It is really just very minor inconvenience. When you enable “Lock screen when system enters power saving mode” in Xfce Power Management Settings, send the System to hibernation and then wake it up again with a keypress, the displays stay offline until you press another button or move the mouse.
If this option is not set, the displays wake up by themself after the first button press.
Desired behavior would be that the displays wake up even if this option is set and show the login screen.
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
