I’m still kind of a noobish Linux user. I know orphans are packages that are not used by anything, but sometimes it’s really confusing if it’s safe to do or not.
I installed Ungoogled Chromium from source the other day (through Pamac, AUR iirc), but I didn’t remove orphans afterwards because I forgot (I typically do it after a few installs that I do on my own). Today I installed Open JDK (pacman -S jre-openjdk), and then used “sudo pacman -Rsn $(pacman -Qqdt)”, and there were some packages that I wasn’t sure about, for example “gc” (which according to Google is a garbage collector for C and C++), “make” and a few others. I know it’s typically safe to remove orphans, but I’m totally unsure if I should proceed in this case. I know stuff like “make” will be useful if I were to build more programs from source, but I don’t typically do that (the Chromium one was a mistake I didn’t realize because I clicked install and had to leave for a few hours, came back seeing I installed it from source, lol).
This is the list of orphans I can remove. Is it 100% safe to do or should I just not remove any of those?
checking dependencies...
:: gnutls optionally requires guile: for use with Guile bindings
:: graphviz optionally requires guile: guile bindings
Packages (14) gc-8.2.0-2 guile-2.2.7-2 m4-1.4.19-1 autoconf-2.71-1 automake-1.16.5-1
bison-3.8.2-1 flex-2.6.4-3 gn-0.1956.fc295f3a-1 gperf-3.1-3 lld-13.0.1-1
make-4.3-3 ninja-1.10.2-1 patch-2.7.6-8 pkgconf-1.8.0-1
Total Removed Size: 83,69 MiB
Thank you in advance.
