qwikaccess - a point and click qt gui for scripts
so i thought i should share something that i have done with qt creator
qwikaccess
it is a simple program made with qt.
its a gui to run scripts with clicks.
aur download --
https://aur.archlinux.org/packages/qwikaccess-git/
pamac build qwikaccess-git
github repo --
the scripts here used are what i found them here on forum and on web.
if anyone interested in improving scripts please do so.
Looks really professional, should be really helpful :smiley:
Have you created an AUR package yet?
Stupid question - flashlight?
yup it works
tested on postmarket os
nexus5
Phone doh! (I did say stupid!!)
okay added new restart scripts and touchpad touchscreen on/off buttons
restart scripts credits @tbg
autohidpi script credits @cscs
well .. I did once go on a hunt for a way to use a laptop webcam flash/light as a reading light ..
(I was not successful)
added keyboard backlight on/off button
now ui is scrollable and good looking
im now out of ideas
as to what to add next
if anyone has suggestions then tell.
added playerctl controls
Enabled status checking of almost all buttons
You said something about ideas .. and I was just thinking .. depending on how this was widgetized or bound to sliding from the side of screen or similar .. it could work a lot like those budgie or deeping\ 'side configuration panel' things that some people liked so much.
well it is going to be in coreaction as a widget
which is a sidebar.
i had added the widget at start but now im delaying its addition until i feel its ready.
this app actually is a prototype.
made for testing until its ready to be added in coreaction.
but i will make coreaction widget qwickaccess and qwickaccess app as seperate.
as both have different things.
raven. thats what the budgie one was.
now it looks okay on pinephone too
images by
@spikerguy
so i have added qwikaccess parts to coreaction and coretoppings
Nice work.
