Ever since the bigger update last Monday (Feb 3rd) which elevated my Manjaro Stable to kernel 6.12.11-1 I am getting random freezes.
It is reproducible when I open Gimp and try to open several images as layers. But it has happened on other occasions, too. But this one is reproducible.
Can I help here in any way?
Yes
Please provide inxi -zv8
so we can try to help you.
random is not reproducible
Either it is reproducible or it is not
Without system info it is impossible to advise
- lack of adequate swap space comes to mind → Swap - Manjaro.
Here’s my inxi -zv8
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: hpet avail: acpi_pm
root=UUID=ad0f1960-e767-4d1a-9cd4-71b8a46d626a rw quiet splash
resume=UUID=36a1ac66-df39-43af-9e99-b54e9d9c0c2a udev.log_priority=3
video=DP-4:2360x1640@30
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: HP product: HP ProDesk 405 G4 Desktop Mini
v: DBXEnabled serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: HP model: 8626 v: KBC Version 07.D1.00 serial: <filter>
part-nu: 6QS11EA#ABD uuid: f32d2f13-ce4a-f1db-0f21-64dcbb3ce735 UEFI: HP
v: R24 Ver. 02.19.01 date: 07/28/2022
System RAM: total: 16 GiB available: 14.57 GiB used: 3.29 GiB (22.6%)
Device-1: ChannelB DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2667 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Hynix/Hyundai
part-no: HMA81GS6JJR8N-VK serial: <filter>
Device-2: ChannelA DIMM0 type: DDR4 detail: synchronous unbuffered
Slot: 2 type: PCIe gen: 3 status: available info: M.2 length: other
volts: 3.3 bus-ID: 02:05.0
Slot: 3 type: PCIe gen: 3 status: in use info: M.2 length: long volts: 3.3
bus-ID: 00:01.6 children: 1: 09:00.0 class-ID: 0108 type: mass-storage
Info: model: AMD Ryzen 5 PRO 2400GE w/ Radeon Vega Graphics socket: AM4
bits: 64 type: MT MCP arch: Zen level: v3 note: check built: 2017-19
process: GF 14nm family: 0x17 (23) model-id: 0x11 (17) stepping: 0
microcode: 0x8101016
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2300 min/max: 1600/3200 boost: enabled
base/boost: 3200/3800 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.4 V ext-clock: 100 MHz cores: 1: 2300 2: 2300 3: 2300 4: 2300
5: 2300 6: 2300 7: 2300 8: 2300 bogomips: 51123
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series
/ Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-2,DP-4 empty: DP-1,DP-3
bus-ID: 0a:00.0 chip-ID: 1002:15dd class-ID: 0300 temp: 49.0 C
Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-4.4:5
chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 5760x1600 s-dpi: 96 s-size: 1524x423mm (60.00x16.65")
s-diag: 1582mm (62.27") monitors: <missing: xrandr>
Monitor-1: DP-2 model: Acer CB382CUR serial: <filter> built: 2022
res: 3840x1600 dpi: 111 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green:
x: 0.271 y: 0.671 blue: x: 0.153 y: 0.055 white: x: 0.314 y: 0.329
size: 880x367mm (34.65x14.45") diag: 953mm (37.5") modes: 3840x1600,
2560x1080, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 90
Monitor-2: DP-4 model: DP1080P60 built: 2018 res: 1920x1080 dpi: 94
gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green: x: 0.282 y: 0.604 blue:
x: 0.141 y: 0.071 white: x: 0.314 y: 0.329 size: 480x270mm (18.9x10.63")
diag: 595mm (23.4") ratio: 16:9 modes: 1920x1080, 3840x2160, 2560x1600,
2360x1640, 2560x1440, 1920x1200, 1680x1050, 1600x900, 1280x1024,
1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 11 Graphics
(radeonsi raven LLVM 19.1.7 DRM 3.59 6.12.11-1-MANJARO)
device-ID: 1002:15dd memory: 1000 MiB unified: no
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: integrated-gpu name: AMD
Radeon Vega 11 Graphics (RADV RAVEN) driver: N/A device-ID: 1002:15dd
surfaces: xcb,xlib
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
speed: 8 GT/s lanes: 16 bus-ID: 0a:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3300 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br-e485322613b8 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 4-4.3.3:8 chip-ID: 0a12:0001 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 536.53 GiB used: 89.31 GiB (16.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H
lanes: 4 tech: SSD serial: <filter> fw-rev: HPS0 temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 283d 12h cycles: 676
read-units: 568,932,697 [291 TB] written-units: 12,231,539 [6.26 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Orico model: UFSD-C size: 59.59 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 0303
scheme: GPT
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-1: / raw-size: 460.61 GiB size: 452.31 GiB (98.20%)
used: 89.28 GiB (19.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: ad0f1960-e767-4d1a-9cd4-71b8a46d626a
used: 32.3 MiB (10.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 488B-D95B
ID-1: swap-1 type: partition size: 16.03 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 36a1ac66-df39-43af-9e99-b54e9d9c0c2a
ID-1: /dev/sda1 maj-min: 8:1 size: 59.55 GiB fs: exfat label: Ventoy
uuid: C467-C6C9
ID-2: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 223C-F3F8
Hub-2: 2-0:1 info: full speed or root hub ports: 1 rev: 2.0
Hub-3: 3-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 4-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-4:2 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 4-4.1:3 info: DigitalPersona Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 200mA
chip-ID: 05ba:000a class-ID: 0000 serial: <filter>
Hub-6: 4-4.3:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 4-4.3.1:6 info: Logitech Keyboard K120 type: keyboard,HID
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
chip-ID: 046d:c31c class-ID: 0300
Device-2: 4-4.3.2:7 info: HP Optical Mouse [672662-001] type: mouse
chip-ID: 03f0:094a class-ID: 0301
Device-3: 4-4.3.3:8 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode) type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
class-ID: e001
Device-4: 4-4.4:5 info: Logitech C920 PRO HD Webcam type: video,audio
Device-5: 4-4.5:9 info: Realtek BillBoard Device type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 chip-ID: 0bda:5418 class-ID: 1100
Hub-7: 5-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 5-3:2 info: JMicron / USA JMS567 SATA 6Gb/s bridge
type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 152d:0562 class-ID: 0806 serial: <filter>
Hub-8: 5-4:3 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-9: 5-4.3:4 info: Realtek Hub ports: 4 rev: 3.0
Hub-10: 6-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-11: 7-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 48.5 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1556 libs: 388 tools: pamac pm: rpm pkgs: 0
pm: flatpak pkgs: 0
Active pacman repo servers in: /etc/pacman.conf
1: https://download.sublimetext.com/arch/stable/x86_64
1: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
2: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
4: https://manjaro.kurdy.org/stable/$repo/$arch
5: https://mirror.23m.com/manjaro/stable/$repo/$arch
6: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 313
1: cpu: 100% command: ps pid: 3211 mem: 3.98 MiB (0.0%)
2: cpu: 50.3% command: firefox pid: 2490 mem: 668.3 MiB (4.4%)
3: cpu: 14.9% command: firefox pid: 2842 mem: 241.0 MiB (1.6%)
4: cpu: 10.4% command: kwin_wayland pid: 1101 mem: 298.4 MiB (2.0%)
5: cpu: 7.1% command: plasmashell pid: 1377 mem: 519.2 MiB (3.4%)
Memory top: 5 of 313
1: mem: 668.3 MiB (4.4%) command: firefox pid: 2490 cpu: 50.3%
2: mem: 519.2 MiB (3.4%) command: plasmashell pid: 1377 cpu: 7.1%
3: mem: 298.4 MiB (2.0%) command: kwin_wayland pid: 1101 cpu: 10.4%
4: mem: 241.0 MiB (1.6%) command: firefox pid: 2842 cpu: 14.9%
5: mem: 188.9 MiB (1.2%) command: firefox pid: 2758 cpu: 1.8%
Processes: 313 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.8 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
As you also have an AMD Radeon Vega Graphics, these random freezes might be caused by an Issues with Mesa 24.3.x and AMD Vega Graphics, as described in this thread Issues with Mesa 24.3.x and amdgpu Vega graphics / Pacman & Package Upgrade Issues / Arch Linux Forums.
Based on latest news this issue is hopefully gone with Kernel 6.12.17-1-lts and mesa 25.0.1.
Just a quick note to address a common misunderstanding when an issue is said to be reproducible;
An issue must generally be reproducable by others for it to be useful for troubleshooting purposes.
If you think about that in context, every issue you might have is likely to be reproducible (for you); but, unless others can also reproduce an issue, it’s increasingly difficult to confirm a cause.
You might already be aware of this; others, maybe not; so this note is equally for anyone who might have made assumptions when reproducing an issue is spoken of.
