typo? the echo behind md0 looks wrong.
It is wrong haha, sorry, just a copy/paste error.
LC_ALL=C sudo mdadm --action=check /dev/md0
mdadm: Count not set action for /dev/md0 to check: No such file or directory
I’m just wondering here:
this does not look like copy/paste -
… Count not set action …
that’s not english, that is a typo
Yeah true. It prints it differently, but the error is the same: ... No such file or directory
But why would you not copy/paste but type it instead and introduce errors and uncertainty that way?
It was a rhetorical question and I don’t want to derail the thread - sorry.
No response wanted or needed.
Now I know why - it is indeed related to the fact that it is raid0 - there is no such action for that kind of raid.
If you list the sys content for your raid you will see the sync_action file does not exist
ls /sys/block/md0/md
Example from my test box
[server1 ~]# cat /proc/mdstat
Personalities : [raid10] [raid0]
md126 : active raid0 sdc1[1] sdb1[0]
838596608 blocks super 1.2 512k chunks
md127 : active raid10 sde1[1] sdd1[0]
419298304 blocks super 1.2 512K chunks 2 far-copies [2/2] [UU]
[=======>.............] resync = 36.6% (153630848/419298304) finish=23.4min speed=188474K/sec
bitmap: 3/4 pages [12KB], 65536KB chunk
sample raid0
[server1 ~]# ls /sys/block/md126/md
array_size dev-sdb1 metadata_version reshape_position
array_state dev-sdc1 new_dev resync_start
bitmap fail_last_dev raid_disks safe_mode_delay
chunk_size layout rd0 serialize_policy
component_size level rd1 uuid
consistency_policy max_read_errors reshape_direction
as opposed to raid10far2
[server1 ~]# ls /sys/block/md127/md
array_size dev-sdd1 mismatch_cnt safe_mode_delay sync_min
array_state dev-sde1 new_dev serialize_policy sync_speed
bitmap fail_last_dev raid_disks suspend_hi sync_speed_max
bitmap_set_bits last_sync_action rd0 suspend_lo sync_speed_min
chunk_size layout rd1 sync_action uuid
component_size level reshape_direction sync_completed
consistency_policy max_read_errors reshape_position sync_force_parallel
degraded metadata_version resync_start sync_max
Awww goddamn!
If I’d only known this earlier
Would’ve saved me a lot of brain juice ![]()
Thank you so much for finally solving this and all of your efforts! Case closed!
