Random freezes of system
Hello,
I’ve been using manjaro for 4 years now and from the beginning I’ve been experiencing random freezes of the system. Hard to track/reproduce. I changed several time the kernel version (updating) and even made a complete new install of manjaro wiping out everything including config files in home once.
Here is my inxi
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=4c9feddd-ed2f-4772-9b56-b3d58512b575 ro quiet apparmor=1
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: Micro-Star model: B450 GAMING PRO CARBON AC (MS-7B85)
    v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 1.B0
    date: 11/08/2019
  System RAM: available: 31.29 GiB used: 3.91 GiB (12.5%)
  Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
    desc: 2x16 MiB
  Speed (MHz): avg: 3058 high: 4259 min/max: 2200/4409 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3783 2: 2057
    3: 3599 4: 2200 5: 4259 6: 2400 7: 3598 8: 2081 9: 4190 10: 2075 11: 4235
    12: 2222 bogomips: 91246
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Sapphire Nitro+ driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1,HDMI-A-2
    empty: DP-1,DP-2,DVI-D-1 bus-ID: 26:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 50.0 C
  Device-2: AVerMedia Live Streamer CAM 313 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2
    chip-ID: 07ca:313a class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: left model: AOC 24G2W1G4
    serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary,right model: AOC 2590G5
    serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 90 gamma: 1.2
    size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 590 Series
    (polaris10 LLVM 15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 26:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: AVerMedia Live Streamer CAM 313 driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 21:00.0 chip-ID: 8086:2526 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
  IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:4
    chip-ID: 8087:0025 class-ID: e001
  Local Storage: total: 931.52 GiB used: 269.78 GiB (29.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
  ID-1: / raw-size: 59.01 GiB size: 57.78 GiB (97.92%) used: 36.43 GiB (63.0%)
    fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 4c9feddd-ed2f-4772-9b56-b3d58512b575
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 79A3-ABE8
  ID-3: /home raw-size: 390.63 GiB size: 383.42 GiB (98.15%)
    used: 149.87 GiB (39.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 06544dbf-418d-45e3-bc98-cac13f3568a3
  ID-4: /run/media/network raw-size: N/A size: 912.46 GiB
    used: 586.41 GiB (64.3%) fs: cifs dev: /dev/Paroisse
  ID-5: /usr/Data raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 83.48 GiB (18.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Data
    uuid: caec8ba9-a359-472e-8914-3acb586707a9
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 8689674a-d3dd-47f7-ad02-ac3646753d4d
  Device-1: 1-8:2 info: Pixart Imaging Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 093a:2510 class-ID: 0301
  Device-2: 1-9:3 info: A4Tech LDLC AZERTY+ type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 09da:2267 class-ID: 0300
  Device-1: 3-2:2 info: AVerMedia Live Streamer CAM 313 type: video,audio
  Device-2: 3-3:3 info: Micro Star PRO CARBON type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7b85 class-ID: 0300
    serial: <filter>
  Device-3: 3-4:4 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  System Temperatures: cpu: 56.2 C mobo: N/A gpu: amdgpu temp: 51.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 859
  Processes: 312 Uptime: 37m wakeups: 0 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1595 libs: 462 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.27
Checking the log of last run I have this error at the end (but I can’t undurstand what to do with it on the internet)
juin 17 16:58:30 olivier-pc plasmashell[9514]: trying to show an empty dialog
juin 17 19:09:02 olivier-pc kernel: BUG: scheduling while atomic: swapper/1/0/0x00000000
juin 17 19:09:02 olivier-pc kernel: Modules linked in: rfcomm nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs qrtr squashfs cmac algif_hash algif_skcipher af_alg bnep v4l2loopback(OE) joydev mousedev btusb uvcvideo btrtl btbcm videobuf2_vmalloc btintel videobuf2_memops videobuf2_v4l2 btmtk snd_usb_audio videobuf2_common snd_usbmidi_lib bluetooth videodev snd_rawmidi intel_rapl_msr snd_seq_device intel_rapl_common mc usbhid ecdh_generic iwlmvm edac_mce_amd amdgpu mac80211 kvm_amd snd_hda_codec_realtek libarc4 snd_hda_codec_generic ledtrig_audio kvm iwlwifi snd_hda_codec_hdmi irqbypass snd_hda_intel vfat snd_intel_dspcfg crct10dif_pclmul fat crc32_pclmul snd_intel_sdw_acpi gpu_sched polyval_clmulni snd_hda_codec polyval_generic drm_buddy gf128mul video snd_hda_core ghash_clmulni_intel sha512_ssse3 drm_ttm_helper snd_hwdep aesni_intel cfg80211 ttm snd_pcm igb crypto_simd drm_display_helper cryptd snd_timer sp5100_tco wmi_bmof rapl rfkill dca pcspkr k10temp i2c_piix4 cec snd ccp soundcore wmi
juin 17 19:09:02 olivier-pc kernel:  gpio_amdpt gpio_generic acpi_cpufreq mac_hid uinput sg crypto_user fuse dm_mod loop bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci xhci_pci_renesas
juin 17 19:09:02 olivier-pc kernel: CPU: 1 PID: 0 Comm: swapper/1 Tainted: G           OE      6.1.31-2-MANJARO #1 f7e23b5df7ec048ccfbcce2261913c53c5ebe5aa
juin 17 19:09:02 olivier-pc kernel: Hardware name: Micro-Star International Co., Ltd. MS-7B85/B450 GAMING PRO CARBON AC (MS-7B85), BIOS 1.B0 11/08/2019
juin 17 19:09:02 olivier-pc kernel: Call Trace:
juin 17 19:09:02 olivier-pc kernel:  <TASK>
juin 17 19:09:02 olivier-pc kernel:  dump_stack_lvl+0x48/0x60
juin 17 19:09:02 olivier-pc kernel:  __schedule_bug.cold+0x42/0x4e
juin 17 19:09:02 olivier-pc kernel:  __schedule+0xecb/0x12c0
juin 17 19:09:02 olivier-pc kernel:  schedule_idle+0x2a/0x40
juin 17 19:09:02 olivier-pc kernel:  cpu_startup_entry+0x1d/0x20
juin 17 19:09:02 olivier-pc kernel:  start_secondary+0x115/0x140
juin 17 19:09:02 olivier-pc kernel:  secondary_startup_64_no_verify+0xe5/0xeb
juin 17 19:09:02 olivier-pc kernel:  </TASK>
I know how to use linux but I’m far to be an expert. Any help is appreciated.
Can you try to use memtest and check the RAM ?
Also: the CPU and GPU are a bit hot with 56°C / 51°C.
Memtest passed with no errors.
For CPU/GPU temperature I can try to tweak the fan, but I doubt it is related, I can play video game with high system load for a long time without any problem, or have a freeze while watching youtube …
