I have exactly the same issue. Not responsive mouse or keyboard for a second and in case of the keyboard it types the first character two times (by writing this post I noticed it can also happen with Ctrl+V).
I though it had something to do with a power saving mode, that’s why I disabled the USB autosuspend in /etc/default/grub
by adding this grub option usbcore.autosuspend=-1
. It doesn’t seem to work.
As @megavolt pointed, I have a similar output every time the system freezes on my /var/log/Xorg.0.log
. I watch the logs in real time by using tail -f /var/log/Xorg.0.log
. Whenever the system freezes the following lines appear:
[ 69.881] (II) event6 - MSFT0001:01 04F3:309E Touchpad: SYN_DROPPED event - some input events have been lost.
[ 69.882] (EE) client bug: timer event6 tap: scheduled expiry is in the past (-152ms), your system is too slow
Do you guys have any update? I tried different kernels but the issue persists, right now I am running 5.10
Here you have my inxi -Fazy
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_GB.UTF-8",
LC_IDENTIFICATION = "en_GB.UTF-8",
LC_MEASUREMENT = "en_GB.UTF-8",
LC_MONETARY = "en_GB.UTF-8",
LC_NAME = "en_GB.UTF-8",
LC_NUMERIC = "en_GB.UTF-8",
LC_PAPER = "en_GB.UTF-8",
LC_TELEPHONE = "en_GB.UTF-8",
LC_TIME = "en_DK.UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=d7fb37a0-afce-4f0a-b91d-4414fc357e41 ro quiet apparmor=1
security=apparmor udev.log_priority=3 intel_pstate=active
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81SX v: Legion Y540-15IRH
serial: <filter> Chassis: type: 10 v: Legion Y540-15IRH serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
UEFI: LENOVO v: BHCN29WW date: 06/19/2019
ID-1: BAT0 charge: 47.1 Wh condition: 48.5/57.0 Wh (85%) volts: 13.0/11.5
model: SMP L17M3PG2 type: Li-poly serial: <filter> status: Charging
cycles: 398
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 12 MiB
bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 801 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b class ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 460.39 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f11 class ID: 0300
Device-3: Lite-On Integrated Camera type: USB driver: uvcvideo bus ID: 1-6:2
chip ID: 04ca:7070 class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 res: 1920x1080 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348 class ID: 0403
Sound Server: ALSA v: k5.10.15-1-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 5000 bus ID: 00:14.3 chip ID: 8086:a370 class ID: 0280
IF: wlp0s20f3 state: dormant mac: <filter>
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 07:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp7s0 state: down mac: <filter>
IF-ID-1: br-704d80f9ebd8 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus ID: 1-14:4 chip ID: 8087:0aaa class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 924.07 GiB used: 54.41 GiB (5.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512TCK
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 002 P1LN temp: 46.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
size: 447.13 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: R022 scheme: GPT
ID-1: / raw size: 267.88 GiB size: 262.68 GiB (98.06%)
used: 54.38 GiB (20.7%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%)
used: 35.3 MiB (13.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 63.0 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 299 Uptime: N/A wakeups: 1 Memory: 15.52 GiB used: 1.1 GiB (7.1%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 alt: 9 Packages: 1391
pacman: 1382 lib: 408 flatpak: 0 snap: 9 Shell: Zsh v: 5.8
running in: yakuake inxi: 3.3.01
