I installed Manjaro Gnome on my DELL notebook. It just freezes ranomly, most of the time when opening discord or surfing web. Only solves when restarted. I tried different kernels but problem persisted.
There is my log and my systeminfo.
zář 21 17:01:51 lizardo-g55505 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20230331/dswload2-162)
zář 21 17:01:51 lizardo-g55505 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230331/psobject-220)
zář 21 17:01:51 lizardo-g55505 kernel: amd_gpio AMDI0030:00: Invalid config param 0014
zář 21 17:01:52 lizardo-g55505 kernel: amd_gpio AMDI0030:00: Invalid config param 0014
zář 21 17:01:52 lizardo-g55505 kernel: amd_gpio AMDI0030:00: Invalid config param 0001
zář 21 17:01:54 lizardo-g55505 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
zář 21 17:01:58 lizardo-g55505 kernel: amdgpu 0000:07:00.0: amdgpu: Secure display: Generic Failure.
zář 21 17:01:58 lizardo-g55505 kernel: amdgpu 0000:07:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
zář 21 17:01:59 lizardo-g55505 gdm-autologin][915]: gkr-pam: couldn't unlock the login keyring.
zář 21 17:01:59 lizardo-g55505 systemd[923]: Failed to start Application launched by gnome-session-binary.
zář 21 17:02:01 lizardo-g55505 systemd[923]: Failed to start Application launched by gnome-session-binary.
zář 21 17:28:38 lizardo-g55505 kernel: amdgpu 0000:07:00.0: [drm] *ERROR* [CRTC:67:crtc-0] flip_done timed out
Kernel: 6.4.6-3-rt8-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-rt-x86_64
root=UUID=eafa91b7-b592-4e71-b965-71e2388f5df5 rw amdgpu.noretry=0 quiet
splash apparmor=1 security=apparmor udev.log_priority=3 amdgpu.noretry=0
Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: Dell product: G5 5505 v: 1.15.0
serial: <superuser required> Chassis: type: 10 v: 1.15.0
Mobo: Dell model: 0JT83K v: A02 serial: <superuser required> UEFI: Dell
v: 1.15.0 date: 03/14/2023
ID-1: BAT0 charge: 17.0 Wh (55.4%) condition: 30.7/51.0 Wh (60.2%)
volts: 12.4 min: 11.4 model: LGC-LGC4.474 DELL 415CG0C type: Li-ion
serial: <filter> status: charging
System RAM: total: 16 GiB note: est. available: 15 GiB used: 1.55 GiB (10.3%)
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2524 high: 2900 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 2900
3: 2900 4: 2900 5: 1397 6: 2900 7: 2900 8: 2900 9: 1400 10: 2900 11: 2900
12: 2900 13: 2900 14: 2900 15: 1397 16: 2900 bogomips: 92637
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Dell driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:731f
class-ID: 0380
Device-2: AMD Renoir vendor: Dell driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-2
bus-ID: 07:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 57.0 C
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 0c45:671f
class-ID: 0e02
Display: wayland server: 'X.org' v: 1.21.1.8 with: Xwayland v: 23.2.0
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x05e4 built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.7-1 renderer: AMD Radeon Graphics (renoir
LLVM 16.0.6 DRM 3.52 6.4.6-3-rt8-MANJARO) direct-render: Yes
Device-1: AMD Navi 10 HDMI Audio vendor: Dell driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Dell
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.6-3-rt8-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off tools: pw-cli
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3.1:4 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 476.94 GiB used: 23.32 GiB (4.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 11004101 temp: 54.9 C
scheme: GPT
ID-1: / raw-size: 471.99 GiB size: 463.51 GiB (98.20%) used: 23.32 GiB (5.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: eafa91b7-b592-4e71-b965-71e2388f5df5
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 2C68-6B7E
ID-1: swap-1 type: partition size: 4.19 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 67e92172-7e4d-409b-9b3c-b9465cef81f9
Device-1: 3-2:2 info: Microdia Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0c45:671f class-ID: 0e02
Hub-4: 3-3:3 info: Genesys Logic Hub ports: 2 rev: 2.0
Device-1: 3-3.1:4 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 68.1 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 58.0 C device: amdgpu temp: 59.0 C mem: 60.0 C
fan: 65535 watts: 16.00
Processes: 512 Uptime: 1m wakeups: 5377 Init: systemd v: 254
Packages: pm: pacman pkgs: 1410 libs: 471 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.29
Moderator edit: formatting
