Quick Settings Menu misaligned with User Themes extension
Experiencing an issue with Gnome Quick Settings Menu being misaligned when “User Themes” Gnome Extension is enabled:
Screenshot from 2023-05-25 10-21-31
When extension is turned off, its all good again:
Screenshot from 2023-05-25 13-41-04
My system:
  Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    Desktop: GNOME v: 44.1 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: Z790 Taichi serial: <superuser required>
    UEFI: American Megatrends LLC. v: 2.01 date: 09/22/2022
  Info: 24-core (8-mt/16-st) model: 13th Gen Intel Core i9-13900KF bits: 64
    type: MST AMCP arch: Raptor Lake rev: 1 cache: L1: 2.1 MiB L2: 32 MiB
    L3: 36 MiB
  Speed (MHz): avg: 3201 high: 5500 min/max: 800/5500:5800:4300 cores:
    1: 5500 2: 3000 3: 3000 4: 3000 5: 3000 6: 3000 7: 3000 8: 3000 9: 3000
    10: 3000 11: 3000 12: 3000 13: 3000 14: 3000 15: 3000 16: 3000 17: 4304
    18: 3000 19: 4299 20: 3000 21: 4330 22: 3000 23: 3000 24: 3000 25: 3000
    26: 3000 27: 3000 28: 3000 29: 3000 30: 3000 31: 3000 32: 3000
    bogomips: 191744
  Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Gigabyte driver: nvidia
    v: 530.41.03 arch: Lovelace bus-ID: 01:00.0
  Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1 driver: X:
    loaded: nvidia gpu: nvidia resolution: 1920x1080
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
    4090/PCIe/SSE2 direct-render: Yes
  Device-1: Intel vendor: ASRock driver: snd_hda_intel v: kernel
    bus-ID: 00:1f.3
  Device-2: NVIDIA AD102 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  Device-3: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB bus-ID: 1-7.3:9
  API: ALSA v: k6.1.30-1-MANJARO status: kernel-api
  Server-1: sndiod v: N/A status: off
  Server-2: JACK v: 1.9.22 status: off
  Server-3: PipeWire v: 0.3.70 status: off
  Server-4: PulseAudio v: 16.1 status: active
  Device-1: Intel vendor: Rivet Networks driver: iwlwifi v: kernel port: N/A
    bus-ID: 00:14.3
  IF: wlp0s20f3 state: down mac: <filter>
  Device-2: Intel vendor: ASRock driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169
    v: kernel port: 3000 bus-ID: 6e:00.0
  IF: enp110s0 state: down mac: <filter>
  Device-4: Microsoft Xbox Wireless Adapter for Windows driver: N/A
    type: USB bus-ID: 1-7.2:7
  Device-1: Intel driver: btusb v: 0.8 type: USB bus-ID: 1-14:11
  Report: rfkill ID: hci1 rfk-id: 2 state: up address: see --recommends
  Device-2: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB
    bus-ID: 1-7.1:5
  Report: ID: hci0 rfk-id: 1 state: up address: N/A
  Local Storage: total: 4.94 TiB used: 79.54 GiB (1.6%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
    temp: 43.9 C
  ID-2: /dev/nvme1n1 vendor: Western Digital model: WDS100T3X0C-00SJG0
    size: 931.51 GiB temp: 41.9 C
  ID-3: /dev/nvme2n1 model: PCIe SSD size: 111.79 GiB temp: 32.9 C
  ID-4: /dev/sda vendor: SanDisk model: SSD PLUS 240GB size: 223.58 GiB
  ID-5: /dev/sdb vendor: Samsung model: SSD 850 PRO 1TB size: 953.87 GiB
  ID-6: /dev/sdc vendor: Crucial model: CT1050MX300SSD1 size: 978.09 GiB
  ID-1: / size: 218.72 GiB used: 79.54 GiB (36.4%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 316 KiB (0.1%) fs: vfat
    dev: /dev/sda1
  System Temperatures: cpu: 42.0 C mobo: N/A
  Processes: 517 Uptime: 3h 2m Memory: available: 62.62 GiB
  used: 4.83 GiB (7.7%) Init: systemd Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: 1355 Shell: Zsh v: 5.9 inxi: 3.3.27
Looks like it’s a bug in the theme you have selected. You should report it to them.
