Random freezes on startup and balanced power mode
For a few weeks already I’m experiencing random freezes when I’m on balanced power mode (both X11/Wayland) but for the last 2 days it’s hard to get my laptop to boot up as it freezes many times until a successful boot.
I already did a mem test and it ran smoothly.
Below logs:
journalctl -b -1 -p err
Feb 03 20:04:00 snow kernel: ACPI BIOS Error (bug): Failure creating named object [\_TZ.TZ01], AE_ALREADY_EXISTS (20250807/dswload2-326)
Feb 03 20:04:00 snow kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20250807/psobject-220)
Feb 03 20:04:00 snow kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2], AE_NOT_FOUND (20250807/dswload2-162)
Feb 03 20:04:00 snow kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20250807/psobject-220)
Feb 03 20:04:00 snow kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.WWAN], AE_NOT_FOUND (20250807/dswload2-162)
Feb 03 20:04:01 snow kernel: usb 6-1.1: device descriptor read/64, error -71
Feb 03 20:04:01 snow kernel: usb 6-1-port1: unable to enumerate USB device
Feb 03 20:04:01 snow kernel: usb 1-4: device descriptor read/64, error -110
Feb 03 20:04:01 snow kernel: usb 6-1-port2: unable to enumerate USB device
Feb 03 20:04:01 snow kernel: usb 6-1-port3: unable to enumerate USB device
Feb 03 20:04:01 snow kernel: usb 6-1-port4: unable to enumerate USB device
Feb 03 20:04:01 snow kernel: usb 1-4: device not accepting address 5, error -62
Feb 03 20:04:01 snow kernel: usb 1-4: device not accepting address 6, error -62
Feb 03 20:04:01 snow kernel: usb usb1-port4: unable to enumerate USB device
Feb 03 20:04:01 snow systemd-modules-load[503]: Failed to find module 'v4l2loopback-dc'
journalctl -b -1 | grep -i -E “freeze|hang|cpu|pstate|i915|amdgpu”
Feb 03 20:04:00 snow kernel: CPU topo: Max. logical packages:   1
Feb 03 20:04:00 snow kernel: CPU topo: Max. logical dies:       1
Feb 03 20:04:00 snow kernel: CPU topo: Max. dies per package:   1
Feb 03 20:04:00 snow kernel: CPU topo: Max. threads per core:   2
Feb 03 20:04:00 snow kernel: CPU topo: Num. cores per package:     8
Feb 03 20:04:00 snow kernel: CPU topo: Num. threads per package:  16
Feb 03 20:04:00 snow kernel: CPU topo: Allowing 16 present CPUs plus 0 hotplug CPUs
Feb 03 20:04:00 snow kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1
Feb 03 20:04:00 snow kernel: percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u262144
Feb 03 20:04:00 snow kernel: pcpu-alloc: s217088 r8192 d28672 u262144 alloc=1*2097152
Feb 03 20:04:00 snow kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
Feb 03 20:04:00 snow kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
Feb 03 20:04:00 snow kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=16.
Feb 03 20:04:00 snow kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
Feb 03 20:04:00 snow kernel: RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
Feb 03 20:04:00 snow kernel: RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
Feb 03 20:04:00 snow kernel: RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
Feb 03 20:04:00 snow kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Feb 03 20:04:00 snow kernel: Transient Scheduler Attacks: Mitigation: Clear CPU buffers
Feb 03 20:04:00 snow kernel: smpboot: CPU0: AMD Ryzen 9 6900HX with Radeon Graphics (family: 0x19, model: 0x44, stepping: 0x1)
Feb 03 20:04:00 snow kernel: smp: Bringing up secondary CPUs ...
Feb 03 20:04:00 snow kernel: .... node  #0, CPUs:        #2  #4  #6  #8 #10 #12 #14  #1  #3  #5  #7  #9 #11 #13 #15
Feb 03 20:04:00 snow kernel: smp: Brought up 1 node, 16 CPUs
Feb 03 20:04:00 snow kernel: cpuidle: using governor ladder
Feb 03 20:04:00 snow kernel: cpuidle: using governor menu
Feb 03 20:04:01 snow kernel: ledtrig-cpu: registered to indicate activity on CPUs
Feb 03 20:04:01 snow kernel: [drm] amdgpu kernel modesetting enabled.
Feb 03 20:04:01 snow kernel: amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.GP17.VGA_.ATPX handle
Feb 03 20:04:01 snow kernel: amdgpu: ATPX version 1, functions 0x00000001
Feb 03 20:04:01 snow kernel: amdgpu: ATPX Hybrid Graphics
Feb 03 20:04:01 snow kernel: amdgpu: Virtual CRAT table created for CPU
Feb 03 20:04:01 snow kernel: amdgpu: Topology: Add CPU node
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: enabling device (0006 -> 0007)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: initializing kernel modesetting (YELLOW_CARP 0x1002:0x1681 0x1043:0x144D 0xC7).
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: register mmio base: 0xFC500000
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: register mmio size: 524288
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 0 <common_v1_0_0> (nv_common)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 1 <gmc_v10_0_0> (gmc_v10_0)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 2 <ih_v5_0_0> (navi10_ih)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 3 <psp_v13_0_0> (psp)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 4 <smu_v13_0_0> (smu)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 5 <dce_v1_0_0> (dm)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 6 <gfx_v10_0_0> (gfx_v10_0)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 7 <sdma_v5_2_0> (sdma_v5_2)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 8 <vcn_v3_0_0> (vcn_v3_0)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: detected ip block number 9 <jpeg_v3_0_0> (jpeg_v3_0)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from VFCT
Feb 03 20:04:01 snow kernel: amdgpu: ATOM BIOS: 113-REMBRANDT-X37
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: amdgpu: 512M of VRAM memory ready
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: amdgpu: 15670M of GTT memory ready.
Feb 03 20:04:01 snow kernel: [drm] GART: num cpu pages 262144, num gpu pages 262144
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] Loading DMUB firmware via PSP: version=0x04000046
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [VCN instance 0] Found VCN firmware Version ENC: 1.33 DEC: 4 VEP: 0 Revision: 14
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: reserve 0xa00000 from 0xf41e000000 for PSP TMR
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: SMU is initialized successfully!
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] Display Core v3.2.351 initialized on DCN 3.1.2
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] DP-HDMI FRL PCON supported
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x04000046
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] eDP-1: PSR support 1, DC PSR ver 0, sink PSR ver 1 DPCD caps 0x2a su_y_granularity 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] DP-1: PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] DP-2: PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] DP-3: PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] DP-4: PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] DP-5: PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: kiq ring mec 2 pipe 1 q 0
Feb 03 20:04:01 snow kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Feb 03 20:04:01 snow kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Feb 03 20:04:01 snow kernel: amdgpu: Virtual CRAT table created for GPU
Feb 03 20:04:01 snow kernel: amdgpu: Topology: Add dGPU node [0x1681:0x1002]
Feb 03 20:04:01 snow kernel: kfd kfd: amdgpu: added device 1002:1681
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 6, active_cu_number 12
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: Runtime PM not available
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: amdgpu: [drm] Using custom brightness curve
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: [drm] Registered 4 planes with drm panic
Feb 03 20:04:01 snow kernel: [drm] Initialized amdgpu 3.64.0 for 0000:06:00.0 on minor 1
Feb 03 20:04:01 snow kernel: fbcon: amdgpudrmfb (fb0) is primary device
Feb 03 20:04:01 snow kernel: amdgpu 0000:06:00.0: [drm] fb0: amdgpudrmfb frame buffer device
inxi -zv8
  Kernel: 6.18.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=dc14b2f6-d710-4eaf-95d9-0888be89499a rw quiet
    cryptdevice=UUID=d8c2255b-746b-4112-8825-d5b447cbd487:luks-d8c2255b-746b-4112-8825-d5b447cbd487
    root=/dev/mapper/luks-d8c2255b-746b-4112-8825-d5b447cbd487 splash
    resume=/dev/mapper/luks-a322de2b-8ced-467d-9933-78c144bf7d07
    udev.log_priority=3 optimus-manager.startup=hybrid
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
  Type: Laptop System: ASUSTeK product: ROG Strix G713RS_G713RS v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: G713RS v: 1.0 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: G713RS.327 date: 02/16/2023
  ID-1: BAT0 charge: 69.1 Wh (100%) condition: 69.1/90 Wh (76.8%) volts: 16.55
    min: 15.86 model: AS3GWAF3KC GA50358 type: Unknown serial: <filter>
    charging: status: full control: start: N/A end: 100% cycles: N/A
  System RAM: total: 32 GiB available: 30.61 GiB used: 11.27 GiB (36.8%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M425R2GA3BB0-CQKOL serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 6900HX with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404108
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1100 min/max: 416/4937 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 1100 2: 1100 3: 1100
    4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100 11: 1100 12: 1100
    13: 1100 14: 1100 15: 1100 16: 1100 bogomips: 105401
    xsaves xtopology
    affected
  Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
    vendor: ASUSTeK driver: nvidia v: 590.48.01
    alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    off: HDMI-A-1 empty: DP-6,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:249c
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5,
    Writeback-1 bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 45.0 C
  Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9
    compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu,nv_platform,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
    s-diag: 1245mm (49.01")
  Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: left
    model: ASUS VG249 serial: <filter> built: 2021 res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 93 gamma: 1.2 chroma: red: x: 0.643 y: 0.329 green:
    x: 0.310 y: 0.627 blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1152x864,
    1280x720, 1440x576, 1024x768, 1440x480, 800x600, 720x576, 720x480,
    640x480
  Monitor-2: eDP-1 mapped: eDP pos: primary,right model: BOE Display 0x0a69
    built: 2021 res: 1920x1080 dpi: 171 gamma: 1.2 chroma: red: x: 0.682
    y: 0.322 green: x: 0.263 y: 0.690 blue: x: 0.149 y: 0.059 white: x: 0.314
    y: 0.329 size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9
    modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
    LLVM 21.1.6 DRM 3.64 6.18.8-1-MANJARO) device-ID: 1002:1681
    memory: 500 MiB unified: no
  API: Vulkan v: 1.4.335 layers: 8 device: 0 type: integrated-gpu name: AMD
    Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 25.3.4-arch1.1
    device-ID: 1002:1681 surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 3080 Laptop GPU driver: nvidia v: 590.48.01
    device-ID: 10de:249c surfaces: N/A
  Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: ASUSTeK
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
    bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.8-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
  IF: enp4s0 state: down mac: <filter>
  IF-ID-1: br-32716c3949aa state: down mac: <filter>
  IF-ID-2: br-4af560a95294 state: down mac: <filter>
  IF-ID-3: br-5466bf8b3ea7 state: down mac: <filter>
  IF-ID-4: br-bde33a9a7985 state: down mac: <filter>
  IF-ID-5: br-c7c055792d6b state: down mac: <filter>
  IF-ID-6: docker0 state: down mac: <filter>
  IF-ID-7: docker_gwbridge state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-8: vethd469f45 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Device-1: luks-d8c2255b-746b-4112-8825-d5b447cbd487 maj-min: 253:0
    type: LUKS dm: dm-0 size: 1.79 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.79 TiB
  Device-2: luks-a322de2b-8ced-467d-9933-78c144bf7d07 maj-min: 253:1
    type: LUKS dm: dm-1 size: 33.67 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 33.67 GiB
  Local Storage: total: 2.75 TiB used: 1.42 TiB (51.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 32.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Micron model: 2450 MTFDKBA1T0TFK
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 32.9 C
    scheme: GPT
  ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 1.42 TiB (80.9%)
    fs: ext4 dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-d8c2255b-746b-4112-8825-d5b447cbd487 label: N/A
    uuid: dc14b2f6-d710-4eaf-95d9-0888be89499a
    used: 688 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 578B-BAE5
  ID-1: swap-1 type: partition size: 33.67 GiB used: 125.1 MiB (0.4%)
    priority: -2 dev: /dev/dm-1 maj-min: 253:1
    mapped: luks-a322de2b-8ced-467d-9933-78c144bf7d07 label: N/A
    uuid: 7ee1bf63-ebc4-4ae7-8ca7-c0229e70c1ae
  ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 300 MiB fs: vfat label: NO_LABEL
    uuid: F729-D657
  ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 944.77 GiB fs: ext4 label: N/A
    uuid: 415d8219-ad78-4626-ab10-536750de4619
  ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 8.8 GiB fs: swap label: swap
    uuid: 5dd48583-a3fe-4bb0-af56-f4678bff9466
  Device-1: 1-3:2 info: ASUSTek N-KEY Device type: keyboard
    driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6 class-ID: 0301
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-2:2 info: [Maxxter] USB GAMING MOUSE type: mouse,keyboard
    chip-ID: 18f8:1286 class-ID: 0301
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-7: 6-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Hub-8: 7-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-9: 8-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 9-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 58.5 C mobo: 45.5 C gpu: amdgpu temp: 46.0 C
  Fan Speeds (rpm): cpu: 3000
  Packages: 1869 pm: pacman pkgs: 1831 libs: 398 tools: pamac,yay pm: flatpak
    pkgs: 38
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    3: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    4: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    5: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    6: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    7: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 518
  1: cpu: 100% command: ps pid: 25047 mem: 4.28 MiB (0.0%)
  2: cpu: 23.6% command: brave pid: 24976 mem: 433.4 MiB (1.3%)
  3: cpu: 8.6% command: brave pid: 24010 mem: 453.3 MiB (1.4%)
  4: cpu: 6.3% command: brave pid: 5073 mem: 238.6 MiB (0.7%)
  5: cpu: 5.8% command: brave pid: 2500 mem: 229.0 MiB (0.7%)
  Memory top: 5 of 518
  1: mem: 777.6 MiB (2.4%) command: baloorunner pid: 7359 cpu: 0.0%
  2: mem: 618.7 MiB (1.9%) command: exe pid: 3275 cpu: 3.7%
  3: mem: 588.4 MiB (1.8%) command: plasmashell pid: 1767 cpu: 0.2%
  4: mem: 554.5 MiB (1.7%) command: brave pid: 2437 cpu: 3.3%
  5: mem: 538.3 MiB (1.7%) command: ./steamwebhelper pid: 14813 cpu: 0.7%
  Processes: 518 Power: uptime: 2h 54m states: freeze,mem,disk suspend: s2idle
    image: 12.18 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 258 default: graphical tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.9 running-in: yakuake inxi: 3.3.40
What changes you did in the last 2 days? Maybe its related to Kernel 6.18? Try another Kernel maybe.
LTS 6.12 is another option.
The boot-up fails on 6.12 as well many times if for some reason the laptop is on balanced power mode. But boots up better on the fast mode.
[quote=“raycoms, post:1, topic:185388”]
Feb 03 20:04:00 snow kernel: ACPI BIOS Error (bug): Failure creating named >object [_TZ.TZ01], AE_ALREADY_EXISTS (20250807/dswload2-326)
Feb 03 20:04:00 snow kernel: ACPI Error: AE_ALREADY_EXISTS, During name >lookup/catalog (20250807/psobject-220)
Feb 03 20:04:00 snow kernel: ACPI BIOS Error (bug): Could not resolve symbol >[_SB.PCI0.GPP2], AE_NOT_FOUND (20250807/dswload2-162)
Feb 03 20:04:00 snow kernel: ACPI Error: AE_NOT_FOUND, During name >lookup/catalog (20250807/psobject-220)
Feb 03 20:04:00 snow kernel: ACPI BIOS Error (bug): Could not resolve symbol >[_SB.PCI0.GPP2.WWAN], AE_NOT_FOUND (20250807/dswload2-162)
ACPI errors are shown.
Looks like ACPI is throwing errors during boot. On this laptop, the issue seems tied to power mode: “balanced” can trigger these ACPI calls in a way that sometimes blocks boot, while “fast” mode avoids it. Basically, the BIOS is being picky about power-saving stuff early on.
If boot issues keep happening on “balanced,” you could stick to “fast” for reliability, or see if there’s a BIOS update that improves ACPI handling.
Could this be related to amd-pstate-epp driver?
