Basically desktop freezes with no reason at all. Only power button reboot. video-linux is installed via mhwd. The gpu acceleration seems to be the issue. I will attach some logs. Please help
journalctl (last 100 lines)
-- Journal begins at Sat 2021-02-06 13:04:57 EET, ends at Tue 2021-02-23 21:41:14 EET. --
2021-02-23T19:51:00+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.23' (uid=1000 pid=885 comm="xfdesktop ")
2021-02-23T19:51:00+0200 stratuml tumblerd[913]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.6.so.0: cannot open shared object file: No such file or directory
2021-02-23T19:51:00+0200 stratuml dbus-daemon[486]: [system] Activating via systemd: service name='org.freedesktop.ColorManager' unit='colord.service' requested by ':1.27' (uid=1000 pid=924 comm="xiccd ")
2021-02-23T19:51:00+0200 stratuml systemd[1]: Starting Manage, Install and Generate Color Profiles...
2021-02-23T19:51:00+0200 stratuml dbus-daemon[486]: [system] Successfully activated service 'org.freedesktop.ColorManager'
2021-02-23T19:51:00+0200 stratuml systemd[1]: Started Manage, Install and Generate Color Profiles.
2021-02-23T19:51:00+0200 stratuml audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:00+0200 stratuml org.freedesktop.thumbnails.Thumbnailer1[913]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
2021-02-23T19:51:00+0200 stratuml org.freedesktop.thumbnails.Thumbnailer1[913]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
2021-02-23T19:51:00+0200 stratuml org.freedesktop.thumbnails.Thumbnailer1[913]: Registered thumbnailer heif-thumbnailer -s %s %i %o
2021-02-23T19:51:00+0200 stratuml org.freedesktop.thumbnails.Thumbnailer1[913]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.25' (uid=1000 pid=913 comm="/usr/lib/tumbler-1/tumblerd ")
2021-02-23T19:51:01+0200 stratuml systemd[758]: Starting Virtual filesystem service - disk device monitor...
2021-02-23T19:51:01+0200 stratuml dbus-daemon[486]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.30' (uid=1000 pid=955 comm="/usr/lib/gvfs-udisks2-volume-monitor ")
2021-02-23T19:51:01+0200 stratuml systemd[1]: Starting Disk Manager...
2021-02-23T19:51:01+0200 stratuml udisksd[960]: udisks daemon version 2.9.2 starting
2021-02-23T19:51:01+0200 stratuml polkitd[489]: Registered Authentication Agent for unix-session:1 (system bus name :1.31 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Activating service name='ca.desrt.dconf' requested by ':1.30' (uid=1000 pid=952 comm="light-locker ")
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Successfully activated service 'ca.desrt.dconf'
2021-02-23T19:51:01+0200 stratuml dbus-daemon[486]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.35' (uid=1000 pid=923 comm="xfce4-power-manager ")
2021-02-23T19:51:01+0200 stratuml audit: BPF prog-id=12 op=LOAD
2021-02-23T19:51:01+0200 stratuml audit: BPF prog-id=13 op=LOAD
2021-02-23T19:51:01+0200 stratuml systemd[1]: Starting Daemon for power management...
2021-02-23T19:51:01+0200 stratuml NetworkManager[487]: <info> [1614102661.5036] agent-manager: agent[fdb1dee9218e7db9,:1.34/org.freedesktop.nm-applet/1000]: agent registered
2021-02-23T19:51:01+0200 stratuml audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:01+0200 stratuml dbus-daemon[486]: [system] Successfully activated service 'org.freedesktop.UDisks2'
2021-02-23T19:51:01+0200 stratuml systemd[1]: Started Disk Manager.
2021-02-23T19:51:01+0200 stratuml udisksd[960]: Acquired the name org.freedesktop.UDisks2 on the system message bus
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
2021-02-23T19:51:01+0200 stratuml systemd[758]: Started Virtual filesystem service - disk device monitor.
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.25' (uid=1000 pid=913 comm="/usr/lib/tumbler-1/tumblerd ")
2021-02-23T19:51:01+0200 stratuml systemd[758]: Starting Virtual filesystem service - Apple File Conduit monitor...
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
2021-02-23T19:51:01+0200 stratuml systemd[758]: Started Virtual filesystem service - Apple File Conduit monitor.
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.25' (uid=1000 pid=913 comm="/usr/lib/tumbler-1/tumblerd ")
2021-02-23T19:51:01+0200 stratuml systemd[758]: Starting Virtual filesystem service - digital camera monitor...
2021-02-23T19:51:01+0200 stratuml dbus-daemon[486]: [system] Successfully activated service 'org.freedesktop.UPower'
2021-02-23T19:51:01+0200 stratuml systemd[1]: Started Daemon for power management.
2021-02-23T19:51:01+0200 stratuml audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
2021-02-23T19:51:01+0200 stratuml systemd[758]: Started Virtual filesystem service - digital camera monitor.
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.25' (uid=1000 pid=913 comm="/usr/lib/tumbler-1/tumblerd ")
2021-02-23T19:51:01+0200 stratuml systemd[758]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
2021-02-23T19:51:01+0200 stratuml systemd[758]: Started Virtual filesystem service - Media Transfer Protocol monitor.
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.23' (uid=1000 pid=885 comm="xfdesktop ")
2021-02-23T19:51:01+0200 stratuml systemd[758]: Starting Virtual filesystem metadata service...
2021-02-23T19:51:01+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Successfully activated service 'org.gtk.vfs.Metadata'
2021-02-23T19:51:01+0200 stratuml systemd[758]: Started Virtual filesystem metadata service.
2021-02-23T19:51:02+0200 stratuml dbus-daemon[486]: [system] Activating via systemd: service name='org.blueman.Mechanism' unit='blueman-mechanism.service' requested by ':1.39' (uid=1000 pid=953 comm="/usr/bin/python /usr/bin/blueman-applet ")
2021-02-23T19:51:02+0200 stratuml systemd[1]: Starting Bluetooth management mechanism...
2021-02-23T19:51:02+0200 stratuml blueman-mechanism[1070]: Unable to init server: Could not connect: Connection refused
2021-02-23T19:51:02+0200 stratuml blueman-mechani[1070]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
2021-02-23T19:51:02+0200 stratuml dbus-daemon[486]: [system] Successfully activated service 'org.blueman.Mechanism'
2021-02-23T19:51:02+0200 stratuml systemd[1]: Started Bluetooth management mechanism.
2021-02-23T19:51:02+0200 stratuml audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:02+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.46' (uid=1000 pid=953 comm="/usr/bin/python /usr/bin/blueman-applet ")
2021-02-23T19:51:02+0200 stratuml systemd[758]: Starting Bluetooth OBEX service...
2021-02-23T19:51:02+0200 stratuml obexd[1079]: OBEX daemon 5.55
2021-02-23T19:51:02+0200 stratuml dbus-daemon[780]: [session uid=1000 pid=780] Successfully activated service 'org.bluez.obex'
2021-02-23T19:51:02+0200 stratuml systemd[758]: Started Bluetooth OBEX service.
2021-02-23T19:51:02+0200 stratuml systemd[1]: systemd-rfkill.service: Succeeded.
2021-02-23T19:51:02+0200 stratuml audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:02+0200 stratuml kernel: kauditd_printk_skb: 19 callbacks suppressed
2021-02-23T19:51:02+0200 stratuml kernel: audit: type=1131 audit(1614102662.834:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:02+0200 stratuml NetworkManager[487]: <info> [1614102662.8788] manager: startup complete
2021-02-23T19:51:02+0200 stratuml systemd[1]: Finished Network Manager Wait Online.
2021-02-23T19:51:02+0200 stratuml audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:02+0200 stratuml systemd[1]: Reached target Network is Online.
2021-02-23T19:51:02+0200 stratuml systemd[1]: Starting TeamViewer remote control daemon...
2021-02-23T19:51:02+0200 stratuml kernel: audit: type=1130 audit(1614102662.877:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:02+0200 stratuml systemd[1]: teamviewerd.service: Can't open PID file /run/teamviewerd.pid (yet?) after start: Operation not permitted
2021-02-23T19:51:02+0200 stratuml systemd[1]: Started TeamViewer remote control daemon.
2021-02-23T19:51:02+0200 stratuml audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=teamviewerd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:02+0200 stratuml systemd[1]: Reached target Multi-User System.
2021-02-23T19:51:02+0200 stratuml systemd[1]: Reached target Graphical Interface.
2021-02-23T19:51:02+0200 stratuml kernel: audit: type=1130 audit(1614102662.937:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=teamviewerd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:02+0200 stratuml systemd[1]: Starting TLP system startup/shutdown...
2021-02-23T19:51:03+0200 stratuml tlp[1097]: Applying power save settings...done.
2021-02-23T19:51:03+0200 stratuml tlp[1097]: Setting battery charge thresholds...done.
2021-02-23T19:51:03+0200 stratuml systemd[1]: Finished TLP system startup/shutdown.
2021-02-23T19:51:03+0200 stratuml audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:03+0200 stratuml systemd[1]: Startup finished in 2.762s (firmware) + 7.263s (loader) + 1.738s (kernel) + 9.452s (userspace) = 21.217s.
2021-02-23T19:51:03+0200 stratuml kernel: audit: type=1130 audit(1614102663.194:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:07+0200 stratuml systemd[1]: NetworkManager-dispatcher.service: Succeeded.
2021-02-23T19:51:07+0200 stratuml audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:07+0200 stratuml kernel: audit: type=1131 audit(1614102667.010:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2021-02-23T19:51:10+0200 stratuml kernel: i915 0000:00:02.0: [drm] Resetting bcs0 for invalid CSB event
2021-02-23T19:51:10+0200 stratuml kernel: i915 0000:00:02.0: [drm] Resetting bcs0 for CS error
2021-02-23T19:51:10+0200 stratuml kernel: i915 0000:00:02.0: [drm] *ERROR* bcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
2021-02-23T19:51:10+0200 stratuml kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 8:2:00000009, in Xorg [609]
2021-02-23T19:51:10+0200 stratuml kernel: GPU hangs can indicate a bug anywhere in the entire gfx stack, including userspace.
2021-02-23T19:51:10+0200 stratuml kernel: Please file a _new_ bug report at https://gitlab.freedesktop.org/drm/intel/issues/new.
2021-02-23T19:51:10+0200 stratuml kernel: Please see https://gitlab.freedesktop.org/drm/intel/-/wikis/How-to-file-i915-bugs for details.
2021-02-23T19:51:10+0200 stratuml kernel: drm/i915 developers can then reassign to the right component if it's not a kernel issue.
2021-02-23T19:51:10+0200 stratuml kernel: The GPU crash dump is required to analyze GPU hangs, so please always attach it.
2021-02-23T19:51:10+0200 stratuml kernel: GPU crash dump saved to /sys/class/drm/card0/error
No error state collected
20-intel.conf
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "DRI" "3" # DRI3 is now default
Option "Accel" "False" # default
#Option "AccelMethod" "sna" # default
#Option "AccelMethod" "uxa" # fallback
EndSection
Thanks in advance!
Edit1:
cpu i5-5200U
gpu HD graphics 5500
