I have an old secondary PC and i connect to it using ssh or vnc.
The hardware is my old PC
I tried first to use TigerVnc but that didn’t work: “… connection closed …”
Now i use x11vnc, that works, but it is really slow: i can watch single characters appearing on screen when i type them
Any tipps to speedup x11vnc or an alternative ?
In /etc/hosts.allow i typed x11vnc : All
Perhaps i have to live with that?
Ok, it is enough to ssh to this old PC to keep it uptodate!
Thanks for your tipps!
kurdy
2
I had similar issue and I used Teamviewer which is free for private use. It works fine for me you can adjust some parameters to improve performances.
Ok, i would like to try Teamviewer but how to install on Manjaro?
There are packages: *.deb and tar.gz?!
Thanks a lot for this tipp … it works
mbb
5
You can also try NoMachine. It’s heavier on the CPU, but it works very well, can be forwarded through ssh and doesn’t depend on a 3rd party server.
system
Closed
6
