Hey all, I’m having issues setting up my Razor Core X with Manjaro.
The situation:
I have an external monitor hooked up to the eGPU enclosure. I would like this external monitor to be my primary monitor and my laptop’s built-in monitor to be my secondary monitor.
Current Steps:
Initially, (with the appropriate AMD driver) I tried just connecting the eGPU and authorizing the thunderbolt device. The second display was detected but nothing showed up. I tried checking the “enabled” checkbox under KDE Plasma’s “Display Configuration” settings page. This didn’t change anything. It wasn’t until I also checked the “Primary” checkbox on the second monitor that it started working (turned on, received signal).
Everything was really choppy though so I followed Arch’s PRIME guide on setting a discrete GPU card as the primary GPU and eventually installed egpu-switcher. I tried the generated configuration from egpu-switcher, an analogous script from the Arch Wiki, and a conglomerate of the two. Both of which left me with the problem in the title.
Problem:
Seemingly randomly, when the eGPU is hooked up to the computer before boot, the primary (external) monitor won’t receive any video signal (it goes into sleep) on the login page (the laptop monitor is also off, I assume because it’s not set as the primary monitor). I know it’s the login page because by sheer luck, I tried entering my password with a black screen and Manjaro loaded up, after which, the external monitor would load. When this happens, there would be a number of login screens in windows (sddm-greeter) that can be interacted with, but does not lead to anything. I would just like a bit more consistency.
Currently used xorg.conf
file:
Section "Module"
Load "modesetting"
Load "amdgpu"
Load "intel"
EndSection
Section "ServerLayout"
Identifier "layout"
Screen 1 "primary"
Screen 0 "secondary" LeftOf "primary"
EndSection
Section "Device"
Identifier "amdgpu"
Driver "amdgpu"
BusID "PCI:58:0:0"
# Option "AllowEmptyInitialConfiguration"
# Option "AllowExternalGpus" "True"
EndSection
Section "Screen"
Identifier "primary"
Device "amdgpu"
EndSection
Section "Device"
Identifier "intel"
Driver "intel"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "secondary"
Device "intel"
EndSection
Any help is appreciated!
Here’s my inxi
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=5cd0efe7-0bc3-40fe-9334-0cb2d5228078 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: LENOVO product: 81C4 v: Lenovo YOGA C930-13IKB
serial: <filter> Chassis: type: 31 v: Lenovo YOGA C930-13IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: 8GCN37WW date: 11/23/2020
ID-1: BAT1 charge: 44.5 Wh (99.1%) condition: 44.9/60.0 Wh (74.9%)
volts: 8.6 min: 7.7 model: Simplo BASE-BAT type: Li-poly serial: <filter>
status: Unknown
RAM: total: 15.38 GiB used: 3.79 GiB (24.6%)
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 8 MiB bogomips: 32012
Speed: 2388 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 2388 2: 1170
3: 1939 4: 1810 5: 1481 6: 1850 7: 1613 8: 1945
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 3a:00.0 chip-ID: 1002:67df
class-ID: 0300
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-1:2
chip-ID: 5986:2115 class-ID: 0e02
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-6.1.2:7 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
loaded: amdgpu,intel unloaded: modesetting display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: HDMI-A-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-2: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.42.0
5.14.10-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_soc_skl
v: kernel alternate: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0401
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 3a:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 6b:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp107s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-1.2:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp55s0u1u2 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 462.05 GiB used: 129.44 GiB (28.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-000L2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 0L1QEXD7 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston model: SA400S37240
size: 223.57 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: SBFK scheme: MBR
ID-1: / raw-size: 127.98 GiB size: 125.72 GiB (98.24%)
used: 28.78 GiB (22.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 5cd0efe7-0bc3-40fe-9334-0cb2d5228078
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 29.1 MiB (11.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: BAA4-116D
ID-3: /run/media/ydeng/Windows-SSD raw-size: 109.25 GiB
size: 109.25 GiB (100.00%) used: 100.64 GiB (92.1%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows-SSD uuid: 98A2A485A2A46988
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: CA74A4EB74A4DC07
ID-3: /dev/sda1 maj-min: 8:1 size: 223.57 GiB fs: vfat label: ADDITIONAL
uuid: E0BC-2389
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Acer Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:2115
class-ID: 0e02
Device-2: 1-5:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:0081
class-ID: ff00 serial: <filter>
Hub-2: 1-6:4 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Hub-3: 1-6.1:6 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-6.1.2:7 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Hub-4: 1-6.1.3:8 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-6.1.3.1:10 info: Microdia USB DEVICE type: Keyboard,Mouse
power: 100mA chip-ID: 0c45:8520 class-ID: 0301
Device-2: 1-6.1.4:9 info: SINOWEALTH Game Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 480mA chip-ID: 258a:1007 class-ID: 0301
Device-3: 1-8:5 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 4-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Hub-9: 4-1.1:3 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Device-1: 4-1.2:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 256mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Device-2: 4-1.3:5 info: VIA Labs VL817 SATA Adaptor type: Mass Storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 8mA
chip-ID: 2109:0715 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 52.5 C mobo: 29.8 C gpu: amdgpu temp: 72.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 824
Processes: 315 Uptime: 1h 37m wakeups: 9 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1330
lib: 346 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.08
