Hi i ask for a friend with manjaro i log in his computer via anydesk to update/upgrade the system but in the prosses of doing that pc run out of hdd space so the computer after restart can’t load kernel. so how can i transfer to a usb or external hdd some files to make some space and after what can i do to make manjaro operasional again.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
