Hi everyone folks! Here I’m little question about configure my laptop graphics.
So after learning this great tutorial on Manjaro Wiki, Configure_Graphics_Card
I landed to right installed drivers for Nvidia Prime switch and look all good with this hardware:
inxi -G
Device-1: Intel TigerLake-H GT1 [UHD Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] driver: nvidia
v: 510.54
Display: server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting,nvidia
gpu: i915 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.3.7
andmhwd -li -d
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
CLASSIDS: 0300NAME: video-hybrid-intel-nvidia-prime
ATTACHED: PCI
VERSION: 2021.12.18
INFO: Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 8
FREEDRIVER: false
DEPENDS: video-modesetting
CONFLICTS: videonvidia
So I look strange behavior when testing render with glxspheres64
I tried two different commands for Prime Optimus offloading
First is DRI_PRIME= and other is prime-run but it’s get some different rendering performance and I will know why if possible to know of course, lol.
Below you can see some output for various commands combinations I tested;
DRI_PRIME=0 glxspheres64
Polygons in scene: 62464 (61 spheres * 1024 polys/spheres)
GLX FB config ID of window: 0x375 (8/8/8/0)
Visual ID of window: 0x734
Context is Direct
OpenGL Renderer: Mesa Intel(R) UHD Graphics (TGL GT1)
61.696234 frames/sec - 68.852997 Mpixels/sec
DRI_PRIME=1 glxspheres64 14s
libGL error: failed to create dri screen
libGL error: failed to load driver: nouveau
Context is Direct
1113.364755 frames/sec - 1242.515066 Mpixels/sec
prime-run glxspheres64 12s
GLX FB config ID of window: 0x138 (8/8/8/0)
Visual ID of window: 0x6e0
Context is Direct
OpenGL Renderer: NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2
61.091732 frames/sec - 68.178373 Mpixels/sec
Well after this three command you see output of DRI_PRIME=1 get errors and unbelievable FPS speed, this is not fully clear for me.
(So it’s Prime offloading I assume run cuda’s units with Intel UHD rendering, you remember 3DFX vga pass trough age? lol)
Well I think this so great but in fact is buggy and unusable with games on Steam for example.
When I try to pass DRI_PRIME=1 (or without it) variable on Steam game “Black Mesa”, this game will get random crash I see every cutting scene/ loading transition, otherwise if I launch game with prime-run the game is fine, but I assume no offloading from UHD Intel, only direct Nvidia rendering enabled like glxspheres64 print and performance is still “normal” so not huge FPS amount.
Now if anyone know why this happen, is really appreciated if want to explain to me more deep about Prime Optimus working, and if possible to handling DRI_PRIME=1 without errors. For example , maybe is better go to LTS kernel?
(Edit: or maybe is unusable because works only with noveau free driver? According to Manjaro wiki configure graphics write, this is my best guess)
Thanks in advance and best regards.
