Reading the Manjaro wiki documentation, option 3.2 (shown below), I get errors for the keyserver not found:
Errors:
Should the Manjaro wiki documentation continue to use Phil’s key or rather the Manjaro Build Server <build@manjaro.org>
key?
key?
It’s an issue with the default keyserver. If you’re brave, you can switch to the unstable branch and test gnupg
2.2.28-2.2 with patches to use keyserver.ubuntu.com.
FS#71078 - [gnupg] change default keyserver due to certificate expiration this month
Once upstream makes the needed changes, we can update the wiki accordingly.
EDIT: Wiki updated.
I’ve marked this answer as the solution as it’s the best answer you’ll get:
If you disagree, feel free to:
You’re in control but I just wanted to ensure that when other people have the same issue, they’ll find your Q&a as the authoritative answer…
I don’t want to validate packages (well I do ), but these instructions were for validating an ISO.
I’m assuming that the wiki page is for a, lets say, non-manjaro user (opensuse) interested in validating the Manjaro ISO (because they want to switch maybe ). The wiki page lists specific gpg commands that use a now invalid key server.
Yes, the problem here is not gpg itself, but the wiki that explicitly sets a now defunct server as keyserver.
While the wiki does set the defunct keyserver, it is actually the same server as the GnuPG software itself sets as default. But it is still defunct.
So that line in the wiki, should just get updated to set a working keyserver.
That’s the point
Even if I have defined another keyserver (I have) that command sets a non functional keyserver.
I just updated it.
Should these two sentences on the wiki page also be changed to include the Manjaro Build Server?
If you have some free time, items 1 and 2 should be reviewed for usability by non-Manjaro users.
For example:
Done, except for using pamac
(Manjaro installer) instead of pacman
(Arch) and left out other distros as it’s the Manjaro wiki.
