how to set layout switch to Fn+Shift. I’ve got Lenovo laptop if it helps
The Fn key is a modifier for laptop keyboards and not an actual key, so it does not have a key code all by itself as it is a hardware key to modify existing keys into other keys.
So what you’re asking for is impossible with the current state of technology.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
