-0.service: Succeeded.
Jan 14 21:47:11 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@3-12496-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:12 manjaro audit[12516]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=12516 comm="xfsettingsd" exe="/usr/bin/xfsettingsd" sig=5 res=1
Jan 14 21:47:12 manjaro systemd[1]: Started Process Core Dump (PID 12518/UID 0).
Jan 14 21:47:12 manjaro audit: BPF prog-id=24 op=LOAD
Jan 14 21:47:12 manjaro audit: BPF prog-id=25 op=LOAD
Jan 14 21:47:12 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-12518-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:12 manjaro audit: BPF prog-id=21 op=UNLOAD
Jan 14 21:47:12 manjaro audit: BPF prog-id=20 op=UNLOAD
Jan 14 21:47:12 manjaro audit[12522]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=12522 comm="xfsettingsd" exe="/usr/bin/xfsettingsd" sig=5 res=1
Jan 14 21:47:12 manjaro audit[934]: USER_LOGOUT pid=934 uid=0 auid=1000 ses=2 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=manjaro addr=? terminal=/dev/tty7 res=success'
Jan 14 21:47:12 manjaro lightdm[934]: pam_unix(lightdm:session): session closed for user niko
Jan 14 21:47:12 manjaro systemd[1]: Started Process Core Dump (PID 12525/UID 0).
Jan 14 21:47:12 manjaro audit: BPF prog-id=26 op=LOAD
Jan 14 21:47:12 manjaro audit: BPF prog-id=27 op=LOAD
Jan 14 21:47:12 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@5-12525-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:12 manjaro audit[934]: USER_END pid=934 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:12 manjaro audit[934]: CRED_DISP pid=934 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:12 manjaro systemd-logind[455]: Session 2 logged out. Waiting for processes to exit.
Jan 14 21:47:12 manjaro audit[12532]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=12532 comm="xfsettingsd" exe="/usr/bin/xfsettingsd" sig=5 res=1
Jan 14 21:47:12 manjaro audit: BPF prog-id=28 op=LOAD
Jan 14 21:47:12 manjaro audit: BPF prog-id=29 op=LOAD
Jan 14 21:47:12 manjaro systemd[1]: Started Process Core Dump (PID 12533/UID 0).
Jan 14 21:47:12 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@6-12533-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:12 manjaro systemd[964]: bamfdaemon.service: Scheduled restart job, restart counter is at 2.
Jan 14 21:47:12 manjaro systemd[964]: Stopped BAMF Application Matcher Framework.
Jan 14 21:47:12 manjaro systemd[964]: Starting BAMF Application Matcher Framework...
Jan 14 21:47:12 manjaro bamfdaemon[12539]: Unable to init server: Could not connect: Connection refused
Jan 14 21:47:12 manjaro bamfdaemon[12539]: cannot open display: :0
Jan 14 21:47:12 manjaro systemd[964]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
Jan 14 21:47:12 manjaro systemd[964]: bamfdaemon.service: Failed with result 'exit-code'.
Jan 14 21:47:12 manjaro systemd[964]: Failed to start BAMF Application Matcher Framework.
Jan 14 21:47:12 manjaro systemd-coredump[12519]: Process 12516 (xfsettingsd) of user 1000 dumped core.
Stack trace of thread 12516:
#0 0x00007f9cf13a4b28 g_log_structured_array (libglib-2.0.so.0 + 0x59b28)
#1 0x00007f9cf13a5146 g_log_default_handler (libglib-2.0.so.0 + 0x5a146)
#2 0x00007f9cf13a6219 g_logv (libglib-2.0.so.0 + 0x5b219)
#3 0x00007f9cf13a64c0 g_log (libglib-2.0.so.0 + 0x5b4c0)
#4 0x0000560bbde9b469 n/a (xfsettingsd + 0x6469)
#5 0x00007f9cf1188152 __libc_start_main (libc.so.6 + 0x28152)
#6 0x0000560bbde9b69e n/a (xfsettingsd + 0x669e)
Jan 14 21:47:12 manjaro audit: BPF prog-id=23 op=UNLOAD
Jan 14 21:47:12 manjaro audit: BPF prog-id=22 op=UNLOAD
Jan 14 21:47:12 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-12518-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:12 manjaro systemd[1]: systemd-coredump@4-12518-0.service: Succeeded.
Jan 14 21:47:12 manjaro systemd-coredump[12526]: Process 12522 (xfsettingsd) of user 1000 dumped core.
Stack trace of thread 12522:
#0 0x00007f0ff3da9b28 g_log_structured_array (libglib-2.0.so.0 + 0x59b28)
#1 0x00007f0ff3daa146 g_log_default_handler (libglib-2.0.so.0 + 0x5a146)
#2 0x00007f0ff3dab219 g_logv (libglib-2.0.so.0 + 0x5b219)
#3 0x00007f0ff3dab4c0 g_log (libglib-2.0.so.0 + 0x5b4c0)
#4 0x00005602d1e4f469 n/a (xfsettingsd + 0x6469)
#5 0x00007f0ff3b8d152 __libc_start_main (libc.so.6 + 0x28152)
#6 0x00005602d1e4f69e n/a (xfsettingsd + 0x669e)
Jan 14 21:47:12 manjaro systemd[1]: systemd-coredump@5-12525-0.service: Succeeded.
Jan 14 21:47:12 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@5-12525-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:12 manjaro systemd-coredump[12536]: Process 12532 (xfsettingsd) of user 1000 dumped core.
Stack trace of thread 12532:
#0 0x00007fdaea311b28 g_log_structured_array (libglib-2.0.so.0 + 0x59b28)
#1 0x00007fdaea312146 g_log_default_handler (libglib-2.0.so.0 + 0x5a146)
#2 0x00007fdaea313219 g_logv (libglib-2.0.so.0 + 0x5b219)
#3 0x00007fdaea3134c0 g_log (libglib-2.0.so.0 + 0x5b4c0)
#4 0x0000558f6d078469 n/a (xfsettingsd + 0x6469)
#5 0x00007fdaea0f5152 __libc_start_main (libc.so.6 + 0x28152)
#6 0x0000558f6d07869e n/a (xfsettingsd + 0x669e)
Jan 14 21:47:12 manjaro systemd[1]: systemd-coredump@6-12533-0.service: Succeeded.
Jan 14 21:47:12 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@6-12533-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:12 manjaro rtkit-daemon[1059]: Supervising 1 threads of 1 processes of 1 users.
Jan 14 21:47:12 manjaro rtkit-daemon[1059]: Successfully made thread 12559 of process 12494 owned by '1000' RT at priority 5.
Jan 14 21:47:12 manjaro rtkit-daemon[1059]: Supervising 2 threads of 1 processes of 1 users.
Jan 14 21:47:12 manjaro audit: BPF prog-id=25 op=UNLOAD
Jan 14 21:47:12 manjaro audit: BPF prog-id=24 op=UNLOAD
Jan 14 21:47:12 manjaro rtkit-daemon[1059]: Successfully made thread 12565 of process 12494 owned by '1000' RT at priority 5.
Jan 14 21:47:12 manjaro rtkit-daemon[1059]: Supervising 3 threads of 1 processes of 1 users.
Jan 14 21:47:12 manjaro audit: BPF prog-id=29 op=UNLOAD
Jan 14 21:47:12 manjaro audit: BPF prog-id=28 op=UNLOAD
Jan 14 21:47:12 manjaro audit: BPF prog-id=27 op=UNLOAD
Jan 14 21:47:12 manjaro audit: BPF prog-id=26 op=UNLOAD
Jan 14 21:47:12 manjaro systemd[964]: bamfdaemon.service: Scheduled restart job, restart counter is at 3.
Jan 14 21:47:12 manjaro rtkit-daemon[1059]: Successfully made thread 12569 of process 12494 owned by '1000' RT at priority 5.
Jan 14 21:47:12 manjaro rtkit-daemon[1059]: Supervising 4 threads of 1 processes of 1 users.
Jan 14 21:47:12 manjaro rtkit-daemon[1059]: Successfully made thread 12570 of process 12494 owned by '1000' RT at priority 5.
Jan 14 21:47:12 manjaro rtkit-daemon[1059]: Supervising 5 threads of 1 processes of 1 users.
Jan 14 21:47:12 manjaro dbus-daemon[450]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.136' (uid=1000 pid=12494 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo" label="unconfined")
Jan 14 21:47:12 manjaro systemd[1]: Condition check resulted in Bluetooth service being skipped.
Jan 14 21:47:12 manjaro systemd[964]: Started Sound Service.
Jan 14 21:47:13 manjaro bamfdaemon[12567]: Invalid MIT-MAGIC-COOKIE-1 keyUnable to init server: Could not connect: Connection refused
Jan 14 21:47:13 manjaro bamfdaemon[12567]: cannot open display: :0
Jan 14 21:47:13 manjaro systemd[964]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
Jan 14 21:47:13 manjaro systemd[964]: bamfdaemon.service: Failed with result 'exit-code'.
Jan 14 21:47:13 manjaro systemd[964]: Failed to start BAMF Application Matcher Framework.
Jan 14 21:47:13 manjaro audit[12577]: CRED_ACQ pid=12577 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:13 manjaro lightdm[12577]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=969) by (uid=0)
Jan 14 21:47:13 manjaro systemd[1]: Created slice User Slice of UID 969.
Jan 14 21:47:13 manjaro systemd[1]: Starting User Runtime Directory /run/user/969...
Jan 14 21:47:13 manjaro systemd-logind[455]: New session c3 of user lightdm.
Jan 14 21:47:13 manjaro systemd[1]: Finished User Runtime Directory /run/user/969.
Jan 14 21:47:13 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:13 manjaro systemd[1]: Starting User Manager for UID 969...
Jan 14 21:47:13 manjaro dbus-daemon[450]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.140' (uid=0 pid=12581 comm="(systemd) " label="unconfined")
Jan 14 21:47:13 manjaro dbus-daemon[450]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 14 21:47:13 manjaro systemd[12581]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 14 21:47:13 manjaro audit[12581]: USER_ACCT pid=12581 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:13 manjaro audit[12581]: CRED_ACQ pid=12581 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jan 14 21:47:13 manjaro systemd[12581]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Jan 14 21:47:13 manjaro systemd[12581]: pam_unix(systemd-user:session): session opened for user lightdm(uid=969) by (uid=0)
Jan 14 21:47:13 manjaro systemd[12581]: pam_env(systemd-user:session): deprecated reading of user environment enabled
Jan 14 21:47:13 manjaro audit[12581]: USER_START pid=12581 uid=0 auid=969 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:13 manjaro audit: BPF prog-id=30 op=LOAD
Jan 14 21:47:13 manjaro audit: BPF prog-id=30 op=UNLOAD
Jan 14 21:47:13 manjaro systemd-xdg-autostart-generator[12589]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jan 14 21:47:13 manjaro systemd[12581]: Queued start job for default target Main User Target.
Jan 14 21:47:13 manjaro systemd[12581]: -.slice: Failed to migrate controller cgroups from /user.slice/user-969.slice/user@969.service, ignoring: Permission denied
Jan 14 21:47:13 manjaro systemd[12581]: Created slice User Application Slice.
Jan 14 21:47:13 manjaro systemd[12581]: Reached target Paths.
Jan 14 21:47:13 manjaro systemd[12581]: Reached target Timers.
Jan 14 21:47:13 manjaro systemd[12581]: Starting D-Bus User Message Bus Socket.
Jan 14 21:47:13 manjaro systemd[12581]: Listening on GnuPG network certificate management daemon.
Jan 14 21:47:13 manjaro systemd[12581]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 14 21:47:13 manjaro systemd[12581]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jan 14 21:47:13 manjaro systemd[12581]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jan 14 21:47:13 manjaro systemd[12581]: Listening on GnuPG cryptographic agent and passphrase cache.
Jan 14 21:47:13 manjaro systemd[12581]: Listening on p11-kit server.
Jan 14 21:47:13 manjaro systemd[12581]: Listening on Multimedia System.
Jan 14 21:47:13 manjaro systemd[12581]: Listening on Sound System.
Jan 14 21:47:13 manjaro systemd[12581]: Listening on D-Bus User Message Bus Socket.
Jan 14 21:47:13 manjaro systemd[12581]: Reached target Sockets.
Jan 14 21:47:13 manjaro systemd[12581]: Reached target Basic System.
Jan 14 21:47:13 manjaro systemd[1]: Started User Manager for UID 969.
Jan 14 21:47:13 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:13 manjaro systemd[12581]: Starting Update XDG user dir configuration...
Jan 14 21:47:13 manjaro systemd[1]: Started Session c3 of user lightdm.
Jan 14 21:47:13 manjaro systemd[12581]: xdg-user-dirs-update.service: Succeeded.
Jan 14 21:47:13 manjaro systemd[12581]: Finished Update XDG user dir configuration.
Jan 14 21:47:13 manjaro systemd[12581]: Reached target Main User Target.
Jan 14 21:47:13 manjaro systemd[12581]: Startup finished in 74ms.
Jan 14 21:47:13 manjaro audit[12577]: USER_START pid=12577 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:13 manjaro systemd-coredump[12477]: Process 12372 (vlc) of user 1000 dumped core.
Stack trace of thread 12401:
#0 0x00007ff3ad876d86 __run_exit_handlers (libc.so.6 + 0x3fd86)
#1 0x00007ff3ad876f5e exit (libc.so.6 + 0x3ff5e)
#2 0x00007ff3a41d1852 _XDefaultIOError (libX11.so.6 + 0x43852)
#3 0x00007ff3a41d1b0f _XIOError (libX11.so.6 + 0x43b0f)
#4 0x00007ff3a41cf9e3 _XReply (libX11.so.6 + 0x419e3)
#5 0x00007ff36ed921c9 n/a (libGLX_nvidia.so.0 + 0xa81c9)
#6 0x00007ff36ed39acb n/a (libGLX_nvidia.so.0 + 0x4facb)
#7 0x00007ff36ed37c49 n/a (libGLX_nvidia.so.0 + 0x4dc49)
#8 0x00007ff36ed65c33 n/a (libGLX_nvidia.so.0 + 0x7bc33)
#9 0x00007ff3a9897e32 n/a (libGLX.so.0 + 0x13e32)
#10 0x00007ff3a989a811 n/a (libGLX.so.0 + 0x16811)
#11 0x00007ff3a989d7ed n/a (libGLX.so.0 + 0x197ed)
#12 0x00007ff33edeb18c n/a (libglx_plugin.so + 0x118c)
#13 0x00007ff34c34f2f3 n/a (libgl_plugin.so + 0xc2f3)
#14 0x00007ff3ad7514ce vlc_module_unload (libvlccore.so.9 + 0x2f4ce)
#15 0x00007ff3ad7a3c4d n/a (libvlccore.so.9 + 0x81c4d)
#16 0x00007ff3ad7b4c1d n/a (libvlccore.so.9 + 0x92c1d)
#17 0x00007ff3ad7a74cb n/a (libvlccore.so.9 + 0x854cb)
#18 0x00007ff3ad7a8eca n/a (libvlccore.so.9 + 0x86eca)
#19 0x00007ff3ada0f3e9 start_thread (libpthread.so.0 + 0x93e9)
#20 0x00007ff3ad937293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 12390:
#0 0x00007ff3ada156a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
#1 0x00007ff3ad7dd73f n/a (libvlccore.so.9 + 0xbb73f)
#2 0x00007ff3ada0f3e9 start_thread (libpthread.so.0 + 0x93e9)
#3 0x00007ff3ad937293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 12372:
#0 0x00007ff3ada109b7 __pthread_clockjoin_ex (libpthread.so.0 + 0xa9b7)
#1 0x00007ff3a50c11db n/a (libqt_plugin.so + 0x901db)
#2 0x00007ff3ad7514ce vlc_module_unload (libvlccore.so.9 + 0x2f4ce)
#3 0x00007ff3ad758572 n/a (libvlccore.so.9 + 0x36572)
#4 0x00007ff3ad73a3b0 libvlc_InternalCleanup (libvlccore.so.9 + 0x183b0)
#5 0x00007ff3ada3131d libvlc_release (libvlc.so.5 + 0x931d)
#6 0x0000562367b8b342 n/a (vlc + 0x1342)
#7 0x00007ff3ad85f152 __libc_start_main (libc.so.6 + 0x28152)
#8 0x0000562367b8b42e n/a (vlc + 0x142e)
Stack trace of thread 12374:
#0 0x00007ff3ad92c46f __poll (libc.so.6 + 0xf546f)
#1 0x00007ff3aa8b1654 n/a (libpulse.so.0 + 0x33654)
#2 0x00007ff3aa89a9a9 pa_mainloop_poll (libpulse.so.0 + 0x1c9a9)
#3 0x00007ff3aa8a5281 pa_mainloop_iterate (libpulse.so.0 + 0x27281)
#4 0x00007ff3aa8a5331 pa_mainloop_run (libpulse.so.0 + 0x27331)
#5 0x00007ff3aa8b57fe n/a (libpulse.so.0 + 0x377fe)
#6 0x00007ff3aa84f5fc n/a (libpulsecommon-14.0.so + 0x565fc)
#7 0x00007ff3ada0f3e9 start_thread (libpthread.so.0 + 0x93e9)
#8 0x00007ff3ad937293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 12375:
#1 0x00007ff3ad7a917a vout_Close (libvlccore.so.9 + 0x8717a)
#2 0x00007ff3ad78fa5e input_resource_TerminateVout (libvlccore.so.9 + 0x6da5e)
#3 0x00007ff3ad75a7f3 n/a (libvlccore.so.9 + 0x387f3)
#4 0x00007ff3ada0f3e9 start_thread (libpthread.so.0 + 0x93e9)
#5 0x00007ff3ad937293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 12376:
#1 0x00007ff3aa8ffdad n/a (libdbus_plugin.so + 0xadad)
Stack trace of thread 12402:
#0 0x00007ff3ad92eb7b __select (libc.so.6 + 0xf7b7b)
#1 0x00007ff36d99e172 n/a (libnvidia-glcore.so.455.45.01 + 0x1120172)
#2 0x00007ff36d998fcc n/a (libnvidia-glcore.so.455.45.01 + 0x111afcc)
#3 0x00007ff3ada0f3e9 start_thread (libpthread.so.0 + 0x93e9)
#4 0x00007ff3ad937293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 12389:
#0 0x00007ff3ada1909b __close (libpthread.so.0 + 0x1309b)
#1 0x00007ff3ad58c6e6 _dbus_close (libdbus-1.so.3 + 0x326e6)
#2 0x00007ff3ad5835e7 n/a (libdbus-1.so.3 + 0x295e7)
#3 0x00007ff3ad582d44 n/a (libdbus-1.so.3 + 0x28d44)
#4 0x00007ff3ad56f771 dbus_connection_close (libdbus-1.so.3 + 0x15771)
#5 0x00007ff38b45e03c n/a (libQt5DBus.so.5 + 0x2303c)
#6 0x00007ff38b452117 n/a (libQt5DBus.so.5 + 0x17117)
#7 0x00007ff38bb78f0f n/a (libQt5Core.so.5 + 0xcdf0f)
#8 0x00007ff3ada0f3e9 start_thread (libpthread.so.0 + 0x93e9)
#9 0x00007ff3ad937293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 12379:
#1 0x00007ff38bb7f0d4 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xd40d4)
#2 0x00007ff38bb78bba _ZN7QThread4waitE14QDeadlineTimer (libQt5Core.so.5 + 0xcdbba)
#3 0x00007ff38b451fe5 n/a (libQt5DBus.so.5 + 0x16fe5)
#4 0x00007ff38b452049 n/a (libQt5DBus.so.5 + 0x17049)
#5 0x00007ff3ad876db7 __run_exit_handlers (libc.so.6 + 0x3fdb7)
#6 0x00007ff3ad876f5e exit (libc.so.6 + 0x3ff5e)
#7 0x00007ff3a41d1852 _XDefaultIOError (libX11.so.6 + 0x43852)
#8 0x00007ff3a41d1b0f _XIOError (libX11.so.6 + 0x43b0f)
#9 0x00007ff3a41cf9e3 _XReply (libX11.so.6 + 0x419e3)
#10 0x00007ff3a41b53a1 XGetSelectionOwner (libX11.so.6 + 0x273a1)
#11 0x00007ff38a67f19d _ZN7Kvantum11ThemeConfig16getCompositeSpecEv (libkvantum.so + 0xc319d)
#12 0x00007ff38a5ef8ed _ZNK7Kvantum5Style16setSurfaceFormatEP7QWidget (libkvantum.so + 0x338ed)
#13 0x00007ff38a615d8c _ZNK7Kvantum5Style9styleHintEN6QStyle9StyleHintEPK12QStyleOptionPK7QWidgetP16QStyleHintReturn (libkvantum.so + 0x59d8c)
#14 0x00007ff3a4c75d84 n/a (libQt5Widgets.so.5 + 0x2d8d84)
#15 0x00007ff3a4c76135 _ZN5QMenuC1ERK7QStringP7QWidget (libQt5Widgets.so.5 + 0x2d9135)
#16 0x00007ff3a50c7eab n/a (libqt_plugin.so + 0x96eab)
#17 0x00007ff3a50c8c1c n/a (libqt_plugin.so + 0x97c1c)
#18 0x00007ff38bd97e10 n/a (libQt5Core.so.5 + 0x2ece10)
#19 0x00007ff3a521ea56 n/a (libqt_plugin.so + 0x1eda56)
#20 0x00007ff3a50e5a2c n/a (libqt_plugin.so + 0xb4a2c)
#21 0x00007ff3a50e7379 n/a (libqt_plugin.so + 0xb6379)
#22 0x00007ff38bd97e10 n/a (libQt5Core.so.5 + 0x2ece10)
#23 0x00007ff3a521e8e0 n/a (libqt_plugin.so + 0x1ed8e0)
#24 0x00007ff38bd8d4bf _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2e24bf)
#25 0x00007ff3a4af7752 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x15a752)
#26 0x00007ff38bd60a7a _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2b5a7a)
#27 0x00007ff38bd63573 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5 + 0x2b8573)
#28 0x00007ff38bdba0a4 n/a (libQt5Core.so.5 + 0x30f0a4)
#29 0x00007ff3aaa34a84 g_main_context_dispatch (libglib-2.0.so.0 + 0x52a84)
#30 0x00007ff3aaa889b1 n/a (libglib-2.0.so.0 + 0xa69b1)
#31 0x00007ff3aaa332b1 g_main_context_iteration (libglib-2.0.so.0 + 0x512b1)
#32 0x00007ff38bdb96e1 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e6e1)
#33 0x00007ff38bd5f3fc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43fc)
#34 0x00007ff38bd67894 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2bc894)
#35 0x00007ff3a50c1f22 n/a (libqt_plugin.so + 0x90f22)
#36 0x00007ff3a50c2846 n/a (libqt_plugin.so + 0x91846)
#37 0x00007ff3ada0f3e9 start_thread (libpthread.so.0 + 0x93e9)
#38 0x00007ff3ad937293 __clone (libc.so.6 + 0x100293)
Jan 14 21:47:13 manjaro systemd[12581]: Started D-Bus User Message Bus.
Jan 14 21:47:13 manjaro dbus-daemon[12596]: [session uid=969 pid=12596] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=969 pid=12592 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Jan 14 21:47:13 manjaro systemd[12581]: Starting Accessibility services bus...
Jan 14 21:47:13 manjaro dbus-daemon[12596]: [session uid=969 pid=12596] Successfully activated service 'org.a11y.Bus'
Jan 14 21:47:13 manjaro systemd[12581]: Started Accessibility services bus.
Jan 14 21:47:13 manjaro dbus-daemon[12596]: [session uid=969 pid=12596] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=969 pid=12592 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Jan 14 21:47:13 manjaro systemd[12581]: Starting Virtual filesystem service...
Jan 14 21:47:13 manjaro dbus-daemon[12596]: [session uid=969 pid=12596] Successfully activated service 'org.gtk.vfs.Daemon'
Jan 14 21:47:13 manjaro systemd[12581]: Started Virtual filesystem service.
Jan 14 21:47:13 manjaro systemd[964]: bamfdaemon.service: Scheduled restart job, restart counter is at 4.
Jan 14 21:47:13 manjaro systemd[964]: Stopped BAMF Application Matcher Framework.
Jan 14 21:47:13 manjaro systemd[964]: Starting BAMF Application Matcher Framework...
Jan 14 21:47:13 manjaro bamfdaemon[12613]: Invalid MIT-MAGIC-COOKIE-1 keyUnable to init server: Could not connect: Connection refused
Jan 14 21:47:13 manjaro bamfdaemon[12613]: cannot open display: :0
Jan 14 21:47:13 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-12472-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:13 manjaro systemd[1]: systemd-coredump@1-12472-0.service: Succeeded.
Jan 14 21:47:13 manjaro audit: BPF prog-id=19 op=UNLOAD
Jan 14 21:47:13 manjaro audit: BPF prog-id=18 op=UNLOAD
Jan 14 21:47:13 manjaro polkitd[453]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Jan 14 21:47:13 manjaro polkitd[453]: <no filename>:4: subject=[Subject pid=12592 user='lightdm' groups=lightdm seat='seat0' session='c3' local=true active=true]
Jan 14 21:47:13 manjaro at-spi-bus-launcher[12603]: dbus-daemon[12603]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=969 pid=12592 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Jan 14 21:47:13 manjaro at-spi-bus-launcher[12603]: dbus-daemon[12603]: Successfully activated service 'org.a11y.atspi.Registry'
Jan 14 21:47:13 manjaro at-spi-bus-launcher[12631]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 14 21:47:13 manjaro systemd[964]: bamfdaemon.service: Scheduled restart job, restart counter is at 5.
Jan 14 21:47:13 manjaro bamfdaemon[12634]: Invalid MIT-MAGIC-COOKIE-1 keyUnable to init server: Could not connect: Connection refused
Jan 14 21:47:13 manjaro bamfdaemon[12634]: cannot open display: :0
Jan 14 21:47:13 manjaro systemd[964]: bamfdaemon.service: Scheduled restart job, restart counter is at 6.
Jan 14 21:47:13 manjaro systemd[964]: bamfdaemon.service: Start request repeated too quickly.
Jan 14 21:47:16 manjaro lightdm[12628]: gkr-pam: unable to locate daemon control file
Jan 14 21:47:16 manjaro audit[12628]: USER_AUTH pid=12628 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro lightdm[12628]: gkr-pam: stashed password to try later in open session
Jan 14 21:47:16 manjaro dbus-daemon[450]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.143' (uid=0 pid=12628 comm="lightdm --session-child 12 19 " label="unconfined")
Jan 14 21:47:16 manjaro dbus-daemon[450]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 14 21:47:16 manjaro lightdm[12628]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 14 21:47:16 manjaro audit[12628]: USER_ACCT pid=12628 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro kernel: kauditd_printk_skb: 58 callbacks suppressed
Jan 14 21:47:16 manjaro kernel: audit: type=1100 audit(1610657236.483:188): pid=12628 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro kernel: audit: type=1101 audit(1610657236.483:189): pid=12628 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro systemd[1]: Stopping Session c3 of user lightdm.
Jan 14 21:47:16 manjaro lightdm[12577]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jan 14 21:47:16 manjaro audit[12577]: USER_END pid=12577 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro audit[12577]: CRED_DISP pid=12577 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro systemd[1]: session-c3.scope: Succeeded.
Jan 14 21:47:16 manjaro systemd[1]: Stopped Session c3 of user lightdm.
Jan 14 21:47:16 manjaro kernel: audit: type=1106 audit(1610657236.526:190): pid=12577 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro kernel: audit: type=1104 audit(1610657236.526:191): pid=12577 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro audit[12628]: CRED_ACQ pid=12628 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro systemd-logind[455]: Removed session c3.
Jan 14 21:47:16 manjaro lightdm[12628]: pam_unix(lightdm:session): session opened for user niko(uid=1000) by (uid=0)
Jan 14 21:47:16 manjaro kernel: audit: type=1103 audit(1610657236.529:192): pid=12628 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro kernel: audit: type=1006 audit(1610657236.529:193): pid=12628 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=6 res=1
Jan 14 21:47:16 manjaro systemd-logind[455]: New session 6 of user niko.
Jan 14 21:47:16 manjaro systemd[1]: Started Session 6 of user niko.
Jan 14 21:47:16 manjaro lightdm[12628]: pam_env(lightdm:session): deprecated reading of user environment enabled
Jan 14 21:47:16 manjaro lightdm[12628]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
Jan 14 21:47:16 manjaro audit[12628]: USER_START pid=12628 uid=0 auid=1000 ses=6 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro kernel: audit: type=1105 audit(1610657236.546:194): pid=12628 uid=0 auid=1000 ses=6 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="niko" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 14 21:47:16 manjaro audit[12628]: USER_LOGIN pid=12628 uid=0 auid=1000 ses=6 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=manjaro addr=? terminal=/dev/tty7 res=success'
Jan 14 21:47:16 manjaro kernel: audit: type=1112 audit(1610657236.553:195): pid=12628 uid=0 auid=1000 ses=6 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=manjaro addr=? terminal=/dev/tty7 res=success'
Jan 14 21:47:16 manjaro at-spi-bus-launcher[1029]: dbus-daemon[1029]: Activating service name='org.a11y.atspi.Registry' requested by ':1.45' (uid=1000 pid=12643 comm="xfce4-session " label="unconfined")
Jan 14 21:47:16 manjaro at-spi-bus-launcher[1029]: dbus-daemon[1029]: Successfully activated service 'org.a11y.atspi.Registry'
Jan 14 21:47:16 manjaro at-spi-bus-launcher[12674]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 14 21:47:17 manjaro dbus-daemon[986]: [session uid=1000 pid=986] Activating via systemd: service name='org.ayatana.bamf' unit='bamfdaemon.service' requested by ':1.462' (uid=1000 pid=12721 comm="plank " label="unconfined")
Jan 14 21:47:17 manjaro systemd[964]: bamfdaemon.service: Start request repeated too quickly.
Jan 14 21:47:17 manjaro systemd[964]: bamfdaemon.service: Failed with result 'exit-code'.
Jan 14 21:47:17 manjaro systemd[964]: Failed to start BAMF Application Matcher Framework.
Jan 14 21:47:18 manjaro polkitd[453]: Registered Authentication Agent for unix-session:6 (system bus name :1.152 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Jan 14 21:47:18 manjaro NetworkManager[451]: <info> [1610657238.2145] agent-manager: agent[b068ab3e12e1ad2a,:1.154/org.freedesktop.nm-applet/1000]: agent registered
Jan 14 21:47:18 manjaro dbus-daemon[450]: [system] Activating via systemd: service name='org.blueman.Mechanism' unit='blueman-mechanism.service' requested by ':1.155' (uid=1000 pid=12748 comm="/usr/bin/python /usr/bin/blueman-applet " label="unconfined")
Jan 14 21:47:18 manjaro systemd[1]: Starting Bluetooth management mechanism...
Jan 14 21:47:18 manjaro blueman-mechanism[12827]: Unable to init server: Could not connect: Connection refused
Jan 14 21:47:18 manjaro blueman-mechani[12827]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
Jan 14 21:47:18 manjaro dbus-daemon[450]: [system] Successfully activated service 'org.blueman.Mechanism'
Jan 14 21:47:18 manjaro systemd[1]: Started Bluetooth management mechanism.
Jan 14 21:47:18 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:18 manjaro kernel: audit: type=1130 audit(1610657238.369:196): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:26 manjaro systemd[1]: Stopping User Manager for UID 969...
Jan 14 21:47:26 manjaro systemd[12581]: Stopped target Main User Target.
Jan 14 21:47:26 manjaro systemd[12581]: Stopping Accessibility services bus...
Jan 14 21:47:26 manjaro systemd[12581]: Stopping D-Bus User Message Bus...
Jan 14 21:47:26 manjaro systemd[12581]: Stopping Virtual filesystem service...
Jan 14 21:47:26 manjaro systemd[12581]: dbus.service: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Stopped D-Bus User Message Bus.
Jan 14 21:47:26 manjaro systemd[12581]: at-spi-dbus-bus.service: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Stopped Accessibility services bus.
Jan 14 21:47:26 manjaro systemd[964]: run-user-969-gvfs.mount: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: run-user-969-gvfs.mount: Succeeded.
Jan 14 21:47:26 manjaro systemd[1]: run-user-969-gvfs.mount: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: gvfs-daemon.service: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Stopped Virtual filesystem service.
Jan 14 21:47:26 manjaro systemd[12581]: Stopped target Basic System.
Jan 14 21:47:26 manjaro systemd[12581]: Stopped target Paths.
Jan 14 21:47:26 manjaro systemd[12581]: Stopped target Sockets.
Jan 14 21:47:26 manjaro systemd[12581]: Stopped target Timers.
Jan 14 21:47:26 manjaro systemd[12581]: dbus.socket: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Closed D-Bus User Message Bus Socket.
Jan 14 21:47:26 manjaro systemd[12581]: dirmngr.socket: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Closed GnuPG network certificate management daemon.
Jan 14 21:47:26 manjaro systemd[12581]: gpg-agent-browser.socket: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 14 21:47:26 manjaro systemd[12581]: gpg-agent-extra.socket: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 14 21:47:26 manjaro systemd[12581]: gpg-agent-ssh.socket: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 14 21:47:26 manjaro systemd[12581]: gpg-agent.socket: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 14 21:47:26 manjaro systemd[12581]: p11-kit-server.socket: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Closed p11-kit server.
Jan 14 21:47:26 manjaro systemd[12581]: pipewire.socket: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Closed Multimedia System.
Jan 14 21:47:26 manjaro systemd[12581]: pulseaudio.socket: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Closed Sound System.
Jan 14 21:47:26 manjaro systemd[12581]: Removed slice User Application Slice.
Jan 14 21:47:26 manjaro systemd[12581]: Reached target Shutdown.
Jan 14 21:47:26 manjaro systemd[12581]: systemd-exit.service: Succeeded.
Jan 14 21:47:26 manjaro systemd[12581]: Finished Exit the Session.
Jan 14 21:47:26 manjaro systemd[12581]: Reached target Exit the Session.
Jan 14 21:47:26 manjaro systemd[12582]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Jan 14 21:47:26 manjaro systemd[1]: user@969.service: Succeeded.
Jan 14 21:47:26 manjaro systemd[1]: Stopped User Manager for UID 969.
Jan 14 21:47:26 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:26 manjaro systemd[1]: Stopping User Runtime Directory /run/user/969...
Jan 14 21:47:26 manjaro kernel: audit: type=1131 audit(1610657246.619:197): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:26 manjaro systemd[1]: run-user-969.mount: Succeeded.
Jan 14 21:47:26 manjaro systemd[1]: user-runtime-dir@969.service: Succeeded.
Jan 14 21:47:26 manjaro systemd[1]: Stopped User Runtime Directory /run/user/969.
Jan 14 21:47:26 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:26 manjaro systemd[1]: Removed slice User Slice of UID 969.
Jan 14 21:47:26 manjaro systemd[964]: run-user-969.mount: Succeeded.
Jan 14 21:47:26 manjaro kernel: audit: type=1131 audit(1610657246.626:198): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:37 manjaro pulseaudio[12494]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Jan 14 21:47:37 manjaro dbus-daemon[450]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jan 14 21:47:38 manjaro dbus-daemon[450]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.159' (uid=1000 pid=13124 comm="/opt/discord/Discord " label="unconfined")
Jan 14 21:47:38 manjaro systemd[1]: Condition check resulted in Bluetooth service being skipped.
Jan 14 21:47:48 manjaro systemd[1]: blueman-mechanism.service: Succeeded.
Jan 14 21:47:48 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:48 manjaro kernel: audit: type=1131 audit(1610657268.395:199): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 14 21:47:51 manjaro rtkit-daemon[1059]: Supervising 5 threads of 1 processes of 1 users.
Jan 14 21:47:51 manjaro rtkit-daemon[1059]: Successfully made thread 15114 of process 15041 owned by '1000' RT at priority 10.
Jan 14 21:47:51 manjaro rtkit-daemon[1059]: Supervising 6 threads of 2 processes of 1 users.
Jan 14 21:47:52 manjaro rtkit-daemon[1059]: Supervising 6 threads of 2 processes of 1 users.
Jan 14 21:47:55 manjaro rtkit-daemon[1059]: Supervising 6 threads of 2 processes of 1 users.
Jan 14 21:47:55 manjaro rtkit-daemon[1059]: Successfully made thread 15498 of process 15098 owned by '1000' RT at priority 10.
Jan 14 21:47:55 manjaro rtkit-daemon[1059]: Supervising 7 threads of 3 processes of 1 users.
Jan 14 21:48:03 manjaro dbus-daemon[450]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jan 14 21:48:18 manjaro msm_notifier[12759]: "qt5-translations"
Jan 14 21:48:40 manjaro rtkit-daemon[1059]: Supervising 7 threads of 3 processes of 1 users.
Jan 14 21:48:40 manjaro rtkit-daemon[1059]: Successfully made thread 15795 of process 15142 owned by '1000' RT at priority 10.
Jan 14 21:48:40 manjaro rtkit-daemon[1059]: Supervising 8 threads of 4 processes of 1 users.
Jan 14 21:49:17 manjaro dbus-daemon[986]: [session uid=1000 pid=986] Failed to activate service
Accorrding to log my session was closed at 21:47, so the crash happened there.
I used the command for time between 21:43 and 21:48
SORRY. I did not provide the full log. Fixed that.
