Random Bluetooth
Hello,
I don’t understand what’s going on. For several months, my computer didn’t ask me for a Bluetooth adapter to connect my headphones, phone, etc.
Then, in the middle of a session, everything cuts out and Bluetooth asks me for an adapter and my sound cuts out.
Can you explain what’s happening and how to fix it?
journalctl -b -1 -p err         ✔
mar 03 11:49:15 bruno kernel: x86/cpu: SGX disabled or unsupported by BIOS.
mar 03 11:49:15 bruno kernel: ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20250807/psparse-529)
mar 03 11:49:15 bruno kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20250807/uteval-68)
mar 03 11:49:15 bruno kernel: ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20250807/psparse-529)
mar 03 11:49:15 bruno kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20250807/uteval-68)
mar 03 11:49:15 bruno kernel: usb 1-14: device descriptor read/64, error -71
mar 03 11:49:15 bruno kernel: usb 1-14: device not accepting address 9, error -71
mar 03 11:49:15 bruno kernel: usb 1-14: device not accepting address 10, error -71
mar 03 11:49:15 bruno kernel: usb usb1-port14: unable to enumerate USB device
mar 03 11:49:15 bruno kernel: kvm_amd: CPU 3 isn't AMD or Hygon
mar 03 11:49:16 bruno kernel:
mar 03 11:49:16 bruno kernel: ACPI BIOS Error (bug): Attempt to CreateField of length zero (20250807/dsopcode-133)
mar 03 11:49:16 bruno kernel: ACPI Error: Aborting method \_SB.WMID.WQBD due to previous error (AE_AML_OPERAND_VALUE) (20250807/psparse-529)
mar 03 11:49:17 bruno kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Index (0x000000050) is beyond end of object (length 0x50) (20250807/exoparg2-393)
mar 03 11:49:17 bruno kernel: ACPI Error: Aborting method \_SB.WMID.WQBE due to previous error (AE_AML_BUFFER_LIMIT) (20250807/psparse-529)
mar 03 11:49:17 bruno kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [D008] at bit offset/length 128/8 exceeds size of target Buffer (128 bits) (20250807/dsopcode-198)
mar 03 11:49:17 bruno kernel: ACPI Error: Aborting method \HWMC due to previous error (AE_AML_BUFFER_LIMIT) (20250807/psparse-529)
mar 03 11:49:17 bruno kernel: ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_BUFFER_LIMIT) (20250807/psparse-529)
mar 03 11:49:21 bruno dbus-broker-launch[885]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
mar 03 11:49:30 bruno dbus-broker-launch[988]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
mar 03 11:49:34 bruno systemd[1]: Failed to start PostgreSQL database server.
mar 03 11:50:13 bruno akonadiserver[2550]: Failed to detect mysqld version!
mar 03 11:50:18 bruno akonadiserver[2550]: database server stopped unexpectedly
mar 03 11:50:18 bruno akonadiserver[2550]: Database process exited unexpectedly during initial connection!
mar 03 11:50:18 bruno akonadiserver[2550]: executable: "/usr/bin/mariadb"
mar 03 11:50:18 bruno akonadiserver[2550]: arguments: QList("--defaults-file=/home/bruno/.local/share/akonadi/mysql.conf", "--datadir=/home/bruno/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
mar 03 11:50:18 bruno akonadiserver[2550]: stdout: ""
mar 03 11:50:18 bruno akonadiserver[2550]: stderr: "/usr/bin/mariadb: unknown variable 'datadir=/home/bruno/.local/share/akonadi/db_data/'\n/usr/bin/mariadb: unknown variable 'pid-file=/run/user/1000/akonadi/mysql.pid'\n"
inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.18.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=97cf49da-abda-4eee-a51e-327879e52a12 rw rootflags=subvol=@ quiet
    splash resume=UUID=9482f96f-b0fe-4b78-bc89-20bffcbfff14
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.23.0
  Type: Desktop System: HP product: HP Pavilion Gaming Desktop 690-00xx v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: HP model: 843B v: 00 serial: <superuser required>
    part-nu: 4ML90EA#UUG uuid: <superuser required> Firmware: UEFI vendor: AMI
    v: F.11 date: 06/11/2018
  System RAM: total: 16 GiB available: 15.51 GiB used: 5.13 GiB (33.1%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Micron part-no: 8ATF1G64AZ-2G6E1
    serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 3793 min/max: 800/4000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3793 2: 3793 3: 3793 4: 3793 5: 3793 6: 3793
    bogomips: 33599
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Hewlett-Packard
    driver: nvidia v: 575.64.05 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: DVI-D-1,HDMI-A-1 empty: DP-1
    bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
  Device-2: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 046d:0843
    class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
  Monitor-1: DVI-D-1 pos: primary,left model: Samsung C24F390
    serial: <filter> built: 2019 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 94 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green: x: 0.329 y: 0.616
    blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
    size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  Monitor-2: HDMI-A-1 pos: right model: Samsung C24F390 serial: <filter>
    built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2
    chroma: red: x: 0.647 y: 0.337 green: x: 0.329 y: 0.616 blue: x: 0.145
    y: 0.055 white: x: 0.314 y: 0.329 size: 521x293mm (20.51x11.54")
    diag: 598mm (23.5") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.05
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
    memory: 1.95 GiB display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 4 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1050 driver: nvidia v: 575.64.05
    device-ID: 10de:1c81 surfaces: N/A
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.18.12-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw88_8821ce v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:c821
    class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:17
    chip-ID: 0a12:0001 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
  Local Storage: total: 13.76 TiB used: 7.41 TiB (53.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: BC501 HFM128GDJTNG-8310A size: 119.24 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 80002C00 temp: 46.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1SB102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: HPH4 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD Blue SA510 2.5 2TB size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD
    scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST8000DM004-2U9188
    size: 7.28 TiB block-size: physical: 4096 B logical: 4096 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> fw-rev: 1405 scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: Backup+ Desk
    size: 3.64 TiB block-size: physical: 4096 B logical: 4096 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 0342 scheme: GPT
  ID-1: / raw-size: 103.13 GiB size: 103.13 GiB (100.00%)
    used: 74.32 GiB (72.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 97cf49da-abda-4eee-a51e-327879e52a12
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 664 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: CA88-CDA1
  ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 655.41 GiB (70.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 0e6cd255-3156-47e7-a3c6-0c90ac95538a
  ID-4: /run/media/bruno/1c9f9e72-b373-4712-aec0-70ed9101bf32
    raw-size: 7.28 TiB size: 7.22 TiB (99.20%) used: 5.83 TiB (80.7%) fs: ext4
    dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: 1c9f9e72-b373-4712-aec0-70ed9101bf32
  ID-5: /run/media/bruno/Seagate raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    used: 685.05 GiB (18.4%) fs: btrfs dev: /dev/sdd1 maj-min: 8:49
    label: Seagate uuid: d032f352-c7e6-4813-a9e0-53b99b9b40f8
  ID-6: /run/media/bruno/_home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 206.45 GiB (11.1%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17 label: /home
    uuid: 50d36df0-5654-4709-b5f3-f55878455ee1
  ID-7: /var/cache raw-size: 103.13 GiB size: 103.13 GiB (100.00%)
  ID-8: /var/log raw-size: 103.13 GiB size: 103.13 GiB (100.00%)
  ID-1: swap-1 type: partition size: 15.62 GiB used: 3.24 GiB (20.7%)
    priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 9482f96f-b0fe-4b78-bc89-20bffcbfff14
  Device-1: 1-1:2 info: Dell MS116 Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 413c:301a class-ID: 0301
  Device-2: 1-4:17 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
    class-ID: e001
  Device-3: 1-6:4 info: Logitech Webcam C930e type: video,audio
    chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
  Device-4: 1-8:5 info: Seagate RSS LLC Backup Plus Desktop Drive (5TB)
    type: mass storage driver: uas interfaces: 1 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 0bc2:ab31 class-ID: 0806 serial: <filter>
  Device-5: 1-9:6 info: Primax HP PR1101U / PMX-KPR1101U Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 0461:0010 class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Device-1: 2-4:2 info: JMicron / USA JMS578 SATA 6Gb/s bridge
    type: mass storage driver: uas interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 152d:578e class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 44.0 C pch: 60.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 2619 pm: pacman pkgs: 2602 libs: 497 tools: pamac,yay pm: flatpak
    pkgs: 17
    1: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    2: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    3: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    4: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    6: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    7: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    8: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 400
  1: cpu: 10.6% command: firefox pid: 9481 mem: 1005.6 MiB (6.3%)
  2: cpu: 6.5% command: kwin_wayland pid: 1023 mem: 219.8 MiB (1.3%)
  3: cpu: 6.1% command: konsole pid: 36744 mem: 304.8 MiB (1.9%)
  4: cpu: 4.8% command: plasmashell pid: 1451 mem: 658.8 MiB (4.1%)
  5: cpu: 3.8% command: akonadi_control pid: 36974 mem: 246.2 MiB (1.5%)
  Memory top: 5 of 400
  1: mem: 1324.1 MiB (8.3%) command: baloo_file_extractor pid: 2612 cpu: 3.7%
  2: mem: 1005.6 MiB (6.3%) command: firefox pid: 9481 cpu: 10.6%
  3: mem: 658.8 MiB (4.1%) command: plasmashell pid: 1451 cpu: 4.8%
  4: mem: 562.4 MiB (3.5%) command: firefox pid: 9926 cpu: 1.8%
  5: mem: 389.9 MiB (2.4%) command: baloorunner pid: 18166 cpu: 0.0%
  Processes: 400 Power: uptime: 1h 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
journalctl --boot --priority=4 --no-pager
mar 03 13:01:55 bruno akonadiserver[34092]: exit code: 7
mar 03 13:01:55 bruno akonadiserver[34092]: process error: "Erreur inconnue"
mar 03 13:01:55 bruno akonadiserver[34092]: See "/home/bruno/.local/share/akonadi/db_data/mysql.err" for more details
mar 03 13:01:55 bruno akonadi_control[34132]: QThreadStorage: entry 2 destroyed before end of thread 0x55da89a50890
mar 03 13:01:55 bruno akonadi_control[34132]: QThreadStorage: entry 1 destroyed before end of thread 0x55da89a50890
mar 03 13:01:55 bruno akonadi_control[34134]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 03 13:01:55 bruno akonadi_control[34134]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.akonadi_control'")
mar 03 13:01:56 bruno akonadiserver[34143]: Failed to detect mysqld version!
mar 03 13:02:01 bruno akonadiserver[34143]: database server stopped unexpectedly
mar 03 13:02:01 bruno akonadiserver[34143]: Database process exited unexpectedly during initial connection!
mar 03 13:02:01 bruno akonadiserver[34143]: executable: "/usr/bin/mariadb"
mar 03 13:02:01 bruno akonadiserver[34143]: arguments: QList("--defaults-file=/home/bruno/.local/share/akonadi/mysql.conf", "--datadir=/home/bruno/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
mar 03 13:02:01 bruno akonadiserver[34143]: stdout: ""
mar 03 13:02:01 bruno akonadiserver[34143]: stderr: "/usr/bin/mariadb: unknown variable 'datadir=/home/bruno/.local/share/akonadi/db_data/'\n/usr/bin/mariadb: unknown variable 'pid-file=/run/user/1000/akonadi/mysql.pid'\n"
mar 03 13:02:01 bruno akonadiserver[34143]: exit code: 7
mar 03 13:02:01 bruno akonadiserver[34143]: process error: "Erreur inconnue"
mar 03 13:02:01 bruno akonadiserver[34143]: See "/home/bruno/.local/share/akonadi/db_data/mysql.err" for more details
mar 03 13:02:02 bruno akonadi_control[34189]: QThreadStorage: entry 2 destroyed before end of thread 0x55df53482890
mar 03 13:02:02 bruno akonadi_control[34189]: QThreadStorage: entry 1 destroyed before end of thread 0x55df53482890
mar 03 13:02:02 bruno akonadi_control[34187]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 03 13:02:02 bruno akonadi_control[34187]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.akonadi_control'")
mar 03 13:02:03 bruno akonadiserver[34199]: Failed to detect mysqld version!
mar 03 13:02:08 bruno akonadiserver[34199]: database server stopped unexpectedly
mar 03 13:02:08 bruno akonadiserver[34199]: Database process exited unexpectedly during initial connection!
mar 03 13:02:08 bruno akonadiserver[34199]: executable: "/usr/bin/mariadb"
mar 03 13:02:08 bruno akonadiserver[34199]: arguments: QList("--defaults-file=/home/bruno/.local/share/akonadi/mysql.conf", "--datadir=/home/bruno/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
mar 03 13:02:08 bruno akonadiserver[34199]: stdout: ""
mar 03 13:02:08 bruno akonadiserver[34199]: stderr: "/usr/bin/mariadb: unknown variable 'datadir=/home/bruno/.local/share/akonadi/db_data/'\n/usr/bin/mariadb: unknown variable 'pid-file=/run/user/1000/akonadi/mysql.pid'\n"
Thank you.
Mod edit: separated the inxi output from the journalctl outputs
That would be difficult…
A guess:
If you think the journal describes the error - that is - your bluetooth is an usb dongle connected at usb 1-14 - it looks like hardware failure, as in the bluetooth dongle dongle died.
As @linux-aarhus mentioned it looks like hardware failure particularly if it stopped working while it was working. There seems to be wavering support for this chip 0a12:0001 if you search for it. There were patches put into the kernel but apparently not completely resolved then they regressed at some point also. Best to get a more modern dongle.
Thanks tout all. I’m going to use a 'ew bluetooth dongle but I don’t know what kind of bluetooth’s Card to use.
Sorry not sure what you mean by this. A bluetooth dongle will have everything built in, doesn’t need a ‘card’ - it plugs into a usb port.
A little old (2022) but it might help: The Best USB Bluetooth Dongle for Linux - BIOSLEVEL
Dongle’s the way to go… where I live, I’d go to Shopee and pay attention to dongles that tell you what chip they have in the description, check if it’s a good one, order it…
Then (as happened a few years ago) return it if it has a fake chip, or doesn’t match the description.
It took me 2 weeks, I ended up with a decent dongle that cost around $3
