Hi there,
i try to make the jump from windows to manjaro. At the moment i am dualbooting with win 10.
Ever since i started to use manjaro more, i get random freezes: the mouse wont move and the screen won’t update. It does not seem to be any particular program, happens in thunderbird, dolphin, system settings, etc. I never had this problem with the win 10 install. My SO reported some crashes on her win 10 user account with citrix workspace, but i didnt think any of that, because it didn’t happen to me on my account ever.
I tried to activate REISUB and it does work sometimes, but recently it won’t work, i have to hard reset. I did a memtest (via grub) and it passed.
inxi -Fazy:
Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9e389b27-9fa8-48dd-8d9e-d77987c768df rw quiet splash
resume=UUID=9ce8cf0d-eb8d-4ff7-b779-166dc71995c2 udev.log_priority=3
amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASRock model: AB350 Gaming-ITX/ac
serial: <superuser required> UEFI: American Megatrends v: P7.40
date: 10/27/2022
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 1497 high: 2562 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1303 2: 1273
3: 2562 4: 1376 5: 1377 6: 1377 7: 1273 8: 1273 9: 2026 10: 1377 11: 1377
12: 1378 bogomips: 76830
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0c:00.0
chip-ID: 1002:73ef class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-1 mapped: DisplayPort-0 model: LG (GoldStar) ULTRAGEAR
serial: <filter> built: 2021 res: 2560x1440 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon RX 6650 XT (navi23
LLVM 15.0.7 DRM 3.49 6.1.44-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0e:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: GYROCOM C&C Fiio E10 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2
chip-ID: 1852:7022 class-ID: 0102
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: off with: wireplumber status: active
tools: pw-cli,wpctl
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp8s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:2 chip-ID: 8087:0aa7
class-ID: e001
Local Storage: total: 1.94 TiB used: 107.72 GiB (5.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 40.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Intenso model: Portable SSD
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 0506 scheme: GPT
ID-1: / raw-size: 237.78 GiB size: 232.99 GiB (97.98%) used: 17.91 GiB (7.7%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 465.75 GiB size: 457.37 GiB (98.20%)
used: 89.8 GiB (19.6%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-1: swap-1 type: partition size: 25.39 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 41.5 C mobo: N/A gpu: amdgpu temp: 40.0 C
mem: 40.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1062 fan-3: 653 fan-4: 0 fan-5: 0
gpu: amdgpu fan: 0
Processes: 292 Uptime: 1h 7m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 3.28 GiB (10.5%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1405 libs: 402 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
mhwd -li:
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
So here are some logs i pulled:
Thanks for any help!
